10" wide 15" Hoosier
Last post 05-28-2008, 12:11 PM by streetmod22. 103 replies.
Page 3 of 6 (104 items)   < Previous 1 2 3 4 5 Next > ... Last »
  •  04-06-2007, 11:41 PM 239925 in reply to 239908
    • actor is not online. Last active: 07/05/2008, 6:22 PM actor
    • Top 500 Contributor
    • Joined on 11-20-2001
    • Los Angeles, CA USA
    • Posts 199
    • Points 1,870
    Re: 10" wide 15" Hoosier
    EF_LSVtec:
    Just wondering if anyone here knows anything about when this tire is actually coming out?
    I don't think anyone really knows, but if I told you what I know, I'd have to kill you.Big Smile
    Suffice it to say, it won't be in time for AtwaterCrying
    Bill Schenker
    CalClub & S.D.R. #14 CSP 10AE Miata
  •  04-07-2007, 1:38 AM 239927 in reply to 239925
    I don't know how official this is but I was on Hoosier's website and they have the 275/35/15 listed on the A6/R6 spec sheet here;
    https://www.hoosiertire.com/rrtire.htm
    but not on the price list yet.(?)
    https://www.hoosiertire.com/46list.pdf
    DJsilver
  •  04-07-2007, 8:43 PM 239978 in reply to 239927
    i spoke to jeff speer 3 weeks ago, and his answer was "beginning of april". basically, look at the hoosier webpage, and as soon as they are avail, they will post it on the front page. Geeked
    Hi! I'm Rodney. "Hi Rodney!" I'm addicted to Solo2....
  •  04-16-2007, 1:38 PM 240840 in reply to 239978
    subscribing...
     It'll be interesting to see what size wheels (assuming 15x11max) and backspacing/ offset everyone will be running.....
  •  04-16-2007, 8:05 PM 240897 in reply to 240840
    Black R:
    15" x 10" with 6" & 6.25" backspace here.
    BTW - the latest from Hoosier is that the first production run of these tires is supposed to happen this week.  I'll be surprised if I see a set of tires before the end of the month.
    Steve Garnjobst
    #75 XP
    '99 Mazda Mutant
  •  04-19-2007, 1:02 AM 241259 in reply to 240897
    MNbiker:
    What tires are you running on those wheels currently?
  •  04-19-2007, 9:20 AM 241280 in reply to 241259
    Black R:
    Nothing - I'm waiting for the 275/35-15's to show up.
    I ran 22x10-16 Hoosier bias-ply slicks last year on different wheels.
    -Steve
    p.s.  If the 275/35-15 A6's prove to be deficient, the plan is to move to 23x9.5R-15 radial slicks, which use the same 10" wide wheels.
    Steve Garnjobst
    #75 XP
    '99 Mazda Mutant
  •  04-19-2007, 3:48 PM 241344 in reply to 241280
    FWIW, TireRack now has the 275/35/15 A6 listed for $237. Estimated availability is 04/25/07
  •  04-25-2007, 2:23 PM 242160 in reply to 241344
    I just got off the phone with Tom Reichel, and he's shipping a set of 275/35-15's out to me today. Cool
    I think the first batch was pretty small, so it may be a couple weeks before production ramps up.
    Steve Garnjobst
    #75 XP
    '99 Mazda Mutant
  •  04-26-2007, 8:40 PM 242368 in reply to 242160
    Hey, first post here guys.  I got a miata and looking into getting these Hoosiers for an autox and track tire down the road.  Main question is wheel size, looking at Diamond Racing rims.  I had originally been thinking a 15x9 would be enough, but sounds like everyone else is thinking wider .. 15x10 instead?  I also have no problem cutting the fenders to fit flares, but i was still worried they would rub.  Looking forward to seeing how your setup works out for you MNbiker
    1990 SM2 turbo miata
  •  04-26-2007, 11:37 PM 242385 in reply to 242368
    akaryrye:
    You're probably better off watching how these tires work out for Bill Schenker, as he has to live within the Street Prepared allowances - which means no touching the inner fenders.  My car, however - no longer bears much resemblance to a street car, and was running racing slicks of approximately the same size last year.  I am rather curious to see how the 275mm A6's perform, in comparison to the 22x10.0-16 slicks.
    Steve Garnjobst
    #75 XP
    '99 Mazda Mutant
  •  04-27-2007, 11:24 AM 242427 in reply to 242385
    My inner fenders and suspension are still stock too (although I'm in XP too so they may not stay that way for long) and I should have a set of these tires arriving shortly (although I didn't get a call from Tom, so maybe I didn't make the first batch?). Anyway,\ there will surely be lots of info on fitment up here and miata.net soon. At this point I would hold off on the wheel orders until you hear from the first people to put the tires on the car; both width and offset/backspace will be critical to fit inside the tight miata inner fenders.
    Also FYI: the 15x10 diamonds are not 18ish pounds as their website suggests, they are over 23 pounds each. I know because I just got some and put them on a scale... ouch.
    -- Glenn
  •  04-27-2007, 1:43 PM 242459 in reply to 242427
    geewiz:
    Yep, my digital scale says 22.8 lbs for the set I received.
    (shouldn't be too much danger of bending those bad boys!)
    I'm much more interested in confirming the 14.02 lbs Bill reported for the Bogarts.  My set is supposed to ship out by Monday.  Party!!!
    Steve Garnjobst
    #75 XP
    '99 Mazda Mutant
  •  04-27-2007, 1:57 PM 242461 in reply to 242459
    • Posts 199
    • Points 1,870
    MNbiker:
    Yes!  I'd like you to confirm that too.  I tried 3 different U.S. Post scales, but I was surprised by the results.  As a side note, Hoosier Tom thought that the 275s wiegh ~19lbs.; if true, that might mean that they're only 3lbs. more than my 13s!?
    Bill Schenker
  •  04-27-2007, 2:22 PM 242468 in reply to 242461
    Looking forward to seeing the results of your fitment Bill.
    Chris H.
  •  04-27-2007, 2:36 PM 242469 in reply to 242459
    MNbiker:
    geewiz:
    For reference, my 17x11 Bogarts weighed in the 16.xx range.  I think my 17x12's were closer to 18-19, but they had a thicker center due to my backspace requirements.  Bottom line, the Bogarts are very light, and built well.
     -Andy M.
  •  04-27-2007, 7:01 PM 242500 in reply to 242461
    actor:
     As a side note, Hoosier Tom thought that the 275s weigh ~19lbs.; if true, that might mean that they're only 3lbs. more than my 13s!?
    A set of tires just showed up on my doorstep.  My  scale says they weight 19.8 lbs each.  Not quite the 16 lbs of my 22x10.0-16 slicks, but not bad.  At first glance, the 275/35-15's appear almost identical to the 22x10.0-16's, in terms of width & diameter.
    Now the question is whether to mount the tires on the Diamond wheels sitting in my garage, or wait a week for my blingy Bogarts to show up.  Nice problem to have, I guess......
    -Steve
    Steve Garnjobst
    #75 XP
    '99 Mazda Mutant
  •  04-27-2007, 7:13 PM 242501 in reply to 242500
    Have you measured the actual width of of the 275/35R15s?  They seem pretty narrow to me, much closer to a 255 IMO...
    Garrick
    '89 325is
    DSP 72
  •  04-27-2007, 10:49 PM 242527 in reply to 242501
    E30 Racer:
    Not sure what would lead you to call these tires narrow - that's definitely not a word that comes to mind when you see them in person.  Wink
    Hoosier quotes tread widths ranging from 9.4" - 9.8" for their various 255mm sizes.  They list 10.1" for the 275/35-15's.  Based on my measurements, that number is very conservative.  On a 10" wide wheel, I'm thinking the useable tread width will be closer to 10.5".
    Steve Garnjobst
    #75 XP
    '99 Mazda Mutant
  •  04-27-2007, 11:57 PM 242531 in reply to 242527
    Pics! Pics! We need pics!
    '89 RX-7 GTU
    Speed in Gears Calculator
