Last post 07-21-2008, 8:09 AM by solo-x. 148 replies.
Page 3 of 8 (149 items)   < Previous 1 2 3 4 5 Next > ... Last »
  •  03-10-2008, 4:27 PM 289298 in reply to 289258
    Mike Shields:
    OK, so while you concentrate on shifting, I'll concentrate on cornering :P
    Once I get the head back on the car and get it off to the dyno for tuning, we'll have to compare dyno charts to see just what the area under the curve is.
    -Mike
    Definitely. Where are you taking yours to get it dyno'd? I was thinking of hitting that place in Ayer.
    Nate Whipple
    NER
    188/88 DSP ITR
  •  03-10-2008, 4:38 PM 289301 in reply to 285655
    how does 4 lug vs 5 lug affect axles? same axle.... huh?
  •  03-10-2008, 7:04 PM 289337 in reply to 289301
    Rodney:
    Really? I thought the bigger outer joint went with the bigger hubs and bearings. They look bigger then my civic axles, but I don't have a gsr axle to compare against. Part numbers are different too. 44010-ST7-J61 for the GSR axle, 44010-ST7-J72 for the ITR axle. :shrug:
    Nate Whipple
    NER
    188/88 DSP ITR
  •  03-10-2008, 7:53 PM 289348 in reply to 289337
    solo-x:
    ah, you n00b.....  sohc civic axles are different then dohc integra. they are smaller, and they do not have a halfhsaft... you should know this. Geeked
    regarding gsr and itr axles, they are physically the same. same outer joint, spline count etc. you can swap the gsr 4lug spindles/brakes directly onto the itr and it will be bolt on, no axle issues. same with 99/00 si and 94/95 si w/ abs spindles. all the 10.2 stuff. in fact, the 96-00 and 92-95 dx spindles (9.4 brakes) bolt on with no fuss as well. only the 92-95 cx will not wor, as the outer hub has a smaller spline count.
  •  03-10-2008, 8:32 PM 289355 in reply to 289348
    Doh!! Too bad he's already got those 5 lug wheels bought and installed. Oh well there's always next year!
    Mike Shields
    1993 BMW 325is | 92/192 DSP
  •  03-10-2008, 8:32 PM 289356 in reply to 289355
    Nate,
    I'm thinking Turner since it's going to be a custom chip burned for the stock ECU. If anyone happens to know of a better option, I'm all ears
    Mike Shields
  •  03-10-2008, 9:57 PM 289371 in reply to 289337
    What size is your axle nut? Do only the JDM type-r's get the big axles with the 36mm nut? I know the rest of the b-series nuts are 32mm. That's an easy way to verify. I could have sworn that the Type-Rs got bigger axles than the rest of the DOHC motors.
  •  03-10-2008, 11:41 PM 289395 in reply to 289348
    Rodney:
    solo-x:
    I know about the intermediate shaft on the b-series. Guess I'm just being thrown by the different part numbers for the axles per honda parts fiche. At least I've got that l33t ABS!
    Nate Whipple
    NER
    188/88 DSP ITR
  •  03-10-2008, 11:43 PM 289396 in reply to 289356
    Mike Shields:
    Nate,
    Ah, didn't know Turner did dyno services. Do you know what type of dyno they use?
    Nate Whipple
    NER
    188/88 DSP ITR
  •  03-10-2008, 11:52 PM 289399 in reply to 289396
    Dynopack IIRC
    Mike Shields
  •  03-11-2008, 5:10 AM 289425 in reply to 289371
    mleach:
    this car is being prepped for SP, you are not allowed to change to jdm parts, hence he will have the 32mm setup. not that that makes a difference, since the jdm front brakes/rotors/calipers are the same, only the hub/bearing is larger. i never had hub issues, and i run the smaller bearing/spindle setup then he is Cool
    nate, i know the gsr and itr axles have diff part numbers, iirc the gsr axle has green rings on it and the itr has red. but the are dimensionally the same. all b series integra/civic/del sol axles are the same, save for the 90-93 teg driver's side. the difference there is the half shalft is female instead of male, but it will work if you have the 90-93 axle/halfshaft combo though. oh, and the 99/00 si does not have the abs rings on it, but they can be put on.
    god damn, i am a plethora of honda info..... Embarrassed i would say more but someone just told me to SHHHHH! Super Angry
  •  03-11-2008, 8:38 AM 289431 in reply to 289298
    solo-x:
    Mike Shields:
    -Mike
     Quag and I also need to dyno (just wired my new standalone in last night!).  NER dyno day, anyone? :P
  •  03-11-2008, 9:33 AM 289442 in reply to 289431
    I just gave Kevin Holmes @ Turners a quick shout.  He'd be glad to take on individuals probably next week (this week is flat out) but would also consider a group.  If several folks wanted to come together he reckoned that would be a Saturday gig.  He is open to that.
    And yes, it's a Dynopak.
    Charlie Thompson
    '04 JCW Cooper [STX]
    NER Cannon Fodder
  •  03-11-2008, 11:19 AM 289467 in reply to 289431
    AceInHole:
    solo-x:
    Mike Shields:
    -Mike
    I'm thinking Turner won't know how to tune Hondata.... NER dyno day at the place in Ayer would be pretty cool though. hrm.........
    Nate Whipple
    NER
    188/88 DSP ITR
  •  03-11-2008, 11:20 AM 289470 in reply to 289442
    cmt52663:
    I wouldn't be able to get to the dyno until April at the earliest. (the car isn't quite drive able yet and I don't have my tuneable ECU yet either)
    Any idea if Turner will tune stuff other then a BMW?
    Nate Whipple
    NER
    188/88 DSP ITR
  •  03-11-2008, 11:40 AM 289491 in reply to 289470
    If by Ayer place you mean KTM, then you're SOL. They have a dyno, but no tuner.
    Mike Shields
  •  03-11-2008, 12:07 PM 289501 in reply to 289491
    Mike Shields:
    When I took the tour over there last year during the Devens Tour they had a tuner that could tune Hondata ECU's. Maybe he left?
    Nate Whipple
    NER
    188/88 DSP ITR
  •  03-11-2008, 1:09 PM 289514 in reply to 289470
    solo-x:
    no harm in asking.  978-388-7769, then enter 5 to get to Kevin
    Charlie Thompson
    NER Cannon Fodder
  •  03-11-2008, 1:15 PM 289515 in reply to 289425
    I knew that much, I just couldn't recall if the USDM Rs got 36mm axles or not. Apparently you could.
  •  03-11-2008, 1:51 PM 289525 in reply to 289470
    solo-x:
    cmt52663:
    I know Mike and Quag are no-where near ready for dyno time :P  I've got a decent basemap, so I can hit up local stuff on low-boost if any events come up between now and then.  Maybe I'll go paint my car one color while I wait.
