Who's used the Hankook Z214??
Last post 05-05-2008, 10:00 AM by Thinkkker03. 285 replies.
04-16-2007, 8:51 AM |
lead_foot
Joined on 04-21-2003
Houston, TX
Posts 69
Points 265
Re: Who's used the Hankook Z214??
STS3gCivicSi:Yes, we used the Z212 (street) in the pouring pouring rain on Saturday, and the dry Z214's on Sunday. Still managed to pull over 1g continuous on the street tires, in standing water, in an HS car....I have not reviewed the video and data from Sunday, just got home after a 7 hour drive....sleepy time!
Excellent job! Can't wait to hear more about what you thought of the tires.
2007 Mazda 3s #3 HS
04-16-2007, 11:15 AM |
Auto-X Fil
Joined on 07-19-2005
Posts 790
Points 3,710
I was planning on Z212 wets, and running Z214s instead of V710s would mean I never have to lose out on contingency when I switch to wets. In the northeast, that could be very nice...
-Philip Maynard No weenies!
04-17-2007, 8:40 PM |
RX7 KLR
Joined on 01-19-2001
Ladera Ranch, CA
Posts 1,351
Points 18,760
I guess we will get to see if the Z214 is faster than the old Kumho Victoracer:
Kumho Tires Named Official Tire of Mazda MX-5 Cup Through 2008
Topeka, Kan. - SCCA Pro Racing Ltd. and Kumho Tires announced today a multi-year agreement that makes Kumho the Official Tire of the SCCA Pro Racing SIRIUS Satellite Radio Mazda MX-5 Cup through the 2008 season.
Beginning with the Grand Prix of Houston, April 20-22, each MX-5 Cup car will be outfitted with Kumho's Victoracer V700 DOT-approved racing tire.
Jason Isley 2005-2006-2007 B Stock National Champion
04-17-2007, 9:31 PM |
STS3gCivicSi
Joined on 04-18-2002
Austin, TX
Posts 885
Points 11,735
RX7 KLR:I guess we will get to see if the Z214 is faster than the old Kumho Victoracer:
Yes, this has been a long-coming plan of Hankook to back out of the Series...rising support costs and the need for a lot of hand-holding and unnecessary involvement from the company was probably to blame....when I heard about it 8 months ago, the guys at Hankook were actually relieved :)
*Banned Again* Permanently
04-19-2007, 12:20 PM |
daverx7
Joined on 12-05-2006
Posts 89
Points 510
After Steve W. getting 2nd in AS at Nationals last year with A6 245/45-16 on all four corners on his AP1 S2000, I thought I would give that tire size configuration a try. Based on what I have read in this forum, Kumho dragging their feet on making 245/45-16 V710's, and the cost/longevity of the A6's, I've decided to try the Z214's out.
With my existing V710's, I typically have my pressure ~31F/29R, where would be a good start place with the Z214's?
Thanks, -Dave edit: corrected grammar
04-19-2007, 8:28 PM |
SteveW
Joined on 01-02-2001
Redmond, OR
Posts 288
Points 3,210
daverx7:
-Dave
Keep us posted on this particular tire as me and my SRT-4 buddies are probably going to try and cram that tire in our wheel wells real soon.
edit: I'm the Steve W. that, uhh, did not finish 2nd in anything at nats last year.
Steve W. #66 DS ACR SRT-4
04-19-2007, 10:16 PM |
daverx7
Posts 89
Points 510
SteveW:Keep us posted on this particular tire as me and my SRT-4 buddies are probably going to try and cram that tire in our wheel wells real soon.
Will do! I must admit that I'm not a national caliber driver, yet, but I'll be happy to share what I learn any way. I would love to read what you guys learn with the Z214's as well. It would be great to get another competitive tire in the mix.
SteveW:edit: I'm the Steve W. that, uhh, did not finish 2nd in anything at nats last year.
Whoops!! I was lazy... I should have been more clear put both names. Steve Wynveen was the S2000 driver that I was referring to. Sorry for the confusion.
-Dave
04-20-2007, 10:01 AM |
daverx7
Posts 89
Points 510
STS3gCivicSi:The sidewall carcass is much stiffer in the Z214 than the V710 and the A6 That is good info to know. I am now a bit concerned getting the 245/45-16's on my front wheels that are 6.5" as the V710's 225/50-16's are already quite pinched. We will soon see. Worst case would be is that I would need to buy some 225/50-16's for my fronts and have a couple of spare 245/45-16's for the rear.
STS3gCivicSi:theoretically you should need less pressure. You will probably figure it out right away, but Hankook recommends starting closer to 38-40psi and going up or down from there. In the super-camber-challenged HS car, I run about 47psi front (hot) and 55 psi rear, but AWD really helps any patch deficit...but any lower pressure, and I am cording the sidewalls :)
This at least gets me in the ballpark to start with. I will likely start with 40 and go from there. Too bad I didn't get these for the 2 test and tunes... BTW, how did you get those numbers from Hankook? Thanks, -Dave
04-21-2007, 8:50 PM |
daverx7
Posts 89
Points 510
STS3gCivicSi:Yes, they wrote a Competition Tire Guide that is unpublished. I can post it here if I get permission.
Any info you can share would be awesome! Thanks!! -Dave
04-21-2007, 10:24 PM |
ratt_finkel
Joined on 10-14-2004
Dallass
Posts 1,183
Points 14,080
STS3gCivicSi:The sidewall carcass is much stiffer in the Z214 than the V710 and the A6, theoretically you should need less pressure. You will probably figure it out right away, but Hankook recommends starting closer to 38-40psi and going up or down from there. In the super-camber-challenged HS car, I run about 47psi front (hot) and 55 psi rear, but AWD really helps any patch deficit...but any lower pressure, and I am cording the sidewalls :)
That doesn't sound horribly stiff. I ran 32psi at most lots on my heavier more powerfull RS running taller 225/50/16 V710's and ran 30 all the way around on slick asphault, etc. I was able to get around 85-90 runs before they corded. And that was usually in the middle not the typical cording on the outside like most hoosier and or mini drivers see.
Jeremy Foley 2001 2.5RS GS#80 2004-2006 2003 Evo8 STU #80 Who Knows? 2004 Mazda RX-8 BS #75 RWD? WTF do I do now? President Team if you can't beat them-Join them!
04-23-2007, 6:57 PM |
daverx7
Posts 89
Points 510
Look what just showed up at my front door! Now I get to stare at them for almost two weeks before the fun breaks out.  -D
04-23-2007, 7:08 PM |
lead_foot
Houston, TX
Posts 69
Points 265
Oooooh, shiny!
2007 Mazda 3s #3 HS
04-25-2007, 10:46 AM |
daverx7
Posts 89
Points 510
Just got the Z214's 245/45-16's mounted on my narrow 6.5" and 7.5" wheels. Some notes... my V710 size configuration was: 225/50-16 Fronts 265/45-16 Rears (taller than what should be on there 245/45-16) Width Comparisons
Z214's are on on left side of the image, and the rear tires are closest to the
camera... Notice how the V710's 225's are pretty close to the same
width to the Z214's 245's.
 Pinch Comparisons
Z214's on left side of the image, and the rear tires are closest to the
camera. Look how much better the rear pinch and how little difference
there is between the fronts.
This is going to be fun!! -Dave
04-25-2007, 7:11 PM |
ratedx1
Joined on 04-21-2007
Posts 1
Points 0
Any reason you went with the 245's and not the 255 rears?
04-25-2007, 9:18 PM |
daverx7
Posts 89
Points 510
lead_foot:Man, that far left one looks awfully pinched to me. The Kumho on the far right though doesn't look quite as bad.
It does have a little more pinch. From what I was told, the Z214's are narrower than the A6's and Steve Wynveen was successful with 245/45's. So, I'm hoping it shouldn't be a problem with the Z214's. [crossing my fingers] Since the fronts were further away in the other pics, here are a couple of more pics that better show the pinch differences between 225's vs. 245's.
What do you think? -Dave
Page 3 of 15 (286 items)
3 ...
