Way to go Ian, Peter and Danny!
Actually Danny hit a cone on the warm-up lap, not even the timed one, and he was penalized 10 seconds. Another car took out a ten cone wall on the timed lap and was also penalized just 10 seconds. Ian hit a lay down cone directional cone and was hit with 10 seconds. The rules say nothing about these penalties so they made the rule up on the spot, hit one or all and it's a 10 second penalty. Obviously the organizers knew nothing about autox and the rules associated with it...none of the cones were boxed and if they were hit they weren't always put back for the next car, and if they were they weren't in the same spot.
Also at the final autox several cars went off course (they chose not to walk the course) and the event organizers felt sorry for the DNF's so they decided to give those cars that DNF'd 150 points. All other events awarded 0 points for a DNF. After much discussion they changed their minds and took away the 150 points and made the DNF worth 0 points. That's better.
They can do better!!! If you're going to run an autox, then run an autox! You don't go to a drag strip and put a slalom in it.
Ted
2004 Z16/Z06 SS
