class??
Last post 06-25-2009, 11:48 PM by Speed Raycer. 3 replies.
  •  06-25-2009, 11:54 AM 366655
    class??
    Im Interested In racing at Gateway St. louis coming up but had a few questions.. Im not sure what class my car would be in, Its A 96 Trans Am 6 speed manual, ecms been reprogramed, camed, sway bars, strut tower brace, sub frame conectors, exhast.. anyone have any idea what class i would be in?? Thanks!
  •  06-25-2009, 12:05 PM 366658 in reply to 366655
    Re: class??
    I believe the non-stock cams put you in Street Modified.  Everything else I believe is Street Prepared legal where you would be ESP.
  •  06-25-2009, 1:25 PM 366675 in reply to 366658
    Re: class??
    Here is the rule concerning the sub-frame connectors in Street Prepared and Street Modified:
    E. Longitudinal (fore-aft) subframe connectors (“SFCs”) are permit-
    ted with the following restrictions:
    1. They must only connect previously unconnected boxed frame
    rails on unibody vehicles.
    2. Each SFC must attach at no more than three points on the
    unibody (e.g. front, rear, and one point in between such as a
    seat mount brace or rocker box brace).
    3. SFCs must be bolted or welded, but welding must be to the
    OE subframe stampings, not to the floor pan in between.
    4. No cutting of OE subframes or floorpan stampings is permit-
    ted. Drilling is permitted for mounting bolts only.
    5. No cross-car/lateral/triangulated connections directly be-
    tween the driver’s side and passenger’s side SFCs are permit-
    ted. Connections to OE components such as tunnel braces or
    closure panels via bolts are allowed and count as the third
    point of attachment. No alteration to the OE components is
    permitted.
    6. SFCs may not be used to attach other components (including
    but not limited to torque arm front mounts or driveshaft
    loops) and may serve no other purpose.
    With the cam, you are in Street Modified.  If the sub-frame connectors do not meet the above rules, you are in C Prepared or E Modified.
    2002 Mercedes C230k, retired, 2005 Nationals STU DFL
    1969 Beach Solo Vee and 1985 Lynx B Solo Vee
  •  06-25-2009, 11:48 PM 366758 in reply to 366675
    Re: class??
    So... if the SFC's are installed with any real thought,you play with the Big Dogs? That'd suck Sad
    Lynn:
    permitted.
    Scott Rhea
    It's not what you build...
    it's how you build it
    Izzy's Custom Cages
