SCCA Racing Forums and Discussions
Welcome to SCCAForums.com
Sign in
Join
Latest Posts
My Posts
Help
in
Vehicles for Sale! (and rental) (forum)
Market Place (group)
(Entire Site)
Search
Home
Blogs
Forums
Vote in the 2006 Runoffs Pick The Winners Contest!
Market Place
Vehicles for Sale! (and rental...
Re: 1994 Acura Integra GSR, Price Drop $4300 obo
Last post 05-10-2008, 7:36 PM by
lennecefer
. 6 replies.
Sort Posts:
Oldest to newest
Newest to oldest
Previous
Next
04-07-2008, 4:53 PM
293942
lennecefer
Joined on 10-15-2007
Posts 18
Points 225
Reply
Quote
1994 Integra GSR, Milano Red
236k Miles
considering selling for a more competitive autocross
car
Engine
DC Sports 4-2-1 Header
-Holley 2.5” Stainless Cat-Back Exhaust
MSD Ignition Wires
New 02 Sensor
New Distributor, Cap, Plugs and Rotor (2/08)
Top End Gasket Set Replaced
New OEM Radiator
A/C removed*
DIY Cold Air Box**
K&N OEM Filter
Stainless Steel Clutch Line (Fastline
Performance
Clutch Replaced at 230K
New Slave Cylinder
New Driver’s Side Axel Replaced 9/07
*will include all parts
**also have a cold air intake and will include
Engine Oil Replaced, every 2500-3000 miles with synthetic since 150k (German Castrol)
Transmission Fluid Replaced every 10k with OEM Honda fluid
Suspension
All Bushings replaced with Polyurethane (ES)
Trailing arm bushings replaced with ES
Skunk2 Upper Control Arms (Camber adjustable)
New Tie Rods 12/07
New Ball Joints 12/07
All wheel bearings replaced 12/07
OTS Koni Sports
Ground Controls w/ 400lb/in front 500lb/in rear (Eibach and H&R springs)
KSport Rear toe adjusters
22mm ITR Rear Sway Bar w/ mounting kit
Blox Spherical Endlinks
New OEM front Ball-stud endlinks
DIY Trunk Bar
Rear Strut Brace
Brakes
Performance Friction Pads w/ Goodridge Stainless steel brakes lines
New Rotors (10/07)
New Master Cylinder (10/07)
Wheels
Have two sets of wheels, OEM Fat Fives with new tires (purchased in 12/07 less than 3000 on set)
and
15” Falken Hanabis with Hankook z212 tires (3/32” left on tread)
The Good
Compression was 210 across the board
Car has been very well maintained since ownership
Very fast autocross car, was able to win regional events with this setup. Could use more sorting out to become even faster, or drive as is.
Many parts have been replaced and drives amazingly well
Interior in great condition
Has been very reliable as a daily driver and autocrosser
The Bad
-The car does burn and leak oil, I have narrowed down the cause to bad valve seals, oil pan, and a gasket on the rear of the block, all can be easily replaced.
-Car had a small fender-bender, slightly damaged hatch and area around taillight, have to look closely to notice. Could use a little work
-Clearcoat has chipped off on spoiler and hood
-Minor dents and dings on sides of car
-Front window has crack was quoted $300 for this repair
Post Points: 35
Report abuse
04-10-2008, 2:00 PM
294526
in reply to
293942
lennecefer
Posts 18
Points 225
Re: 1994 Acura Integra GSR, STS prep $4500 obo
Reply
Quote
here's another picture of the vehicle in action, ttt
Post Points: 20
Report abuse
04-11-2008, 3:55 AM
294621
in reply to
294526
honda33
Joined on 06-02-2007
Posts 4
Points 60
Reply
Quote
bump for a great seller and car....Len say it isn't so
Post Points: 20
Report abuse
04-11-2008, 11:20 AM
294667
in reply to
294621
lennecefer
Posts 18
Points 225
Reply
Quote
I found an 89 civic that already has been setup, i can't pass it up since it'll be a lot cheaper to maintain than an integra.
Post Points: 5
Report abuse
04-20-2008, 1:36 PM
296073
in reply to
293942
gripfreak89
Joined on 05-22-2006
Brownsburg, INDIANA
Posts 73
Points 1,355
Reply
Quote
How much oil does it burn? Could I drive it back to Indianapolis with no problems and then rebuild the engine? haha
German Tabor
#46 STS2 1991 Miata - Future DP car
STS2 or STS wheel/tires for sale (RE-01r):
http://sccaforums.com/forums/276012/ShowThread.aspx#276012
Post Points: 5
Report abuse
05-10-2008, 6:55 PM
299527
in reply to
293942
JH Love TT DC2
Joined on 05-10-2008
Posts 3
Points 45
Reply
Quote
hey Do you have a picture of your car on h&r spring
Post Points: 20
Report abuse
05-10-2008, 7:36 PM
299533
in reply to
299527
lennecefer
Posts 18
Points 225
Reply
Quote
they're just 7in linear rate coilover springs. are you thinking the sport or race kits?
Post Points: 5
Report abuse
Copyright 2008 SCCAForums.com
