new spherical Delrin pin top shock mounts
Last post 07-15-2009, 1:56 PM by G1. 10 replies.
07-01-2009, 6:02 AM |
BrianCunningham
Joined on 12-27-2000
from Boston
Posts 977
Points 16,390
just thought you might want to know about the mounts I'm going to use in the front.
this lets you run a longer shock and still have the benefits of a clevis mount.
You can run them on your stock shocks too
ghoffman; This is the first and only truly correct mount for "pin top" shocks. They are CNC billet DuPont Delrin and stainless steel and will allow your shocks to have correct damping without the rubber and it still allows angular deflection of the shock as it goes through its' motion with virtually zero side load on the shock. Unlike some others, this is spherical on the top and bottom so it works with stock or coil-over shocks. Tested on Penske, Bilstein, Sachs (OE Corvette) shocks but will fit any shock with a 10mm upper pin top. The price is for an entire car set. Better performance, better shock life, totally quiet for street or track use. In stock for immediate delivery. The gold colored plate not included. http://hardbarusa.com/hardbar/product_info.php?cPath=21&products_id=141
Polo Green 95 LT1 6-spd Chevy Corvette Upgrading as stuff wears out and/or breaks Autocross / Road / Drag in whatever class they decide to stick me in this week! 2000 CCM Group IIG Autocross Champ Member: NCCC, NCM, SCCA, NHRA, CART
07-01-2009, 3:40 PM |
Marshall Grice
Joined on 08-15-2007
Posts 147
Points 3,030
Re: new spherical Delrin pin top shock mounts
Why wouldn't you just use a spherical bearing? I believe steel on teflon has lower friction then steel on delrin does. Also likely to have less compliance then the delrin.
07-02-2009, 3:15 PM |
BrianCunningham
from Boston
Posts 977
Points 16,390
Here's his answer -----Original Message----- From: Gary Hoffman Subject: Re: responce on the SCCA post
I went through that
many SW studies ago. Without modifying the frame, it does not have
enough angular travel. Another guy sells a kit like that for $850, and
it is terrible for NVH, and has no advantages over Delrin.
07-02-2009, 8:29 PM |
TeamRX8
Joined on 04-19-2003
Posts 1,816
Points 25,680
nice, don't know why it's taken anyone this long to do it, same for a control arm bushing version  some classes don't allow metal spherical bearings and/or require the polymer/steel % ratio not to change in a replacement
07-10-2009, 9:03 AM |
Orthonormal
Joined on 08-10-2001
Sunnyvale, CA, USA
Posts 1,384
Points 19,170
I don't recall there being any such restriction in Stock for the shock bushings/bearings. I've also been wondering when someone would start selling something like this.
John S. S2000 #42as
07-11-2009, 10:35 AM |
BrianCunningham
from Boston
Posts 977
Points 16,390
I had my shocks dynoed with the new mounts Since they're setup with the C5/6 mounts for now, I had Gary test them just to see how bad the stock bushings are, be sure to watch the videos! ghoffman; here are the dyno plots for each of the vids above. Rubber  Poly (note: good curves, but it will make for very high shaft side loads)  Hardbar Delrin
07-11-2009, 10:46 PM |
TeamRX8
Posts 1,816
Points 25,680
Orthonormal:I don't recall there being any such restriction in Stock for the shock bushings/bearings. I've also been wondering when someone would start selling something like this.
Sorry I took us a bit off topic. That comment was relevant to my belief that a similar type strategy could be applied to suspension arm bushings in ST and SP where heim/spherical bearings aren't allowed. Stock, ST, and SP all allow heim/spherical bearings for shocks. Most of the spherical bearing NVH results from wearing and becoming sloppy. This is usually more due to using a bearing too small for the load or using a cheap bearing over a quality one since the quality one can cost 3x - 4x more. The benefit to this delrin setup is you can tighten it up as it wears, otherwise it will get NVH too if not maintained. A worn/noisy/vibrating spherical bearing has to be replaced in whole, no way around it.
07-14-2009, 10:34 PM |
G1
Joined on 03-06-2001
Raleigh NC USA
Posts 975
Points 16,605
Are these legal in stock class?
TEAM DYNAMICS
03 GSL, 05 HSL Nat Champ AS 07 Solstice GXP
07-15-2009, 6:22 AM |
marka
Joined on 03-14-2001
Poland, OH
Posts 2,066
Points 32,030
Howdy, TeamRX8: Orthonormal:I don't recall there being any such restriction in Stock for the shock bushings/bearings. I've also been wondering when someone would start selling something like this.
Except that SP rules don't allow that... 15.8.C says in part: Suspension bushings may be replaced with bushings of any materials (except metal) as long as they fit in the original location. Offset bushings may be used. In a replacement bushing the amount of metal relative to the amount of non-metallic material may not be increased. This does not authorize a change in type of bushing (for example ball and socket replacing a cylindrical bushing), or use of a bushing with an angled hole whose direction differs from that of the original bushing. If the Stock bushing accommodated multi-axis motion via compliance of the component material(s), the replacement bushing may not be changed to accommodate such motion via change in bushing type, for example to a spherical bearing or similar component involving internal moving parts. Personally, I think that'd dumb. I'd 100% prefer allowing spherical bearings for suspension bushings in SP. I think that even more so if a stupid product like this, which exists only because some people are scared of spherical bearings, is deemed legal. Mark
07-15-2009, 1:56 PM |
G1
Raleigh NC USA
Posts 975
Points 16,605
marka:
TeamRX8:
Well if they aren't legal in SP they certainly must not be legal in stock.
TEAM DYNAMICS 03 GSL, 05 HSL Nat Champ AS 07 Solstice GXP
