Need tech guy help!!! Seat Mounting.... ITS Integra
Last post 06-05-2009, 9:03 AM by vbspec. 0 replies.
  •  06-05-2009, 9:03 AM 364122
    I'm having second thoughts on how I'm going to remount my seat lower in a car I just picked up (which was an SSB can and because of that the cge is a little low).
    Here are some pics:
    And here is why its all a problem  (that and and the fact I'm 6'2")
    Pics 3 and 4 are what I'm dealing with (inner mount).  I had to cut out the bottom seat bar that the shown seat bracket was bolted to.  My question is can I use peices of angle stock to mount the seat.  What I mean is for the front mount can mount the angle with one side laying flat on the top of the tunnel and the other connecting to the weld plate from the origional seat mount setup.  And for the rear can I use a shorter angle that will mount to a plate that will be welded from the floor pan 1/2 way up the tunnel.  To these angles I will be using these mount plates.
    I'll try to get some updated pics later tonight if needed.
    Thanx so much for the help..
    1988 CRX Si........ mucho funo
