A stock class proposal
Last post 10-10-2005, 8:06 PM by jmp33. 48 replies.
10-06-2005, 1:20 PM |
GH Sharp
Joined on 09-29-2005
NC
Posts 112
Points 565
Re: A stock class proposal
Newbies are no more likely to understand a points-based classing system than the one we have now. They need to understand that the driver is the most important part of the equation, especially at the regional level. Even if they happen to have the top car for their class when they discover the sport, it's likely it won't be prepped to the limit of the rules, so there is going to be a learning curve for them on several levels early on regardless.
As for our current classing system itself, when you have a limited number of classes in which to place hundreds of different cars, there will unavoidably be a range of performance within each class, which means by definition that a few cars will rise to the top of the class and others will be seen as uncompetitive. A points-based system won't change this given the same number of classes. And if you're going to have a "fudge factor" and plan on moving cars from one class to another at the end of every year because the points assigned to some of them didn't accurately predict their Solo performance, you're doing pretty much the same thing that's being done now, just with a different set of criteria to make those decisions.
GH
10-06-2005, 1:46 PM |
Joined on 05-28-2003
Posts 5,092
Points 81,605
GH Sharp wrote: | |
Newbies are no more likely to understand a points-based classing system than the one we have now. They need to understand that the driver is the most important part of the equation, especially at the regional level. |
Ooh.! Ooh! Ooh! I know!
Let's class the driver, then!
Much easier to do that!
"You newbies suck, so you are in HS"
"Hey, that guy's got one of them there fancy jackets. That makes him SS."
![Big Smile [:D]](/emoticons/emotion-2.gif)
10-06-2005, 2:55 PM |
GRMPer
Joined on 01-05-2001
Ormond Beach, FL, USA, Earth
Posts 543
Points 9,085
Didn't they try that with Russ Wiles?
10-06-2005, 3:01 PM |
Grintch
Joined on 06-04-2004
Huntsville, AL
Posts 154
Points 1,560
They do. They're called the Novice and Ladies classes.
(puts on flame proof underwear).
Bruce Funderburg #95 Spec Racer Ford '04 Subaru WRX STi - STU It will be of little avail ... if the laws [or rules] be so voluminous that they cannot be read, or so incoherent that they cannot be understood... Alexander Hamilton
10-06-2005, 9:57 PM |
jmp33
Joined on 11-03-2003
Farragut, TN
Posts 501
Points 4,825
ericdc wrote: | |
I completely agree on class philosophys... If the RSX-S with 200hp can't keep up with other similar on paper cars to bad, so sad. Reclassing a slow car to a slower class is senseless to me. The best few cars within the spec range for the class will be the ones that win. I really don't see a problem with that.
It is very common for people to ask "What is ES?" or "What is DS?". There really are no clear cut guidelines and because of that things change constantly.
My points exactly. This would add stability to the classing and once the stability is established, I doubt we would have the issues with people getting upset about classing that we do now.
There will always be probably 1-3 preferred cars for a class. At least this way, people will probably see the new preferred cars coming. This is similar to what we have coming with CS right now. Several people think the newer cars will be faster. Until now, the preferred car was the '99 Miata. Everyone knows the guard will possibly be changing with the new Miata and Solstice coming in. There isn't any uproar that I have noticed about the new cars coming in. This is totally different from what we are seeing with the DS/GS debate.
Mark Pilson owner of STS2 Honduh co-driver of HS Subaru (race tires rule)
10-06-2005, 10:08 PM |
jmp33
Farragut, TN
Posts 501
Points 4,825
GH Sharp wrote: | |
GH
I agree completely.
I think the points system would be too confusing, although, I do appreciate the new line of thinking. I think if we are to make the system better, we need to do it for everyone, not just the veterans that understand the system. The way to attract new people to the sport is to make it as easy as possible for them to get involved. Classing that is easy to follow and makes sense to the average, not necessarily mechanically inclined, person plays a large part in this.
10-07-2005, 9:06 AM |
10-07-2005, 12:36 PM |
Davebs14
Joined on 10-11-2001
Houston, Texas USA
Posts 2,185
Points 27,340
LOL...nice one Andy. Looks like I"m going to CS again :-)
I'm gonna tell Karter you said he sucks. :-p
David "Scrub" Hedderick
Andy Hollis wrote: | GH Sharp wrote: | |
--Andy |
David Hedderick Pearland (Houston), TX http://www.hyperfuels.com 09 VW Jetta TDI SSC racer 08 Mazda 3s 02 Mazda Protege (automatic tow vehicle) 92 Miata SE - Fun half-arsed STS2 Car
10-07-2005, 12:38 PM |
Davebs14
Houston, Texas USA
Posts 2,185
Points 27,340
<jabbering> Anybody been to any BMW events in his area lately? I haven't seen him since an event in like 02 when he was warming up for the O-fest in Texas. :-) That was fun double header event. We drove out butts off. :-) Boy what a nice guy! </jabber>
David
GRMPer wrote: | | Didn't they try that with Russ Wiles? |
10-07-2005, 2:05 PM |
marka
Joined on 03-14-2001
Poland, OH
Posts 2,066
Points 32,030
Back when I raced motorcycles, the "stock" classes were pretty damn simple. It was done on displacement. You got a 4 cylinder 600cc? Its in 600cc superstock. Doesn't matter if its this year's zx-6rr or a hurricane from 10 years ago.
The difference was that the hurricane owner didn't expect to be able to run with the top dogs and would have been laughed at for suggesting that his bike should be classed somewhere else.
Sometimes I think we should go to something like that. Stock classes are:
fwd 4 cyl.
fwd 6 cyl.
rwd 4 cyl.
rwd 6 cyl.
rwd 8 cyl.
awd 4 cyl.
open
And if you really wanna follow the motorcycle classing lead... Allow folks to change springs/bars at each end in addition to the current allowances.
Sure would ease all of these classing debates. No confusion as to where a new car is going to go. And if a manufacturer comes out with something that obsoletes everything else... Well that's not much different than if the SEB classes something into GS that obsoletes everything else either, eh?
And heck, compared to the current class system, there's one less class above, so you've got one class to "play" with and can create a protected spec class... Like spec '99 sport or whatever.
(yes, I know this will never happen. Thank you for pointing that out in advance. I also know that its not "fair". And yet it seems to work in the motorcycle racing example...)
10-07-2005, 3:11 PM |
Fedja J.
Joined on 10-22-2003
Arlington, MA
Posts 649
Points 6,615
GH Sharp wrote: | | ...And if you're going to have a "fudge factor"
those decisions. |
I was wondering if there is a known set of criteria that you
have mentioned above for the existing classing situation in Stock? Could we know what is used to
say that car A will go to this class X because of this and not to class Y because
of that?
Thanks
Fedja
95 AWD #34 SM or ESP "Let boost be with you... ...and bring some timing too!" http://www.geocities.com/esp_er
10-07-2005, 3:24 PM |
Fedja J.
Arlington, MA
Posts 649
Points 6,615
marka wrote: | Howdy,
fwd 4 cyl.
fwd 6 cyl.
rwd 4 cyl.
rwd 6 cyl.
rwd 8 cyl.
awd 4 cyl.
open
Hmm, right now there are also AWD cars with 6
cylinder (R32, GT3000/Stealth, Audi A4/A6, Skyline pretty soon, I hope ,
and few more) and some that using all 8 cylinders (several Audis (S4, RS4,...),
Magnum I believe comes with AWD as well, and few more too).
Then, to bring fun to even higher level, there are those darn turbo
chargers that could come to the aid regardless of the number of the
cylinders and those where not mentioned above, but do have tendency to
mix things up a bit!!
Fedja
10-07-2005, 4:53 PM |
NickFlynn
Joined on 09-19-2002
Morgantown, WV
Posts 766
Points 10,155
I have to say I think the current stock classing works pretty well. Sure, it would be great to have some more clarity in the system, which is something that the original poster (with the formula approach) and Mark Andy are both getting at with their proposals.
There are a lot of reasons that the formula type approach (which also encompasses Mark Andy's motorcycle classing idea) won't satisfy people and I won't go through all of them, but I will mention two areas in which the current SEB system, flawed as might be, really excels.
1) The SEB system largely succeeds in classing the maximum number of cars fairly. A formula type system is likely to leave many cars in classes where they have NO CHANCE of competing.
2) The SEB system takes into account the relative attractiveness of owning a particular car when making classing decisions. With a formula system, you are going to end up with the "car to have" possibly being some car that no one really wants to own or drive - like a Tempo V6 in HS or RX-7 in AS.
For those of you who hate the current system, it will all be over soon - there likely won't be stock classes in another 10 years anyway. (My own personal opinion is that driving aids will become so prevelant and intrusive that no one will really want to autocross a stock car.)
- Nick
Just two guys in a Miata - what's everyone looking at?
10-07-2005, 8:26 PM |
GH Sharp
NC
Posts 112
Points 565
Mark P,
Not to hammer my point too hard, but easily understood (read: simple) classing = rigid rules that would need to be followed almost without exception. As Nick pointed out, this would result in more cars that were uncompetitive in their assigned class. Believe me, if there were an easier, fairer method of classing, the SAC and SEB would be the first ones on the bandwagon. Hey, we could abolish the SAC...and the SCCA would save a bundle on conference calls, and our dues would go down.....well, maybe not. :-) And our correspondence load would go WAY down, since we'd just point out to everyone that once your car is classed, that's it. No class changes. If you DIDN"T enforce it that way, it wouldn't be simple anymore, and you'd be on the path back to the system we have now.
Mark A,
Fedja had the same thought I did about splitting the classes up by FWD, RWD, AWD, and engine size. Not enough places to cubbyhole everything we have now, plus you still have the same problem as above.
Fedja,
Yes, the SAC and the SEB have some general guidelines that we try to follow when classing cars. Calling them a "set of criteria" (IMO) would imply that they should be adhered to rigidly. And the reason we don't publish the guidelines, or whatever you'd like to call them, in the rulebook is that there are too many situations that arise...either in classing a car initially or proposing to move it to another class later...that simply defy our strict adherence to them all. Sometimes you just have to look at the big picture. Example: BMW 330Ci vs Acura Integra Type R. These 2 cars have competed equally on a wide variety of courses at the national level for several years. They ended up together in DS in sort of a roundabout way, but what sort of guideline or classing system would lead you to automatically put a heavy, RWD sedan in the same class with a light, FWD sport coupe... much less expect them to be equal competitors?
Nick, nice post. :-)
I don't expect the Stock classes to go away, even in 10 years, assuming the fuel situation doesn't get so critical that no one can afford to drive to events anymore. Electronic stability systems certainly won't be the culprit. Yes, some of these systems are VERY intrusive, but the better ones don't step in until you're pretty close to the edge of the envelope already, and nearly all can be substantially or completely defeated by the driver's pushing a button (you DO have to remember to push the button :-) ). The least intrusive systems are usually on cars that the mfrs know are going to be driven spiritedly (and correspondingly are the kind of car that people like to autocross) and design the systems accordingly. I think they'll only get better in that regard. There *are* a few car companies still out there that know there are people who don't want an electronic nanny preventing them from enjoying driving the car at its limits....BMW, GM (in the case of the Corvette at least), Mazda, and Porsche come to mind....and they all either make the ESC systems optional or defeatable, or program them to accommodate more aggressive driving before they step in to save your rear. :-)
GH
10-07-2005, 11:20 PM |
marka
Poland, OH
Posts 2,066
Points 32,030
GH Sharp wrote: | |
Yeah, I understand the problems and wouldn't expect this to ever be seriously considered. I _like_ the fact that a c4 or a 2nd gen mr2 has a place to play that's competitive in our current system.
As much as anything, I was just trying to point out that different philosophies exist and are used. They also have their drawbacks. Nobody on the motorcycle racing scene would expect their 600 hurricane to be competitive in superstock, but that's a luxury us folks in autocross often have. The downside to that luxury is that we rely on people to make the same decisions we would, and that's impossible.
The main advantage of "the motorcycle system" is that its rigid and easily understood. The main disadvantage is that its rigid... :-) The only 4 cyl rwd car that's gonna be competitive is the Elise. Previously it woulda been an S2000. Etc. In the motorcycle racing world, when the 'Elise' gets released, everyone sells what they have and gets the 'Elise' or just sucks it up and does the best they can. But not too many people *** about it, because the accepted system is very rigid and its ingrained in the competitor/fan base. It also doesn't hurt that the manufacturers very much want to do well, and all have racing as a priority for some of their bikes.
(btw, you could do some combining... :-) Like, awd 4 cyl turbos w/rwd v8, fwd v6 w/rwd 4, etc. Again though, not like you aren't just trading one set of problems for another.)
Page 3 of 4 (49 items)
3
