BSP NEEDS TO BE FIXED! SEND A LETTER!
Last post 13 hours, 33 minutes ago by leepic. 773 replies.
05-25-2008, 7:30 AM |
Jazzie604
Joined on 05-10-2006
Posts 96
Points 1,245
Re: BSP NEEDS TO BE FIXED! SEND A LETTER!
Obivously, Im making some inflammatory remarks. And in 10 years, I cant wait until someone starts bitching about the new car that is beating up on the evo, or GXP, or whatever.
05-26-2008, 10:31 PM |
ewesch
Joined on 05-26-2005
Jacksonville, FL
Posts 11
Points 340
I don’t have an account on the NASIOC Forum so I would like to reply to Karen’s post (http://forums.nasioc.com/forums/showthread.php?t=1519051&page=5) on that forum here since it involves the BSP and AWD issue. Hi Karen…
First off, the BSP Corvette didn’t “bail” at the event. I registered for BSP only after emailing Nancy Downing about the ability to change classes at the event owing to the so surprising lack of interest in BSP. The day prior to leaving for the Atlanta Tour we received notification that the SPAC decided to leave the STI and Evo in BSP. At that time, prior to leaving, the decision to boycott the class (as did the other Corvette that registered for SM2) and move to SM2 was made. When I saw Joel at the event I spoke with him about his registration in XP and initially we both decided to run in BSP but later I decided to stick to my original decision and move to SM2 which I advised Joel of an hour or so after our initial conversation. This was not a spur of the moment decision since I had told Bill Cook of my decision to “boycott” BSP about a month and a half earlier at a Buccaneer Region meeting. My opinion is that other BSP owners, if they are dissatisfied with the SPAC’s decision, should do the same. The numbers would indicate that this may have occurred already. My guess is that this may occur in other classes with AWD cars also. It appears that the rally car crowd may wind up with AWD only classes whether they want them or not. This may have happened in BSP already. Be careful what you wish for!
The Atlanta Tour was one example of why the AWD cars should have their own class. Our Saturday runs started well after 9AM and we had to use water to maintain the two front tire temperatures below 130 degrees. On Sunday we started over an hour earlier (~8AM) and due to track and ambient temperatures/conditions I could only get one front tire up to 120 by the last run on a two driver car! Do you think an AWD car would have gained an advantage here? If not, a position on the SPAC would be in order for those individuals that can’t comprehend this. All you have to do is compare Joel’s times (from run group 3) on Saturday with 88 SM2 (run group 1) and then do the same comparison on Sunday. It was not that we felt we couldn’t compete with Gentleman Joel (and a gentleman he is) it was quite simply a political statement. Thankfully it didn’t cost Joel anything and at the most it cost us one tire. At this time we have made the decision to move to SM2, at least until sanity prevails and an AWD structure is created.
OK, I’ve got my flak jacket on so let it rip…
Ed Wesch, Sr. BSP - '92 Corvette
05-26-2008, 10:50 PM |
winchester
Joined on 06-15-2006
Posts 39
Points 355
ewesch:
Please explain the codrive situation. I see 88 and 188 in SM2. If that is the same car and is BSP prepped then the gap to Joel's BSP winning total time is in the 0.4 sec range.
As for some of the participation, I think you'll see a good amount of regional variance. For the upcoming Devens NT we have 9 drivers reg'd for BSP (albeit mostly evo's with a sprinkle of miata & sti). I know there would have been at least one M3 if he didn't have schedule conflicts with the event. There would also be another evo, but that car owner just had a baby boy last week. This is almost double what we had last year at the same event.
John
05-26-2008, 11:29 PM |
ewesch
Jacksonville, FL
Posts 11
Points 340
Yes, the 88/188 SM2 car is BSP car. I would conjecture that if our car and Joel's car had run in the same heat on BOTH days the Corvette would have prevailed although winning under ideal track conditions with experienced drivers is not the issue. The problem is when conditions are not ideal, like this past cool Sunday morning.
It is my opinion that the inclusion of AWD cars in single axle drive classes will eventually hurt membership. I would conjecture that if you took a number of inexperienced drivers and allowed them to run a course in a BSP prepped Subi / Evo and then BSP prepped Corvettes or S2000's or for that matter and single axle car these inexperienced drivers would turn their best times in Subi / Evo. You could run this little test in Stock and Street Tire classes with similar results. This means the newbie to autocross single axle drivers will be looking elsewhere to spend their time and money. How would you feel if your buddy bought an STI and you bought an S2000 and you went to an event and he waxed your butt by 3 or 4 seconds? This is just MHO of course...
The battle will go on, but with out me.
05-27-2008, 10:52 AM |
EVOlutionary
Joined on 01-15-2006
Posts 56
Points 600
ewesch:
. . .. At this time we have made the decision to move to SM2, at least until sanity prevails and an AWD structure is created.
Uhh, you don't feel you are competitive in BSP, so you move to a FASTER class? Good logic there
05-27-2008, 11:36 AM |
ewesch
Jacksonville, FL
Posts 11
Points 340
We feel that we are competitive in BSP and the ability to win the class under ideal ambient and track conditions is not the issue. Compare Joel's times with ours, 88 SM2 vs. Joels in SM. Also take the opportunity to view our times at the Dixie NT where we won BSP by a margin of 2.440 sec. We do feel Joel had a slight advantage since we ran in the first run group and were unable to get our tire temps over 120 on Sunday due to weather conditions which would have afforded us better traction ( i know this is obvious but I'm just being fair to those that may not quite understand). Joel ran in run group 3 where temperaturs where much higher. The temp issue on Sunday underscores the OBVIOUS! If Joel had been in run group 1 he would have had an advantage. Single axle drive cars are different than AWD cars. The primary reason for the development of AWD vehicles was improved traction over two wheel drive vehicles. On a wet and/or cold autocross track, with similarly experienced and qualified drivers, a 1,000 hp Corvette is not going to beat a 300 hp Evo.
We are currently developing some tests to see why certain individuals are unable to understand the AWD / 2WD concept. The first test we are proposing is a typical IQ test question where participants identify similar objects. We are suggesting photos of an STi, an Evo, an S2000 and a Honda Civic and we are going to ask automotively astute individuals to draw lines between the vehicles with the greatest similarities. We will even give them a hint by identifying them as 2WD and AWD!
Jazzie604
Posts 96
Points 1,245
EVOlutionary: ewesch:
You got it all wrong man. He's saying that its fair for him to have a FASTER car when weather is ideal for his setup, but its unfair that an Evo MIGHT have better front tire heating abilities when the weather is a little cool. He thinks that is a component of being AWD, not the fact that we have a 60% front weight bias and crappy strut design.
05-27-2008, 11:50 AM |
SpyderVenom
Joined on 01-11-2001
Southeast, PA
Posts 1,407
Points 18,765
Jazzie604: EVOlutionary: ewesch:
No, No, No. He is saying that we need a class where 15 year old technology should be faster than new technology. For example - his "BSP" Vette was beaten by AS and BS (both classes that ran in the same heat as him) with cars that are only 2 and 4 years old. Those overhead cam things and rotary engines are just confusing.
05-27-2008, 12:18 PM |
ewesch
Jacksonville, FL
Posts 11
Points 340
OK, a C4 Corvette is 15 year old technology. What does that mean? 5 of the 6 street tire classes were won by cars that are 13 to 21 years old. Somehow I'm missing the point. Do we need to wet that course down at alternate events so the AWD cars can show their stuff? We could even mix a little soap in with the water to extend their advantage.
05-27-2008, 12:21 PM |
BrianGT
Joined on 09-16-2005
Atlanta, GA
Posts 218
Points 3,335
ewesch:We feel that we are competitive in BSP and the ability to win the class under ideal ambient and track conditions is not the issue. Compare Joel's times with ours, 88 SM2 vs. Joels in SM. Also take the opportunity to view our times at the Dixie NT where we won BSP by a margin of 2.440 sec. We do feel Joel had a slight advantage since we ran in the first run group and were unable to get our tire temps over 120 on Sunday due to weather conditions which would have afforded us better traction ( i know this is obvious but I'm just being fair to those that may not quite understand). Joel ran in run group 3 where temperaturs where much higher. The temp issue on Sunday underscores the OBVIOUS! If Joel had been in run group 1 he would have had an advantage. Single axle drive cars are different than AWD cars. The primary reason for the development of AWD vehicles was improved traction over two wheel drive vehicles. On a wet and/or cold autocross track, with similarly experienced and qualified drivers, a 1,000 hp Corvette is not going to beat a 300 hp Evo.
Joel's car had issues on Saturday, so that isn't a valid comparison for Saturday vs Sunday.
You also were outpaced by AS,BS and FSP, all running in the 1st run group. Maybe you should petition to move the car to FSP? Also, if heating tires is an issue, why not run narrower tires? Top raw times by class (first column indicates where they ended up via RRTP): ( vs 109 Edward Wesch Hoosier SM2 89.314 )
89/189 STS/STX '89 Civic Si
05-27-2008, 1:02 PM |
EVOlutionary
Posts 56
Points 600
Jazzie604:
So it's a tire heating issue? So then a RWD car with a iron big block should be in a different class because they have more weight on the front and may be able to get more heat in the front tires on a cool day?
So if I put 315's on the rear of my EVO and they never get up to temp even on a 90* day then we should kick those darn BMW's out of SM!
05-27-2008, 1:07 PM |
Jazzie604
Posts 96
Points 1,245
ewesch:On a wet and/or cold autocross track, with similarly experienced and qualified drivers, a 1,000 hp Corvette is not going to beat a 300 hp Evo.
Bad example there: we all know hp has very little to do with autox. on that same track a 300hp Corvette would also beat that 1000hp corvette.
ewesch:We are currently developing some tests to see why certain individuals are unable to understand the AWD / 2WD concept.  The first test we are proposing is a typical IQ test question where participants identify similar objects. We are suggesting photos of an STi, an Evo, an S2000 and a Honda Civic and we are going to ask automotively astute individuals to draw lines between the vehicles with the greatest similarities. We will even give them a hint by identifying them as 2WD and AWD!
oh cool, I'll play this game!! the Sti and the Civic are both blue. the s2k and the civic are both hondas. hmmm, the evo and civic could be 4 doors, though the s2k and the civic could be 2 doors. The new Sti is only a 5 door, so that doesnt fit in.....
What Im getting at is its easy to setup a questionaire to get the answers you want to hear. The hard part is finding out where your thoughts end and the real, unbiased questions begin.
What really irks me is that you stated you whipped ass on the class when you had good conditions, but you're crying about cold weather. Trust me, AWD cars hurt when their tires dont get warm just like your car does. If you choose to run on the right tires for the conditions, then there will be much less disparity. Dont cry over something that you could change yourself. Or go run and hide in another class. I dont know you from Adam, and you may be the next Massa, but I always thought that a great driver trumps good cars anyday. guess you dont fall in that category.
05-27-2008, 1:44 PM |
DaveH
Joined on 09-04-2007
Posts 177
Points 3,330
ewesch:
Which is why we don't class cars based on how novices would do in them. The whole point of this argument is that the Evo and STi don't belong in ASP. Just like the Skystice, E46, M Coupes, MR2, etc. don't belong in ASP. If that means somebody in a C4 needs perfect conditions to win BSP, then it just means you have a class with course and condition dependencies like nearly every other class out there.
Dave Heinig 07 GXP Z0K (Thanks Rob!)
05-27-2008, 2:03 PM |
BrianGT
Atlanta, GA
Posts 218
Points 3,335
EVOlutionary: Jazzie604:
Yeah, Joel had 315s on the front and 275s on the rear IIRC. -Brian
05-27-2008, 2:29 PM |
BigB
Joined on 03-15-2005
ATL, GA
Posts 183
Points 2,815
So it has nothing to do with the 3 cone slalom I was watching/taking pics of your runs at and you both screwed up that section each and every run both days? It's more about having the optimum conditions to be fast?
Brian Cembor It's like a koala bear crapped a rainbow in my brain! 25 STS 1989 Civic Si
05-27-2008, 5:26 PM |
thunderbird
Joined on 10-04-2006
Posts 114
Points 1,730
ewesch:
We are currently developing a test to see why certain individuals are unable to stand competition. The first test we are proposing is a typical share-the-toy test to see whether they can play nice with strangers.
lamoureaux BSP 2004 STi Wichita, Ks
05-27-2008, 6:25 PM |
slowSER
Joined on 12-29-2000
SoBWI
Posts 545
Points 7,395
slowSER:
Combined ASP/BSP results from the last two years at Nationals
John Tak, Evo 99.567
Michael Johnson, Z06 99.825
Tage Evanson, Evo 100.353
Chris Cox, GT2, 100.579
Harold Olsen, C4 Vette 100.790
Andrew Lieber, Evo 100.841
James Gunn-Wilkinson, GT3 101.053
Lee Piccione, E36 M3 101.286
Rod McGeorge, C6 Z06 101.061
Scotty White, Viper 101.366
Rob Boynton, GT2 101.928
Jason Tipple, S2000 101.969
Brian Hair, E46 M3 102.109
Jason Uyeda, S2000 102.937
Justin Rothermel, STi 103.674
Mike Johnson, C5 Z06 87.505
Tom Berry, Evo 87.572
Geoff Newman, GT2 89.115
Harold Olsen, C4 Vette 89.054
Marshall Grice, Evo 89.152
Aaron Miller, Evo 89.270
Michael Wootton 89.321
Rod McGeorge, C6 Z06 89.412
Steve O’Blenes, Elise 89.579
Jason Uyeda, S2000 89.635
Rob Boynton, GT2 89.679
Tommy Pulliam, C5 Z06 90.287
Randy Chase, Elise 90.796
Just bringing this back to the top since we're comparing results from past events.
Pat
'92 Sentra SE-R, daily driver and track car '82 Camaro Z28, ESP, 65% prepared, 50% ownership Upset about Stock class proposals? Get PISST!
