Tire size and make suggestions
Last post 05-09-2008, 3:28 PM by JT_TT. 2 replies.
  •  05-09-2008, 2:04 PM 299367
    I really can't decide what to run and am looking for some suggestions.
     car's a Saleen S281 SC 3,600+- Car.
    Average (at best) driver
    Im going to try 285/3018 V710's, but I'm finding the OD too small ( almost 2 inches shorter than stock which is 275/35/20 ) which is going to cause ground clearance issues ( I trailer the car to and from events)
     Can anyone suggest a tire and size to try on a 18x9.5 rim?
    SCCA Badlands Member
    Saleen S281 SC
  •  05-09-2008, 3:02 PM 299381 in reply to 299367
    Re: Tire size and make suggestions
    how wide does your class allow?
    corners"
    Emerson Fittipaldi
  •  05-09-2008, 3:28 PM 299391 in reply to 299381
    Matt that's a tough call the 275/35R18 A6 that I run is a bit more then 1/2 an inch taller in OD and that's about all your gonna get. The 315/30R18 (which you could run pending fender) would be the same OD as the 275 (25.6). Both Chris and i are getting a set of them in this weekend. his are going on rims right away cause he needs them for next weekend, but mine don't need to be on rims till after the break in June. if you want to mount up all 4 and see if it makes a difference feel free....no using them for the autocross though, i gotta save those babies. but at least you'd see if that extra bit will help.
    That's the hoosier option.
    the kumho option is the 315/35R18 which you should be able to get on a 9.5 alright. they are a 26.5 OD is very close to your stock OD.
    2008 BS something...
    2007 SCCA National DS Runner-up
    2006 CAC National DS Runner-up
    Badlands SCCA
    Pictures of my car
    2007 Nationals Runs
