Prius Classification For Solo - Can anyone help me?
Last post 05-23-2008, 9:39 PM by Bryan S. 24 replies.
Page 1 of 2 (25 items)   1 2 Next >
  •  05-14-2008, 12:22 PM 300243
    • Paul is not online. Last active: 05-14-2008, 4:31 PM Paul
    • Not Ranked
      Male
    • Joined on 05-14-2008
    • No. California
    • Posts 4
    • Points 140
    I want to run a Prius in autocross and need some direction on the best classification. Were do you think this car fits best?
    Filed under:
  •  05-14-2008, 12:30 PM 300246 in reply to 300243
    Re: Prius Classification For Solo - Can anyone help me?
    What mods does the car have?
    89/189 STS/STX '89 Civic Si
  •  05-14-2008, 12:39 PM 300250 in reply to 300246
    • Not Ranked
      Male
    • No. California
    • Posts 4
    • Points 140
    The car has has none, but I am considering buiding it to a class.  Were do other Prius run?
  •  05-14-2008, 12:43 PM 300251 in reply to 300250
    juicedhybrid:
    Google "FSP Prius" and you will see one.  I remember it from a while back, but not sure if it as official classification.
    I saw pics of an FSP one a while back:
    http://priuschat.com/forums/prius-main-forum/16285-prius-scca-solo-ii-fsp.html
  •  05-14-2008, 12:49 PM 300252 in reply to 300250
    H Stock.
    Keith
    '07 MINI Cooper S with some sort of stripes
    www.chaserace.com
    www.tightntidyracing.com
  •  05-14-2008, 1:01 PM 300257 in reply to 300252
    You could build it into XP.
    Ted
    2004 Z16/Z06 SS
  •  05-14-2008, 3:37 PM 300304 in reply to 300257
    • Not Ranked
      Male
    • No. California
    • Posts 4
    • Points 140
    Ok. FSP, XP, or H stock? I am sure they are all really good classes. But I want to make some mods to the car. I would start with Chassis stffiening, front strut tower, and some other chassis/suspension products that are bolt on.
    My other items I have to install are gounding kits for the battery/engine, and ECU managment systems. This proably gets me nulled in some of the stock classes. Modified?
  •  05-14-2008, 4:00 PM 300310 in reply to 300304
    Sounds like you need to read the rule book.  Read through the allowances and figure out which class you end up in based on your chosen mods.  Remember if it doesn't say you can, you can't.
     If your goal is to be competitive, be very careful when you chose your mods,  some simple things will move you up to a point you could never be competitive.
     If you goal is to make you car more fun to drive, and you want to have fun on the autox course, build your car the way you want it.  but don't expect to be competitive.
    Keith
    www.chaserace.com
  •  05-14-2008, 4:14 PM 300316 in reply to 300310
    • Not Ranked
      Male
    • No. California
    • Posts 4
    • Points 140
    Good suggestion. I will check it out tonight. Thanks.
  •  05-15-2008, 4:25 PM 300565 in reply to 300316
    good grief,  its a noncompetitive car in whatever class it runs.   you might as well run in XP,  that way you'll be legal no matter what you do to the car and you can run a real cool wing.
    lamoureaux
    BSP 2004 STi
    Wichita, Ks
  •  05-15-2008, 4:35 PM 300568 in reply to 300316
    more thoughts on possible mods.  remove all of the batteries and replace with one battery that carries enough juice to last for two minutes at full power drain.  This would be an allowable mod under stock rules.  put on as much tire as the stock rims can manage,  a sway bar up front and go racing.  the prius is likely to do very well in H-stock in such a configuration.
    lamoureaux
    BSP 2004 STi
    Wichita, Ks
  •  05-15-2008, 5:37 PM 300573 in reply to 300568
    thunderbird:
    Not legal in stock class (replacement batteries must be same size, weight as stock).  Might be legal in ST depending on if you count it as one battery or multiple ones.
    STS2 - 1990 Mazda Miata
  •  05-15-2008, 5:56 PM 300577 in reply to 300573
    I'm sorry. . .but is no one else struck by the irony of this?  The Prius is the antithesis of this sport.  It stands for everything we don't.
     Regardless of how funny I find it, coming from an underdog car (and now building another) I wish you luck.  As long as YOU are having fun, that's all that matters in this sport.  Remember, most us will never be rich from auto-x'ing!
  •  05-15-2008, 6:06 PM 300578 in reply to 300577
    Bobzilla:
    i take your point, but antithesis is such a strong word isn't it?
    as a fellow luddite i've nonetheless had to learn a bit about electric vehicles - the prius may be a bad example, but i'm chuckling at the reference to battery substitution, as the rules may have to withstand some changes in the next few years...
    i seem to recall one with 100 whp per wheel, which wouldn't embarass even Mr. Daddio would it?  max torque at 0 rpm?
    ah yes... batteries...
    Charlie Thompson
    '04 JCW Cooper [STX]
    NER Cannon Fodder
  •  05-16-2008, 11:44 AM 300676 in reply to 300578
    wouldn't that be in the "no class"?
     Just kidding;  it would go to the catch alls in HS and escalate from there.  Bring whatever you want to race, i always did, whether it was an old truck, oldsmobile, or whatever, and have fun.  Sometimes I had more fun in my old jalopy's than in competetive cars.
    But if you really want to be competetively racing, remember that this is the SPORTS CAR club, there should be no expectation that cars designed to be the antithesis of a performance car should have a class it can win nationally in.
  •  05-16-2008, 2:22 PM 300694 in reply to 300243
    Paul:
    probably in your garage.
    seriously, though, unless you're REALLY tight on parking space,* you might consider just getting something cheap to autoX in, and not ruining the prius for its central purpose.  you can pick up any number of fun older cars for about what it would cost you to prep a prius, which will still not be as much fun in the end.
    *i live in center city philly and park my autoX miata on the street.  so by "really tight," i mean less than that. Wink
    Mike - #44 STS2
    '91 Miata - racer
    '07 CX-7 - dog taxi
    www.phillyscca.com
  •  05-16-2008, 4:08 PM 300708 in reply to 300676
    cbramey:
    it would go to the catch alls in HS and escalate from there. Toyota Prius is listed in H Stock, no catch-all needed.  There is no Street Prepared listing though.
    I don't think that autocrossing a Prius is any weirder than autocrossing a Dodge Intrepid.  The only reason the Prius is weird at all is because it's such a boat suspension-wise.  I've seen Honda Insights and even a GM EV-1 autocrossed, and I personally thought that was cool.  A Tesla Roadster would be right at home on the autocross course, despite the fact that it burns no gasoline...
    Where hybrids pose the biggest potential problem in terms of the current rules is in Street Mod.  Unrestricted drive train as long as it includes a production block from the original manufacturer...which might allow you to do anything you want with the electric side of things!
    John S.
    S2000 #42as
  •  05-16-2008, 5:31 PM 300719 in reply to 300708
    While we're on the subject of Hybrids at autox it might be a good idea to remind everyone of the safety reminder that SCCA put out on the use of Hybrids at autoxs.  All Safety Stewards should familiarize themselves with the ignition switches of the hybrids to ensure they are turned off in a safety situation.  Since the engines aren't running at a standstill they represent a potential hazzard should an accident happen and they are not shut off and it isn't recognized that the car is still capable of moving under power while safety personnel and course workers are approaching the accident.
    Drivers of Hybrids should make it a point to show the safety stewards how to shut off power to the cars.
     FWIW
    Ted
    2004 Z16/Z06 SS
  •  05-19-2008, 2:38 PM 301047 in reply to 300304
    Paul:
    1) Save the $$ you were going to spend modifying the Prius.
    2) Buy an early 90's Miata instead.
    3) Watch your desire to stab yourself in the eye decrease.
    I'm just sayin ;)
    John W: 2003 WRX: STX (and sometimes 1991 MR2: ES)
    Washington, DC Region
  •  05-20-2008, 9:14 AM 301224 in reply to 300577
    Bobzilla:
    Wait a minute. Wasn't the origin of motorsports competition to provide a place to test the new fangled horseless carriageSmile? While I'd agree that the Prius, like many "alternative" cars looks like it was designed by people who don't like cars I'm love the exploration of new technology in competition. If we don't find ways to include new stuff we'll look more like NASCAR (the only place other than a lawnmower where you'll find a carbuator these days Smile)
    I agree with Ted that the safety issue is very important. For most of us taking care of a normal car in an emergency is second nature. I'm not so sure I know what real hazzards a Prius might have if not handled right.
    If the owners point is to get involved in autocross then buying a Miata is probably a better investment in the sport. But if the point is playing with a Prius, this sport is a good place and you WILL get noticed.
    Bryan S.
    Thanks Jan for the 06, 07 Mini co-drive
    '91 Miata (coming out of the garage? ES? STS2?)
    Past St. L BoD member
    Course Chief
    Novice Autocross School Chairman
