atcovan:
Dick Rasmussen:
"Too much oil will result in overheating due to oil being squeezed out the end of the gear teeth."
Huh? Does this cause foaming?
It may. I work with non-automotive gearboxes and in our experience foaming can go away with more oil or less oil.
Too much oil is definitely a problem because it causes churning - excess energy being put into mixing the oil. I would guess the comment above refers to having oil immersing the gear teeth contact region, where the design is to have the oil below that and the spinning gear dips into the oil and carries a film of lubricant through the contact region.
Whether it's churning or foaming, you'll see increased temps and more lost power.
Dave
