Atlanta Pro Solo Index Results
Last post 05-20-2008, 5:15 AM by rtp.rick. 16 replies.
05-19-2008, 10:51 AM |
Renspeed
Joined on 04-30-2005
Jacksonville, FL
Posts 410
Points 5,660
Re: Atlanta Pro Solo Index Results
Hey Rick. Thanks for posting the results! Is there any way to run the report with normal PAX/RTP factors? Since this wasn't a normal Pro Solo and since Pro Solo indices are screwed up anyway, the regular PAX/RTP index might be interesting to see. Thanks! Mike
Mike King 88 CRX Si - STS2 #99 Jacksonville, FL 2007, 2008 STS2 Solo National Champion Team Bridgestone - King Motorsports - A-Spec Racing - Renspeed
05-19-2008, 11:19 AM |
rtp.rick
Joined on 05-10-2001
O'Fallon, MO USA
Posts 996
Points 12,445
SoloTiresdotCom:
Thanks!
Mike
I'll see what I can do.
H's & K's, Rick Ruth
05-19-2008, 11:33 AM |
glagola1
Joined on 04-08-2004
Atlanta
Posts 213
Points 2,550
SoloTiresdotCom:
Thanks!
Mike
No doubt. This was my first Pro in the CRX and I was pretty shocked by the handicap STS2 is given compared to STS. Who makes those things up anyway? Rick, they should adopt your index. :)
Matt
05-19-2008, 2:54 PM |
rtp.rick
O'Fallon, MO USA
Posts 996
Points 12,445
I've discussed, with the SCCA, using the PAX/RTP Index factors for the "Pro" events. The factors do seem to be more meaningful than the Pro Solo Factors. I realize the format is different and could (should), require different numbers, but the ones adopted seem to be substantially awry and the PAX/RTP numbers seem to be much closer. :-( I even suggested that they wouldn't get a ton of flak about the factors because they didn't come up with them. :-) At any rate, SCCA insisted on using their own factors.
The Atlanta Pro used side-by-side courses, or two different courses? Or, were the two times used from morning and afternoon?
Please let me know.
Thanks, with H's & K's, Rick Ruth
05-19-2008, 3:03 PM |
Renspeed
Jacksonville, FL
Posts 410
Points 5,660
The Atlanta Pro course was one course with two cars on course at the same time. The left "start" had about a ~50 foot launch then an immediate ~110 degree turn back to the left with about a 25 foot radius. The right "start" had about 100 feet of straight before you made a 90 right then a 90 left. So, when it came down to it, it very much was like a Tour course on the left with the start the way it was and more like a Pro on the right, but not terribly. Times were used from morning and also afternoon. The course just rubbered up and got warmer by a mile in the early afternoon. -MK
05-19-2008, 3:41 PM |
rtp.rick
O'Fallon, MO USA
Posts 996
Points 12,445
I guess what I'm trying to understand, is what to call the first row of times, as opposed to the second row of times? In a normal Pro, they would be left and right, but I don't know what to call these. Or, should I just Index them by the best single run? What does the total represent?
05-19-2008, 3:52 PM |
glagola1
Atlanta
Posts 213
Points 2,550
The first row of times is the left side. The second row is the right side. The first run on each side was done in the morning and was really just a look at the course and a test and tune. In the afternoon, competitors got two more tries on each side. The total is the best run from each side added.
05-19-2008, 4:27 PM |
decke003
Joined on 12-27-2007
Atlanta, GA
Posts 9
Points 165
Not that it matters, but where did my name disappear to?
I would have liked to have had that index
Chris Raymond 1990 Miata - STS2
05-19-2008, 5:59 PM |
rtp.rick
O'Fallon, MO USA
Posts 996
Points 12,445
decke003:
Sorry, Christopher. You and one other (Christopher Rotenbe) got eliminated, somehow, when I did the PAX/RTP versions. It so happend that you two had the longest names. That me have had something to do with it. I don't really think it had anything to do with being a "Christopher". :-)
At any rate, I have replaced the three PDFs in the posts, above, as of 5:00pm CST.
05-19-2008, 6:26 PM |
devomgd
Joined on 06-24-2004
Atlanta, GA
Posts 89
Points 1,150
Thank you for the postings Rick!
I have never finished that high in PAX befor at a national event. It was good to see.
Mark Davis 1993 Toyota MR-2 White "Casper"
05-19-2008, 9:21 PM |
sm2dan
Joined on 12-26-2000
Round Rock, Texas. y'all
Posts 650
Points 8,260
Rick, just an FYI, your Right Side calculations are incorrect. d
Dan Pedroza CS 72/172 2008 Nationals CS first loser
05-19-2008, 11:25 PM |
ErikZ06
Joined on 03-03-2004
Austin
Posts 206
Points 1,835
rtp.rick:
Please let me know.
I would hope that the "power"('s) that be at SCCA would take your offer to help with the PAX numbers in the future. I think using your numbers with some small tweaks to classes such as BSP, STU, STX and other AWD dominated classes for the launch advantage might be better than the numbers we have now.
BTW, it's obvious your numbers are more accurate.
1 1 SM2 Erik Strelnieks 1993 Mazda 3-Rotor R Hoosier 0.867 81.236 70.432 0.000
2 1 ESP Mark Madarash 1988 Pontiac Trans-A Hoosier 0.841 83.798 70.474 0.043
Erik Strelnieks 93 3-ROTOR RX7 01 Honda S2000 05 SLK 350 AMG 08 BMW 135i
05-20-2008, 5:15 AM |
rtp.rick
O'Fallon, MO USA
Posts 996
Points 12,445
sm2dan:
d
I re-checked and discovered that I had not recalculated the right side, at all. I have replaced the Right Side PDF above. Sorry and thanks Dan.
