1991 Mitsubishi Galant VR4 Track Day/Auto-X Car F/S
Last post 05-13-2008, 1:29 AM by race2win. 0 replies.
  •  05-13-2008, 1:29 AM 299903
    Well, the time has come once again to try & find a home for my beloved Galant VR-4. I had it up for sale for a bit last year as I was going through a tough time. Things got better for me so I took it off the market thinking I would do a lot of track days this year. Well, my passion is autocross, & now would rather use the funds from this car to campaign a Miata of some sort nationally. So, here is a rundown of what the car has...
    1991 Galant VR4, #1303 of 2000 imported, 4G63 turbo 4-cyl, 5-spd, AWD & 4WS, 150K miles, 2 owner CA car (no rust or paintwork EVER!), original leather seats included all in very nice condition, even includes numbered plaque on the dash as well as the original numbered keychain (very rare). I originally set this car up for DSP autocross in 02-03, but quickly realized how outgunned I was against the BMWs. So, I decided to build it up as a fun street car that I could take to open track events. Here is a current mod list....
    Engine-
    Stock 4G63 engine, new head about 25-30K ago
    Extreme PSI ported Evo III 16G turbo with upgraded big internal wastegate
    Custom front mount intercooler with 2.5” custom piping
    Ported Evo 3 Exhaust manifold
    Tubular O2 housing into stainless 3” downpipe & 3" exhaust with no cat (has test pipe)
    Apexi N1 muffler with heat shield on bumper
    Custom 3” cold air intake with box that’s sealed off by the hood, K&N filter
    GM 3” MAF conversion with translator
    650 CC Precision Engineering injectors
    Walbro 255 LPH fuel pump
    AEM Uego wideband O2 & air fuel gauge set up
    Blitz blow off valve vented to atmosphere
    Greddy Profec B electronic boost controller
    Apexi SAFC II air flow converter
    Cruise control, emissions & A/C eliminated completely
    Battery relocated to trunk (light weight Odyssey) with custom mount
    Almost perfect original red cam cover, with custom carbon fiber plug wire cover
    NGK wires with special race plugs ($34 ea!)
    Polished aluminum SARD oil catch can
    C&R aluminum race radiator with high-flow slim line fan
    All Redline synthetic fluids in everything
    Transmission-
    Custom hybrid transmission, uses DSM case & final drive ratio but has gear set from JDM VR4 RS tranny (works great!), all new bearings, shims etc, very few miles on it
    Quaife LSD differential (awesome, pulls HARD out of corners)
    ACT 2100 clutch
    New CV axles in front
    Still has functioning 4-wheel steering setup & open rear diff
    Suspension & Brakes-
    KYB AGX adjustable shocks & struts (not the best but tough to find shocks for these cars)
    Ground Control coil overs, 450 lb front, 500 rear spring rates
    Ground Control front camber plates
    Trust front upper strut tower brace
    Whiteline rear upper shock tower brace
    Whiteline sway bars, 24MM front & the big 26MM rear (hard to get!)
    All poly bushings up front
    Custom race alignment & corner balancing done by Edge Motorworks, Dublin, CA
    Drilled & slotted stock size front brake rotors
    Stock dual piston front calipers
    Hawk HP + front brake pads, Metalmaster rear pads
    Steel braided brake lines
    Motul synthetic race brake fluid
    Interior-
    Sparco Pro 2000 race seat with custom brackets
    Sparco 3" 5-point harness (motorized belt eliminated on the driver side)
    Dual A-pillar gauge pod with Auto Meter Pro Comp boost gauge & AEM digital A/F gauge
    Center vents removed for custom gauge panel with Auto Meter oil temp, oil pressure, & water temp gauges, trimmed in carbon fiber (all electronic, no water or oil lines come inside the car)
    Momo suede steering wheel
    Apex I SAFC 2 mounted in ashtray location
    Greddy boost controller mounted above Eclipse CD player, trimmed in carbon fiber
    Custom leather shift boot & knob
    Includes original dash plaque as well as the coveted original keychain!
    Exterior-
    Carbon fiber AMG replica front grill
    Carbon fiber stock sized rear spoiler
    JDM front corner lights
    Custom front bumper opening for intercooler
    17x7” bronze 5Zigen FN01RC wheels with Hoosier A3S04s
    17x7” gun metal Tenzo R Mean 6 wheels with Kumho Victoracers
    There is probably more that I have missed, but as you can see a lot of time & effort went into this car. The best part is, other than the front bumper, nothing was cut or damaged in the build-up, so this car could be put back to stock someday if these things prove to be the 69 Z28 of the future. Included with the car are most of the stock parts, including the original leather driver seat.
    What it needs..... Well, it could use a good tune first off, as well as some better I/C piping. I have tuned it by the seat of the pants as there is no AWD dyno anywhere close to me, but I know it is set up very conservative & could make a lot more power. A few of the exhaust manifold studs are stripping, & there is an oil leak at the head where the feed line to the turbo taps in. The body has some light scratches & a few dings but is otherwise very nice. Other than that there is some sun fading on the top of the back seat, but that's about it.
    The way the car is currently set up, I have autocrossed it locally in SM although with the competition we have here in Northern CA it is obviously not competitive. However, I do believe the car has a chance in DSP now with the unlimited boost allowance (was not the case when I ran it 4-5 years ago). It would take a little work to get it DSP legal (radiator, BOV, turbo, transmission, front bumper), but with modified fenders for 285s, a diet & the right tune it could be a 2900-3000 lb 300WHP all wheel drive contender. If it does not sell this time around, that is what I will do with the car for next season.
    In the mean time, asking $7950 for everything.....I have over $25K invested. Will entertain possible Miata trades, either a 94-95 R package or possibly a 99 Sport, but leaning towards getting back into STS2 with a base 1.8 car. If you have any questions shoot me an email or give me a call.
    sportscarfinders@yahoo.com
    209-743-4989
    Mark Scroggs
    #42 CS 04 Mazdaspeed Miata
    #21 SM 91 Galant VR4 (For Sale)
