STi vs. 135
Last post 04-23-2008, 10:58 AM by murph1379. 85 replies.
02-21-2008, 8:34 AM |
shinronin
Joined on 03-16-2004
Posts 95
Points 1,095
Whiplash_Motorsports:Now that wasnt so hard, was it.... :) (From the March Fastrack) Remove the word “single” from 14.12.3 in class STX. Note: this will allow any forced-induction configuration
seriously. way past due, but a very welcome... clarification. *runs*
Doug #81 STS2 1990 Mazda Miata Philly Solo Points Keeper
04-22-2008, 8:16 AM |
RedTRex
Joined on 03-02-2006
Posts 11
Points 85
Since I just put a 135i on order I will be interested in the outcome here, IMO and FWIW, I think AS would be the best spot for the 135i. The eLSD "tuning/setup" "is specific to this car. Also, max torque is available as early as 1400 rpm, and has an M-Sports suspension.
- Guess we will have to see what actually happens on a course.........
2008 BMW 135i Buccaneer Region DS #15 Cerebrum Digital
04-22-2008, 9:07 AM |
Chiketkd
Joined on 08-23-2006
Charlottesville, VA
Posts 372
Points 2,955
RedTRex:
Per scca.com, the May Fastrack is being released today (4/22). We should definitely know soon enough.
Chike Dellimore - Blue Ridge/Washington DC Regions 2006 Galaxy Gray 6MT Mazda RX-8 (B-stock) Former 2006 Steel Gray 5spd WRX (D-stock)
04-22-2008, 9:42 AM |
SpyderVenom
Joined on 01-11-2001
Southeast, PA
Posts 1,369
Points 18,080
RedTRex:Since I just put a 135i on order I will be interested in the outcome here, IMO and FWIW, I think AS would be the best spot for the 135i. The eLSD "tuning/setup" "is specific to this car. Also, max torque is available as early as 1400 rpm, and has an M-Sports suspension.
We had one with a known national level driver on course this past weekend. A little birdie said it was DS so it could be classed properly. After driving it, he thinks it's going to be a DS also ran. He was completely unhappy with it.
04-22-2008, 9:48 AM |
shinronin
Posts 95
Points 1,095
SpyderVenom:We had one with a known national level driver on course this past weekend. A little birdie said it was DS so it could be classed properly. After driving it, he thinks it's going to be a DS also ran. He was completely unhappy with it.
really? that's unfortunate. i kept meaning to ask steve what he thought of it.
04-22-2008, 9:52 AM |
ConeMasher
Joined on 07-02-2001
Richmond, VA, USA
Posts 146
Points 1,755
SpyderVenom: RedTRex:Since I just put a 135i on order I will be interested in the outcome here, IMO and FWIW, I think AS would be the best spot for the 135i. The eLSD "tuning/setup" "is specific to this car. Also, max torque is available as early as 1400 rpm, and has an M-Sports suspension.
I assume this was Steve Snow. Did he have race rubber on the car? Was it raining? Thanks Rob. Disappointing news for me to say the least.
Scott Hoffman HS '06 Acura RSX
04-22-2008, 9:59 AM |
04-22-2008, 10:45 AM |
John V
Joined on 01-12-2004
Columbia, MD
Posts 717
Points 8,210
conekiller2:135 in d stock doubtfull. 128i in d stock should be able to get it done being that hp levels are similar to 330zhp but the car is 2-300 lbs lighter. 135 should be classed in b stock if it stands a chance not a. Also think the 128 would be one hell of a stx car with a limited slip, suspension, and a few power upgrades.
A little birdie told me that the 128 and 135 will be living together in D Stock. Makes sense to me if the desire is to try to speed up D Stock. I imagine if the 135 starts running BS times it will get moved there under the 12 month rule.
If the 135 is like other BMWs it comes from the factory with a completely neutered alignment, meaning lots of rear toe and camber and minimum front camber with miserable shocks. With some tweaking I'm sure it will improve. It should be better in every way than a 330i ZHP and the ZHP can compete with the Type R on many surfaces.
John
John Vitamvas Overweight, one-wheel drive tire-eater
04-22-2008, 11:32 AM |
Chiketkd
Charlottesville, VA
Posts 372
Points 2,955
John V:A little birdie told me that the 128 and 135 will be living together in D Stock. Makes sense to me if the desire is to try to speed up D Stock. I imagine if the 135 starts running BS times it will get moved there under the 12 month rule.
John
Personally, that wouldn't make sense to me as the 335i has already been classed in FS. Why put a lighter car with the same engine in a slower class? If the 135i gets classed in DS then the 335i should be moved there with it.
04-22-2008, 12:13 PM |
SpyderVenom
Southeast, PA
Posts 1,369
Points 18,080
ConeMasher: SpyderVenom: RedTRex:Since I just put a 135i on order I will be interested in the outcome here, IMO and FWIW, I think AS would be the best spot for the 135i. The eLSD "tuning/setup" "is specific to this car. Also, max torque is available as early as 1400 rpm, and has an M-Sports suspension.
Yep, it was Steve. He had Hoosiers on the car and as far as I could tell, also tweaked the camber. It started spitting on fourth runs but the ground never got wet. He was running one or two cars behind me so I didn't get a chance to watch his runs.
04-22-2008, 1:06 PM |
conekiller2
Joined on 11-20-2005
Posts 85
Points 1,445
and its official
128 and 135 to d stock
evo x to a stock
moxnix
Joined on 06-15-2004
VA
Posts 443
Points 5,335
New fastrack 2. Stock: the following new listings, effective immediately upon publication, have been recommended by the SAC and approved by the SEB: Audi RS6 AS (ref. 08-138) Mitsubishi Lancer Evolution X AS BMW 128i & 135i DS Chevrolet Malibu (all) GS Mini Clubman S GS Mini Clubman HS Saturn Astra HS Suzuki SX4 Sport HS (ref. 08-054)
STS2 - 1990 Mazda Miata
04-22-2008, 1:13 PM |
Chiketkd
Charlottesville, VA
Posts 372
Points 2,955
moxnix:
New fastrack
Interesting. Hope the 335i gets moved to DS...
04-22-2008, 1:25 PM |
murph1379
Joined on 11-05-2006
Minneapolis
Posts 118
Points 1,805
Stock shocks?? Bar? We need to get this guy to post!
Shocks and bar transform the 330 from completely worthless to very competitive. I could see driving a stock 330 and thinking it's not going to cut it. I think the 135 would completely dominate DS. And the bummer with that is that you take a class that had five different cars in the trophies at Nats, all of which can be had for around $20k, and you stick a $35k overdog in there, and what do you get? A dead class.
04-22-2008, 1:47 PM |
NoCones
Joined on 12-27-2000
Greensboro, NC
Posts 552
Points 6,815
Wow. Very interesting.
I know it's heavy and has an open diff, but 300hp/300lb-ft in DS?
I thought I had a lotta grunt with 225 lb-ft.
Bryan 2006 Chrysler Crossfire DS #187 Yeah, seriously...A Chrysler
04-22-2008, 1:51 PM |
Chiketkd
Charlottesville, VA
Posts 372
Points 2,955
NoCones:
My thoughts exactly Bryan. If anything they should have classed the 135i in FS and moved the 335i down to DS along with the new 128i.
04-22-2008, 1:52 PM |
skeeter119
Joined on 06-12-2005
Pittsboro, NC
Posts 167
Points 1,560
NoCones:
Well I won't say there goes the class but it sure is not going to make many people happy. I know I am not thrilled with that call but I guess that is the nature of stock class. Bryan, atleast we have more tire, and 400 lbs or so less weight, plus better suspension.
Keith 2005 Chrysler Crossfire-- DS 1993 Subaru Legacy-- Rallycross car
04-22-2008, 1:59 PM |
NoCones
Greensboro, NC
Posts 552
Points 6,815
skeeter119: NoCones:
More tire? 135 has 18x7.5 and 18x8.5 doesn't it?
04-22-2008, 2:02 PM |
skeeter119
Pittsboro, NC
Posts 167
Points 1,560
NoCones:More tire? 135 has 18x7.5 and 18x8.5 doesn't it?
If they are like the 3 series they won't be able to fit much more than a 245 in the rear which will seriously hamper a car with that much power and basically an open diff. Though I could be wrong.
Page 3 of 5 (86 items)
3
