New York ProSolo Sound level Data
Last post 09-23-2008, 12:03 PM by Sean O'Gorman. 13 replies.
  •  08-12-2008, 9:22 AM 315044
    Here is the sound level data from the New York ProSolo. Some of the sheets were hard to read and hard to understand and a couple of workers didn't get every car so as you can tell in the data not every car has all of their runs in it.
    http://www.sccabb.com/sccabc/uploads/bharmer/2008-08-11_154127_2008_Seneca_PS_Sound_Level.xls
    Brian Harmer
    SCCA Solo Technical Specialist
    Solo National Rules: http://www.scca.com/documents/Solo_Rules/2010_scca_solo_rules.pdf
  •  08-12-2008, 11:06 AM 315066 in reply to 315044
    Re: New York ProSolo Sound level Data
    Running without mufflers was allowed.  I had no muffler for that event.
    Jim
    "Those are my principles, and if you don't like them ... well, I have others." -Groucho Marx
  •  08-12-2008, 4:37 PM 315158 in reply to 315044
    do you happen to know the what distance these readings were taken from?
    Scott
    #187 ES
    95R Miata
    07 Mazdaspeed 3 (for sale!)
  •  08-12-2008, 4:39 PM 315162 in reply to 315158
    The mic was setup to how it is specified on page 258-259 in the 2008 Solo Rules.
    "Measurement will be taken at a point on course where the car can reasonably be expected to be at full throttle, under load, and at high RPM."
    "The measuring point will be 50 ft from the edge of the course lane, using a coned gate as a reference."
    "The meter will be mounted on a tripod, 3-4 feet above ground level."
    "The meter will be positioned perpendicular to the vehicle's direction of travel."
    Brian Harmer
  •  08-12-2008, 5:10 PM 315174 in reply to 315162
    Was the mic repositioned for Sunday's runs?  Or would different readings be due to weather conditions or something.  It seems for many cars the readings were higher by as much as 10 db.  I know we didn't change anything on our car.
    Mike Snyder (little)
    STS 177 (pros)
    SMF 142 (locals)
  •  08-12-2008, 5:19 PM 315177 in reply to 315174
    fastford16:
    I don't beleive the mic was moved but a lot of things can be a factor in the change. The biggest would be weather but also factor in that sunday was runs 7-9 for everyone which meant they knew the course better and so they were able to give it better drive through it. That means on the gas more which also mean higher RPM and different sound level. Many things could be a factor in the differences.
    Brian Harmer
  •  08-14-2008, 11:01 AM 315549 in reply to 315177
    That's interesting...
    A C5 Z06 without mufflers was recorded at 95db, while a C6 Z51 with stock mufflers was recorded at 92db....
    I'm not sure that any measurement technique is going to be very consistant or useful.  On Sunday the dbs seemed to be 10db higher.
    Ted
    2003 C5 AE Coupe AS
    2004 Z16/Z06 SS
  •  08-15-2008, 2:16 PM 315888 in reply to 315549
    The readings are interesting. My car (FMod #96) registered 104-106db at the NY Pro. Readings are regularly taken at all roadraces and my car has never been recorded over 98db.
    -Jeff Blumenthal
    - Jeff Blumenthal
    FMod #96
  •  08-15-2008, 2:43 PM 315903 in reply to 315044
    • Stan is not online. Last active: 03/13/2010, 5:57 AM Stan
    • Top 150 Contributor
    • Joined on 10-28-2002
    • Ridgefield, CT USA
    • Posts 504
    • Points 7,150
    Maybe the sound level meter was inadvertently set to an incorrect mode?  Such as using the wrong weighting.  Normally the A Scale should be used.  Here is a graph indicating weightings...as you can see that alone could easily lead to a 10dB change while the cars/driving stayed constant:
  •  08-15-2008, 5:43 PM 315958 in reply to 315177
    • MXS is not online. Last active: 03-10-2010, 9:17 PM MXS
    • Not Ranked
    • Joined on 01-18-2007
    • Rochester, NY
    • Posts 42
    • Points 575
    bharmer:
    I think it was out in the middle of the course Saturday, and closer to the finish on Sunday. Maybe someone who was working sound (or course in that area) can confirm? I tried to gather photographic evidence but it is somewhat inconclusive. Geeked
    Saturday mid-course (see tripod in background)
    Sunday, same general area, though it could be cut off
    Saturday near the finish, no tripod in background
    Sunday, tripod near finish (caution, huge pic)
    Marnie // 99 Civic // 97 Legacy // 90 CRX Si // #116 // Finger Lakes Region SCCA
  •  08-15-2008, 6:01 PM 315962 in reply to 315888
    solo2racer14:
    -Jeff Blumenthal
    Likely a matter of distance.
  •  08-15-2008, 7:11 PM 315975 in reply to 315962
    • Posts 504
    • Points 7,150
    ChrisFranson:
    solo2racer14:
    -Jeff Blumenthal
    Well in the absence of reflecting surfaces such as a huge cement building very nearby sound tends to diminish with distance fairly predictably.  Of course some frequencies can travel further (lower freqs) but an 8 dB change as noted seems pretty large.  Maybe one reading involved training...brief sounds such as a tire screech, fender liner rub, blowoff valve whoosh are allowed to go over the limit per the rules IIRC and that is fine.  Maybe a time weighting filter besides the frequency filters would reduce the need for training and the subsequent inexplicably different readings.
  •  08-18-2008, 12:34 PM 316230 in reply to 315177
    bharmer:
    fastford16:
    My Sunday runs were not substantially faster than my Saturday runs, yet my db readings were way higher on Sunday.  So I'm not buying the "know the course better" explanation.  I can even produce datalogs which back that up, with speeds and acceleration rates.
    Since there appears to be photographic evidence that the meter was moved, this is probably a great set of data points on how the same cars can produce very different results depending on location of meter.  IMO, I'm glad to see that this kind of data is being looked at.  Any sort of policy based on this type of metering needs to take into consideration such variation.  Otherwise, plenty of cars that might be perfectly within limits on Day One, might be over the limit on Day Two, without changing a thing on their car.  Nobody likes surprises.
  •  09-23-2008, 12:03 PM 322801 in reply to 315888
    solo2racer14:
    -Jeff Blumenthal
    10db was automatically added for it being an FMod. Big Smile
