Passenger a plus?
Last post 07-07-2008, 4:48 PM by Bill Sims. 16 replies.
06-23-2008, 3:18 PM |
OverDrive418
Joined on 05-11-2008
Posts 11
Points 220
I've been running my Civic in FSP for a few months now and a strange thing seems to be happening. It seems that when I have a passenger in the car my times have greatly improved over just flying solo. The best times are when a person closer to my weight is in the car with me.
My theory is that even though it is added weight the weight is evenly distributed making the car more predictable and easier to carve through the corners.
I do not have coil-overs, but from what I have read you can get your car corner-balanced to make the weight evenly distributed if you have coilover suspension.
Has anyone had the same experience as me or am I crazy? Does the corner balancing idea make sense to correct this? What can I do in the meantime since I don't have coilovers?
06-23-2008, 5:27 PM |
06-24-2008, 12:07 PM |
06-24-2008, 3:45 PM |
06-25-2008, 10:44 AM |
Jim G
Joined on 12-15-2005
Posts 376
Points 4,055
When I was competing in stock category, there were some courses on which having a passenger improved my times.
If there were a number of important right hand corners, having the weight of a passenger on the right side of the car definitely helped. It wasn't just my times that improved ... the car felt faster in those particular corners. It was sometimes very striking. And if there were enough right handers, or if the few that were there were important enough, it was enough to overcome the disadvantage of the extra weight.
It wasn't a question of my coming up with the theory and then emotionally convincing myself that it worked. Each time it happened, the passenger was along only because it was a fun run, not because I was experimenting. I felt the difference and looked at my times.
Jim Garry
06-26-2008, 9:50 AM |
Joe_914
Joined on 12-05-2005
Gulf Coast
Posts 540
Points 2,985
After my last suspension re-do I haven't corner balnaced to car. I just set it level all the way around. Good enough for dinkin around at regional events. However I was at a test and tune and was taking measurements and had my friend sit in the driver seat. Car suspension compressed almost 1/4" on left side. He got out and it went back up.
Got the cute 100 girl to sit in passenger seat, almost the same result.
It was like a light bulb dimly lit over my head. I was setting the car up even side to side and also experienced quicker times with a small passenger. Now my car is 1/4" higher on driver side empty. We will see what happens now.
So can this be a coincidence ? I think not.
06-26-2008, 10:17 AM |
DaveH
Joined on 09-04-2007
Posts 177
Points 3,315
I usually get the shop to let me sit in the driver's seat for alignments.
Just remember, on course your suspension is never at its resting position, so that 1/4" difference may not be doing that much. Alignment changes, especially cross camber and toe changes can have an effect. For myself, I've noticed that I can feel the extra weight with a passenger. The car may turn left a little better, but the transitions are just a little slower and I can feel the extra mass dragging the car around. Of course the person who's usually in the passenger seat is my car owner, who isn't exactly a cute 100-lb girl...
Dave Heinig 07 GXP Z0K (Thanks Rob!)
06-27-2008, 8:25 PM |
06-28-2008, 8:56 AM |
CivicSiRacer
Joined on 02-20-2001
Landisville, PA
Posts 637
Points 10,160
I agree. It's something in your head not with the car.
Usually it's because you are A) showing off so driving more aggressively, or B) you are more relaxed so you drive smoother trying to show your passenger how to do this right :)
KAM Racing Sports, Falken Tires, Progress Technology, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO! Buy my Civic parts!
06-28-2008, 9:33 AM |
Jim G
Posts 376
Points 4,055
Or ... you can actually feel changes to the car. I've had a good bit of success autocrossing over the years and yes indeed I can feel the change. And like I wrote in an earlier post on this thread, given certain course situations, it can yield an improvement to ones times. Jim
Jim Garry
06-28-2008, 10:07 AM |
Lynn
Joined on 11-30-2004
Saint Louis
Posts 1,554
Points 13,970
If it's in the driver's head, there are a hell of a lot of circle track racers that need to be told that the location of the weight in the car doesn't matter. They spend a lot of time and money getting as much weight on the left side of the car as the rules allow. And those morons actually move the weight to the right when they use the same cars on a road course. What a bunch of fools doing all that work.
My Mercedes turns left much, much better than it turns right. The difference is so great several magazines commented on it in their test reports. Adding a passenger on a course with mostly right turns, especially sweepers, cuts the time considerably. Adding a passenger on a course with mostly left turns, increases time considerably. I can't tell you how a passenger affects the solo vees because the passengers keep falling off.
2002 Mercedes C230k, retired, 2005 Nationals STU DFL 1969 Beach Solo Vee and 1985 Lynx B Solo Vee
06-28-2008, 6:32 PM |
06-28-2008, 7:29 PM |
kakarot
Joined on 06-25-2008
Posts 7
Points 95
Captain Ron:i have heard that every 100lbs. will add a tenth of a second to your quarter mile time.
On a drag strip. Auto cross and road racing and alike 100lb effect more that that. I believe largest effect of a passenger is the physiological change in the drivers. I drive smother with a passenger, that alone. Because I feel responsible for the passenger.
06-28-2008, 9:31 PM |
Glenn L. Austin
Joined on 06-20-2001
Snoqualmie, WA, USA
Posts 591
Points 7,585
kakarot: Captain Ron:i have heard that every 100lbs. will add a tenth of a second to your quarter mile time.
You brake a fraction of a second earlier and a touch lighter (smoother), turn a bit earlier and slower (smoother), get on the throttle earlier and smoother. Add to that the fact that your passenger makes your car closer to its alignment settings (unless you align with something in the driver's seat), and the car is better as well.
Glenn L. Austin, Computer Wizard and Race Car Driver 2005 Ultra Yellow Nissan 350Z Track Model 2007 Packwood ProSolo "first loser" (0.081) 2007 SCCA Solo National Championships - 10th place
07-02-2008, 9:09 AM |
Surferjer
Joined on 09-17-2004
East Coast
Posts 705
Points 6,900
Down in Atlanta both Robert Carpenter and I saw slower times in the TNT with each other as passengers, as much as 3-5 tenths on a 18 second course. we took a lot of runs, so I'm convinced it's a bad thing.
But my biggest problem is having a passenger for the first three runs of a meet, then for the money run I kick them out and the car handles differently than what I'm used to without the weight and I f up the run. I should probably go without a passenger more, but it's hard to kick 120 pound women out.
Jer #196 ES #187 SS retired
07-07-2008, 4:48 PM |
