August 3rd at the Fort Wayne Coliseum event(Event Master Chuck McMillion)
Last post 08-11-2008, 3:18 PM by Peppler33CS. 49 replies.
06-24-2008, 12:18 PM |
chriskrumnow
Joined on 01-02-2008
Fort Wayne
Posts 47
Points 1,160
Here is a link to Myautoevents.com!
http://www.myautoevents.com/pls/mae/frmEventDetail.Show?psevent_id=8700
What are the plans for the event?
What are the plans for the course?
"It is common sense to take a method and try it. If it fails, admit it frankly and try another. But above all try something." FDR '87 Pontiac Fiero '08 Saturn Astra XR '93 Eagle Talon SE ckrumnow@hotmail.com 260-460-7289
06-24-2008, 8:33 PM |
wrheadle
Joined on 12-04-2005
Fort Wayne, IN
Posts 77
Points 1,445
Re: August 3rd at the Fort Wayne Coliseum event(Event Master Chuck McMillion)
Possibly speaking out of turn on Chuck but...
Current plan is to have 2 courses (well, one course, but run in both directions). The morning heats would take 3 runs on the course in one direction, break for lunch for say 20-30 minutes to allow for moving the start and finish, altering a couple of spots, and walking the course in the opposite direction. I have included the course maps below for your review. The best time in each direction would be combined for an event winner.
Blue dots are cones, lines are course edges and slaloms are shown as crisscrossing curves. Both slaloms on the course are optional entry side. Small red boxes are drain grates, red dots are light poles, large red squares are high-tension power poles, and the long red rectangle in the lower right is a guard rail. White box is timing and yellow box is equipment truck.
Morning course starts east (bottom) center by baseball stadium and finishes along south (left) end of lot
Afternoon course reverses start and finish locations, with the cool down lane added as course at the start. There are two modifications to the body of the course, one as you enter the northern (right) half of the course to change the brake zone after the sweeper, and the kink around the light pole (near afternoon course finish) is removed.
Thoughts?
Bill
Bill Headlee 1970 Boss 302 CP car DONE!Writeup in Ford Builder magazine
06-24-2008, 11:11 PM |
slowmod2
Joined on 02-02-2008
Posts 13
Points 405
course looks good.
there are only two possible concerns that i see:
With the morning course: if your coming out of that slalom with any speed the pole at the finish might be close.
afternoon course: after you come out of the two sweepers there is a small straight away with a pole at the end.
Hope I'm not being to critical, I would just hate to loose another site.
06-24-2008, 11:20 PM |
wrheadle
Fort Wayne, IN
Posts 77
Points 1,445
Paddock is cropped off of the bottom of the image (it will be next to the ball park) and the grids are between the start and finish. The red line on the west (top) of the course is a temporary concrete barrier that will be in place when we get there. The access road that I have drawn in on the south (left) end is the controlled access (waiver) access. Scott and I spent nearly 2 hours on the parking lot laying out the courses. We should be fine on distances.
As a side note, "both feet in" only works when it has a clutch, and the incident you refer to did not have that option. We can talk all we want, but instinct and pre-programmed responses will take over in that type of situation, regardless of what you tell them in the driver's meeting. Besides, its not like that incident was a rookie driver error... It was mechanical failure with a relatively experienced competitor. Some things just happen, thus the term "accident".
BTW- I'm not a SSS.
Bill
06-24-2008, 11:24 PM |
wrheadle
Fort Wayne, IN
Posts 77
Points 1,445
slowmod2: With the morning course: if your coming out of that slalom with any speed the pole at the finish might be close.
That was moved to address that issue. The map is for direction, not scale distances.
slowmod2: afternoon course: after you come out of the two sweepers there is a small straight away with a pole at the end.
Don't see where you are referencing. More detail please.
Bill
06-25-2008, 8:48 AM |
JPMRacing26
Joined on 03-20-2008
Posts 181
Points 2,690
Thanks Chris for the updates! I am working on the flyer this week. Should have it all ready for Chuck for him to submit Monday for advertising. It will look killer! Chris, One thing, anything new I may need to have on the flyer for info? I have the usual... Just want to be sure it is all there! Please email me the details, Thanks!
06-25-2008, 8:37 PM |
chriskrumnow
Fort Wayne
Posts 47
Points 1,160
Honestly there really have not been any updates other than opening registration for the next three events. If you want to know, I did the sanction and insurance about a month ago. Other than that it is supposed to be the Event Master's gig. I'm trying to give them as much space as possible. I do need to know what else to request from the colliseum. I want to meet with them a week or two before the event to go over details again.
The cement barrier are give us a little more room than the picture shows. The barriers will continue the guardrail all the way across the parking lot. Scott and Bill are correct that there is not enough room between the cement wall and the light poles to put the course anyway. As there is only about 40 ft between them.
06-25-2008, 8:41 PM |
chriskrumnow
Fort Wayne
Posts 47
Points 1,160
Seeing all that room reminds me that 97hp is just not enough hp! I really need to put a small block in the fiero!
HEHEHEHEHEHE!!
06-25-2008, 10:36 PM |
wrheadle
Fort Wayne, IN
Posts 77
Points 1,445
chriskrumnow:I do need to know what else to request from the colliseum. I want to meet with them a week or two before the event to go over details again.
The chance to mark cones a day or two before the event. Won't leave anything set up, just leave chalk marks on the ground to save time...
chriskrumnow:The cement barrier are give us a little more room than the picture shows. The barriers will continue the guardrail all the way across the parking lot. Scott and Bill are correct that there is not enough room between the cement wall and the light poles to put the course anyway. As there is only about 40 ft between them.
Based on our visit a few weeks ago, the reconstruction of the Coliseum Blvd entrance has moved the guard rail to just about where I have shown the red line. The Google maps screen capture that the maps are drawn on above is the old layout, not the new.
Bill
06-26-2008, 2:44 PM |
JPMRacing26
Posts 181
Points 2,690
chriskrumnow:Seeing all that room reminds me that 97hp is just not enough hp! I really need to put a small block in the fiero!
HEHEHEHEHEHE!!
You would still be slow. Chuck, Chris, and Steve... check your email for the Flyer. This should be ready to go!
07-10-2008, 4:41 PM |
bmonnin1
Joined on 01-23-2008
Posts 40
Points 885
Kyle,
I just got my class and training for SSS finished (and signed off) at the GASS event in Columbus and I will be at this event so there is one more SSS you can add to the list. Also if you think we need vest or hats you can buy green hats that say you are a SSS from SCCA but they are not very cheap. A single hat cost $18 if you purchase them as a single member, $14 if you purchase them with the region's account. I do agree that you need to have something like that for the SSS though.
Bart Monnin
Bart Monnin 1999 BMW Z3 Roadster 2.8 ASP 24 bmonnin1@roadrunner.com
07-15-2008, 5:33 PM |
Dasmopar
Joined on 04-28-2008
Posts 112
Points 1,925
We are trying to get a small group of NWOR folks to come out and kick all your butts. So make sure it's a good 400FWD hp course would ya? Lots of long straights but not to long as down shifting to 2nd gear can be tough for me. No drag race type starts as that favors the AWD Chuck cars.
Hope to see you all there
Lon
2005 Neon SRT-4 ACR White. #6 SM Fresh of the dealer lot 2008 Solstice GXP #6 AS
07-17-2008, 2:30 PM |
Garold Shaffer
Joined on 05-04-2007
Posts 5
Points 110
Hey guys, Garold Shaffer INR RE. A few of us will be there also. I'm also a SSS so if you need more help I am willing.
It looks like your event will be the unvailing of my new (too me) AX weapon. The wife & I plan to come down the night before and get a hotel room. I used to live in FT Wayne, but its been 22yrs so I know things have changed. Is there any hotel close by the Coliseum that you would recommend? I will have my car on an open trailer so I am looking some place well lit and safe. Spent all my "mad money" getting the car ready that I don't have enough for a enclosed trailer yet :-( It's also a open car (no roof) so just a few concerns there also.
Thanks!
Garold Shaffer 70 914 2.0 SCCA #70 SM2 74 914 2.4 /6 SCCA #64 XP (aka Moby) Wana be racer Indiana Northwest Region www.inr-scca.org "The most important go fast part of any car is the driver"
07-17-2008, 2:44 PM |
JPMRacing26
Posts 181
Points 2,690
Give me an email - I can hook you up! We have a family B&B and you could park the trailer at my house :) jasonpmassey@gmail.com 260-744-2261 ext 124 is my wrk number :) LET talk! Garold Shaffer:Hey guys, Garold Shaffer INR RE. A few of us will be there also. I'm also a SSS so if you need more help I am willing.
Thanks!
07-17-2008, 3:12 PM |
JPMRacing26
Posts 181
Points 2,690
Also, if you email me your phone number, I can call you from the B&B and work some stuff out. We have room in one suite and a couple rooms ava. upstairs. Would love to help you out! Cheers, Jason Massey
07-17-2008, 4:17 PM |
sts38
Joined on 11-14-2007
Fort Wayne, IN
Posts 54
Points 1,195
The event will be right in the heart of Ft. Wayne.....hotel options are endless.
Anything on Coliseum, Coldwater, Lima, or Washington Cntr should work just fine.
The Super 8 on Coliseum is less than a block away.
07-17-2008, 4:51 PM |
Page 1 of 3 (50 items)
1
