1979 Scirocco FSP/SM
Last post 05-11-2008, 3:58 PM by s2003r. 6 replies.
  •  05-03-2008, 3:35 PM 298324
    This car was built for auto-x and set up to run in the fsp class. Although it has been slightly tweaked to run in sm. This car is locally competitive in either class. Here are some quick points, Full roll cage, Koni yellow's with ground control coilovers, front upper and lower bars, front offset delrin, perfect running 1.8 gti motor with header, 4k trans with Quaife. And much much more.
    Since buying it I have replaced one blown front shock, one rebuilt half-shaft, rear swingarm and shock bushings, filled the transaxle with BG Syncroshift and changed the rear bumper to an aluminum one, still have the original one as well. Rear shocks may need to be replaced soon. I'm sure I'm forgetting stuff.
    s2003r (at) yahoo (dot) com
    $2500 with plain steel wheels.
    Car is located in Knoxville, TN.
  •  05-03-2008, 7:44 PM 298342 in reply to 298324
    Re: 1979 Scirocco FSP/SM
    Nice car.  You may want to also post this on www.vwvortex.com they have an autocross section.
    J.Cordeiro
  •  05-05-2008, 12:52 PM 298471 in reply to 298342
    Sportster:
    J.Cordeiro
    Thanks. I'll look into posting it on vwvortex.
  •  05-08-2008, 10:20 AM 299076 in reply to 298471
    what makes it SM?
    Rob P.
    04' VW pegl-leg GTI
  •  05-08-2008, 11:51 AM 299105 in reply to 298324
    Do you have the title and is it street legal?
  •  05-09-2008, 4:49 PM 299416 in reply to 298324
    Aftermarket cam is the biggest thing putting it in SM.
    I do have a title and it is street legal, at least in TN.
  •  05-11-2008, 3:58 PM 299625 in reply to 299416
    I will be going out of town for about a week with limited internet access. I will reply to any questions as soon as I can.
