What kind of gas for my stock cr125?
Last post 07-08-2009, 6:53 AM by Davebs14. 11 replies.
  •  06-29-2009, 7:08 PM 367188
    What kind of gas should I use in my stock cr125? It is brand new and the shop I bought it from said that pump gas (93 octane) wouldn't be ideal. Any thoughts or input would be appreciated.
  •  06-29-2009, 8:33 PM 367201 in reply to 367188
    Re: What kind of gas for my stock cr125?
    If not 110 unleaded at least 100 unleaded.  I've heard anywhere from 24/1 to 32/1 mixture ratio, I've been good with around 28/1.
    Jeff
  •  06-29-2009, 8:45 PM 367203 in reply to 367201
    Thanks Jeff. I'm assuming leaded 110 would be fine as well since VP's website recommends that for shifter applications. Would anybody care to comment on leaded vs. unleaded?
  •  06-30-2009, 6:13 AM 367242 in reply to 367203
    I would assume the new motor has valve seats made of modern material. (I feel so stupid)  Unleaded
    I would also think the shop you bought it from would provide more support.
    Where might you be running this new fancy Kart Brian?  I heard there was a Kart @ Bell Chase this weekend   That wasn't you was it?
  •  06-30-2009, 5:05 PM 367396 in reply to 367242
    Joe_914:
    I would assume the new motor has valve seats made of modern material.  Unleaded
    Valve seats?  In a CR125?
    Stick with leaded if possible. Besides, its hard to find unleaded beyond 104 octane.  But 110 leaded is available from VP or Torco from lots of sources.
    I use Torco 110.  If you want to find a distributor near you, try this:
    http://torcoracefuel.net/dealers.html
    I did that a few years ago and the distributor was able to point out several gas stations in my area that carry his fuel.
    Larry MacLeod
  •  07-02-2009, 8:55 PM 367761 in reply to 367396
    I ended up getting some Sunoco 110 from Hyperfuels. Thanks for all the suggestions.
     Joe, that wasn't me. I'll be at every event possible from here on out tho.
  •  07-02-2009, 10:07 PM 367771 in reply to 367761
    Was that you that called me? Did it get to Mississippi in time for this weekend? I sent it out asap'...
    If it stays under 100 this weekend I plan on double entering my kart as well.
    Call my cell and let me know how it works out :)  832 six two zero 5 5 five seven
    (I'll be running My Sunoco 110 this weekend as well)  ;)   Let me know after this weekend how it works and I can work out a deal for ya on a 15gal of the Stuff. Maybe I can make it to a Louisiana event sometime :)
    David Hedderick
    Pearland (Houston), TX
    http://www.hyperfuels.com
    09 VW Jetta TDI SSC racer
    08 Mazda 3s
  •  07-03-2009, 6:43 AM 367793 in reply to 367761
    Is that Turbo Blue 110?  I used to use that from Sunoco before the local station switched over to unleaded 104 octane.  Strangely, the place I get my Torco 110 is a Sunoco station.
    Good luck.
    Larry
  •  07-06-2009, 12:35 PM 368131 in reply to 367793
    I can get the turbo blue as well (TB and Sunoco are made by Sunoco).
     The only real difference with them is probably just noise at the time of testing....but the TB has a slightly lower reid vapor pressure # than the sunoco...and a slightly higher gravity. :)  Other than that they are identical...
    There are other fuels here that I run from time to time that I sell...(VP U4.2 and Sunoco MO2X) but they really only seem to make a noticable difference for me in the heat when I am down on power. :)
    I wish there was an easy way to run (and wish it was legal) alcohol in the kart too...I got a ton of that and it's WAYYY cheaper :)
    David Hedderick
    08 Mazda 3s
  •  07-06-2009, 8:28 PM 368249 in reply to 368131
    There's a race this weekend here in Baton Rouge. Check it out: http://www.sowela-scca.org/flyers/gckc.pdf
    I'll try and give you a shout tomorrow evening.
  •  07-07-2009, 7:18 AM 368312 in reply to 368249
    CENLA is having a night SOLO event in Zachary on the 18th of July.
  •  07-08-2009, 6:53 AM 368515 in reply to 368312
    I would SO be there if I wasn't going outta town for work :(
    I really liked that site...I wish I was running another Div there again this year
    David Hedderick
    08 Mazda 3s
