Mid Ohio SSB/C Results?
Last post 06-07-2008, 4:07 PM by JTIPPENS. 16 replies.
06-02-2008, 11:04 AM |
06-03-2008, 5:23 PM |
911Carrera
Joined on 07-13-2004
Royal Oak, MI
Posts 30
Points 265
Re: Mid Ohio SSB/C Results?
I don't know all the names, drivers etc but I did watch the race. From Memory..
SSB
Civic SI (black) believe Chad Gillsinger
Civic SI (blue) ????? (HART car)
Mini Ralph Porter
Mini John Start
Don't know if there were any other SSB cars. Start didnt' finish race
SSC
Civic (black) Roger Shoerer?
Escort ZXS Dick Ruhl or guy that races with him
Neon 4d ?????
Sorry that I don't have much more accurate information. As a SRF driver, I like to watch the AS/T1/T2/SSB/SSC/SM races, however the names, faces and cars have changed so much in the last couple of years. Remember the days of Fernandez, Heuschele, Grahovic, Dan Waleki and Ryan C
06-04-2008, 12:29 PM |
JTIPPENS
Joined on 03-02-2001
Posts 806
Points 9,035
Thanks for the link. Any idea why Ralph and Jonathan were not close in their Minis? That huge gap shouldn't normally happen.
Jack SSB Z4 #09
06-04-2008, 2:23 PM |
twin_turborx7
Joined on 01-09-2001
Marietta, GA, USA
Posts 996
Points 11,855
JTIPPENS:Thanks for the link. Any idea why Ralph and Jonathan were not close in their Minis? That huge gap shouldn't normally happen.
Because with the recent BOD combine T3/SSB/SSC they are trying to land in SSC ;) Sorry had to and I am just kidding.
06-04-2008, 3:21 PM |
BAD PNY
Joined on 04-12-2005
Manheim, Pa
Posts 120
Points 1,015
Since the Solstice can't run in T3 that leaves SSC for me. Tim we will have fun next year. I figure with a 185/40/18 I should fit right in.
Mike Scornavacchi #25 SSB Solstice Hoosier, Phoenix, Carbotech, Lawrence Chevrolet, www.TrackTapes.com
06-04-2008, 5:40 PM |
twin_turborx7
Marietta, GA, USA
Posts 996
Points 11,855
BAD PNY:
Now that would be good times :)
06-04-2008, 6:44 PM |
JTIPPENS
Posts 806
Points 9,035
twin_turborx7: BAD PNY:
No, no, no, Mike "Scorch-the-tracki," something more along the lines of 165/55X16 would be more appropriate--no more low profile if you drop to SSC! Why would they drop you to SSC anyway, you're at the pointy end of SSB! Hey, don't you like the idea of trying to keep up with S2000s with only 60 some hp less? Sounds like a real drivers' challenge to me (tongue planted firmly in my cheek). Seriously, how much weight could you get out of the Solstice if they moved you up? It would take an incredible effort to match power/weight with the T3 cars, I'd think. I know that the Z4 2.5 just can't cut that much weight without methods that aren't "approved" for competition. This directive is going to be a tough, tough row to hoe, folks! Not the worst part of it is that SSB is leading the SS/T groups in entries this year, so why chop it up?
Jack SSB Z4 #09
06-04-2008, 9:10 PM |
BAD PNY
Manheim, Pa
Posts 120
Points 1,015
Jack
There is no way that the Solstice could compete without major hp improvements. Handling is not the issue. Unless we could dial up an addtional 25 ponies and get rid of some weight we would be dead. We could not get rid of enough weight to compete in T3 alone.
It is bad enough in B with the Honda way to quick already. I really can't wait until you guys get a good dose of that V TEC at the June sprints.
See ya in Kansas
06-04-2008, 10:25 PM |
lniff42
Joined on 07-24-2003
Delaware, OH
Posts 112
Points 1,440
I didn't race, but I'm trying to figure that one out as well. At both Fontana in January and at VIR in April, the Civic and Mini were neck and neck. I won and set the track record at Fontana over the Brecht boys but only by a tenth. At VIR, Chad won over Robbie Davis, but Davis got the track record and was on his rear the entire race.
Honda/BF Goodrich/ Cobalt Friction/AEM/Traqmate
06-05-2008, 12:31 AM |
qasteve
Joined on 04-16-2003
Pelham, NH USA
Posts 251
Points 2,905
BAD PNY:Since the Solstice can't run in T3
Not sure why you so definitive. At the NH national a Sol was within 1 sec of the previous year T3 time. 1 second is certainly less than how badly the Sol has been beating up on most of the B field for the past two years.
06-05-2008, 2:43 AM |
JTIPPENS
Posts 806
Points 9,035
BAD PNY:Jack
See ya in Kansas
Mike, I realize that you are closer to the limit of your car because of what has already been put into it. T3 does not seem reasonable for the ZOK. Sooner or later, a T3 car has to have a decent amount of power.
As for V Tech motors, I have raced Integras with the V Tech and think that it is wonderful stuff. When that motor hits 5300---Broooooooooooomm! It feels like a good substantial 6 cylinder going to work. The current Civic Si has to be a delight to drive when that thing lights up. The Z4 might be able to keep up with it a bit more without a restrictor, but has to do all the work elsewhere with the 51mm we are stuck with. The Hondas stand to be very, very well placed in the Road America Runoffs. The Minis might be stronger than we imagine, too. They really haul the mail out of the RA corners and get well out from the Z4s until up around 110mph, then we slowly claw a little back on the top end (Minis are bricks). The Hondas are simply gone by then. I expect the Sprints lap record to drop by a second or two, minimum.
Since I've not been able to race yet this season, I am eager to see the new balance within the SSB class--it looks better, but some tracks are still perfect for some of the cars.
Jack SSB Z4 #09
06-05-2008, 2:48 AM |
JTIPPENS
Posts 806
Points 9,035
qasteve: BAD PNY:Since the Solstice can't run in T3
I don't think that the Solstice will be able to hold with the Civics at Road America. We'll really see just how strong the Vtech is this year at the Sprints, unless the weather doesn't cooperate. Watch the Acura, too. The rest of us might be chopped liver there.
Jack SSB Z4 #09
06-05-2008, 8:33 AM |
BAD PNY
Manheim, Pa
Posts 120
Points 1,015
Steve
I am definitive because I have run on all kinds of tracks with this car against everything out there in B and T3. I am pretty sure where we are strong and where we are weak. NH is a good example of where we are strong. (unlike some people who race little and talk alot )
I hope Lee brings the Civic to Pocono & WGI since he is in the NE.
Best of Luck
06-05-2008, 2:54 PM |
qasteve
Pelham, NH USA
Posts 251
Points 2,905
Maybe I don't articulate my point clearly or maybe you'll just refute everything I say no matter what the topic. You said the Sol CAN'T run T3. It CAN run T3 but not at the front every race and not a podium at the Runoffs. I don't see a problem with that happening if it makes the best sense to the club overall. If you had said the Sol can't run up front in T3 and can't win the Runoffs in T3 then I would have never said a word. Let's just call a spade and spade.
What will be interesting to me is to see what happens if hypothetically consolidation happens. Will guys like you stick around and run mid-pack T3 or bail and find the next COY or NASA or whatever everyone threatens. I know I would stay no matter where my car goes because I am out there to have fun.
06-07-2008, 9:29 AM |
SSCRacer
Joined on 01-09-2005
Charleston, SC
Posts 445
Points 4,530
The MINI is a "brick?" That's a little harsh, after all it has the same coefficient as the BMW X5! My proposal for the Solstice and the Honda SI is to mount a 4X8 sheet of plywood to the front of their cars!
I'm glad the Board has again backed up on a bad decision. The competition in both showroom classes looks as even as it has been in several years. Each car has it's own strong points and weak points and accordingly good tracks and bad tracks. Watch a NASCAR race with the COT race cars and see how their attempt to equal the playing field has created rotten races.
Brad
06-07-2008, 4:07 PM |
JTIPPENS
Posts 806
Points 9,035
SSCRacer:The MINI is a "brick?" That's a little harsh, after all it has the same coefficient as the BMW X5! My proposal for the Solstice and the Honda SI is to mount a 4X8 sheet of plywood to the front of their cars!
Brad
Brad, A 4'X8' plywood panel? That's a bit extreme, isn't it? I'd be happy with a 4'X4' penalty!!
Jack SSB Z4 #09
