XP Viper anyone?
Last post 03-06-2008, 2:06 PM by Fair. 56 replies.
Page 3 of 3 (57 items)   < Previous 1 2 3
  •  01-09-2008, 2:06 PM 279757 in reply to 279691
    Re: XP Viper anyone?
    Steve Hoelscher:
    And one other thing to note; no 1.6 liter, turbo/supercharged, 1700 lbs XP car is going to make the corner exit torque that Stan's Vette does.
    Who cares if both cars can obtain the .7-.8G max attainable forward acceleration?
    And a mid engined 2L FI'd engine is still sub 1875 lbs with ABS.  You can start getting some good torque out of a turbo'd 2L... easily in excess of 350 lb-ft.  Or Andy's RX7 ends up sub 2000 lbs.  I bet it's making near Stan's torque...  or at least could be with some more $$ and knowledge thrown at it.
    Jesse
    -2007-2008 XP Spyder
  •  01-09-2008, 2:27 PM 279764 in reply to 279757
    Sorry, but I only have about 300 ft-lbs.   I doubt that is anywhere near what Stan makes.  It does help that I mulitply that with about 9.6 of gearing.
    To match my car's torque/weight in a 1700lb XP car (assuming it has gearing and rpm range like I do), it would only need about 200 ft-lbs.  Somehow I don't think that would be very difficult. Stick out tongue
     -Andy M.
  •  01-09-2008, 2:44 PM 279767 in reply to 279764
    boxboy:
     -Andy M.
    I was figuring with a rotary, you'd have a good bit of gear multiplication vs. Stan's V8, although the automatic may offset that a bit.  Either way, I think I'd give up 5-10% of an acceleration advantage to be almost a FOOT narrower.
    Jesse
  •  01-09-2008, 4:23 PM 279786 in reply to 279767
    400ft/lbs at the wheels starting around 3000rpm.  But dumbed down by the automatics 6.68 gearing (that's 87mph in 2nd gear) - That will be improved for this season.  Those quick with math will see Andy puts more torque to wheels currently Embarrassed And he's in the 'weak' SM2 car - no wonder they are faster
  •  01-09-2008, 4:45 PM 279789 in reply to 279786
    Ouch...  7.52 for gearing for our XP car.  Andy has 50% more torque to the ground than we do in 2nd.
    Jesse
  •  01-09-2008, 4:50 PM 279790 in reply to 279786
    Are there any torque numbers on the 3 rotor?
    I can easily make 200 ft lbs of torque Normally aspirated in the 914. If I sell a kidney.  car was 1743 pounds @ Houston tour last year.  69.5 inches wide.
    Putting it down to the ground is a whole nuther bag of worms.
    This is a very interesting thread.
  •  01-09-2008, 5:48 PM 279796 in reply to 279790
    How is the 914 on brand new tires? You and Hassan looked like it wasn't sticking like a car that light should.....but for a 914 it had good squirt :)
    David Hedderick
    Pearland (Houston), TX
    08 Mazda 3s
  •  01-09-2008, 7:00 PM 279811 in reply to 279796
    I'm still mad at Andy for saying my Spyder has no power!!!! Sleep  I will have you know I have 50% more than stock...which has no power....so 150% of nothing is....ummm...ok, bad argument.   But I DO have VVT!!   Confused
    Tracy Ramsey
    Team Blenderblaster
    2000 MR2 DP Spyder
  •  01-09-2008, 7:15 PM 279814 in reply to 279789
    129STS:
    And you were only 0.5 off him scratch on the west course :)
    Given your power output (not engine size), you could probably be 300# lighter. Or, given your current weight, you could probably have 150-200whp more. Andy's probably 2+ years ahead in chassis development as well.
    Like you said, it gets scary with that much room. It's hard to think a CP car would have that much to gain. You were already a full second ahead of them on the west course, and Bob was more than a second ahead on the east. I'd expect you'd need to squeeze at least 2 seconds more (maybe closer to 3) out of a CP car to run with XP when it matures. I think that's a stretch.
    CSP --> SM2 might be a similar transition as DP --> XP. West course shows a 2.1 second difference CSP --> SM2  (46.7 to 44.6). DP (45.9) less 2.1 is a 43.8, 0.8 faster than SM2, 0.4 slower than BM. I think if you took 500# out of Andy's car he'd make that up. CP ran a 46.1, they need 2.3 seconds just to be in the hunt.
    Andy's probably close. Somewhere between EM and BM is where XP might end up. All of a sudden 2500# RX7s aren't that scary. :)
    Randy Noll
  •  01-09-2008, 7:41 PM 279818 in reply to 279790
    Joe_914:
    The one dyno I've see of Erik and Beth's 3-rotor has about 385 torque (I'm sure it can make more than that if they want).  Their gearing is a little different than mine since he doesn't want to rev as high, but it is a still respectable 8.7 or so.   Do the math on that and you can see why their car is so fast on acceleration.  How much of that you can actually use at HPT plus the fact their car weighs a couple hundred pounds more keeps things interesting.
    -Andy M.
  •  01-10-2008, 12:25 PM 279887 in reply to 279796
    Davebs14:
    What were were running into is too much grip. and twisting the chassis like a leaf spring.   I have a new chassis with full cage, now the object is to make it light enough. (insert sawz-all smiley)  Those were brand new tires at Houston we scrubbed the "new" off them before we arrived.   New car will look a lot more like a race car than something I drive around town.  If it doesn't make the car go faster it won't be on the car.
  •  01-10-2008, 2:03 PM 279908 in reply to 279887
    Joe_914:
    Davebs14:
    Joe, is there a chance we'll get to see the 914 at any East coast National events this year?  Or Nationals?  We need more people in XP at the Dixie Tour!
    Jesse
  •  01-10-2008, 3:22 PM 279915 in reply to 279908
    You should host a Pro at Atlanta Motor Speedway :)   he he he   I couldn't resist.
    David Hedderick
    08 Mazda 3s
  •  01-10-2008, 3:36 PM 279917 in reply to 279915
    Davebs14:
    Nah, we'll just run that pseudo-ProSolo thing there this year.
    Jesse
  •  01-10-2008, 4:05 PM 279921 in reply to 279917
    Mirror cross????
    Will it count and when is it? I wanna go! :)
    David Hedderick
    08 Mazda 3s
  •  01-10-2008, 4:08 PM 279923 in reply to 279921
    Davebs14:
    Mirror cross????
    Weekend before the Atlanta Tour.  Both at AMS.
    Jesse
  •  03-06-2008, 2:06 PM 288640 in reply to 279887
    Joe_914:
    Even without a cage and on 3 year old Hoosier S05s we're making so much grip that our BMW is bicycling a bit. Time for stiffer spring rates again. This car doesn't twist much as-is, but its still got tons of steel bodywork and glass that can help drop more weight, so we are adding a "minimalist cage". This way we can do open track and time trial events with it as well.
    Like the Viper referenced by the original post, this car is still probably too big and too heavy for XP, but the sound, feel and effortless acceleration from an LS1 V8 are so intoxicating... Geeked
    Terry Fair - www.vorshlag.com - www.ast-usa.com
    '93 E36-LS1 (XP), '97 BMW M3 (so long STU!), '91 318is (STS)
