I'm selling my shifter kart and everything else you'd ever need to race
it. You can't go faster for any cheaper. All consumables are a fraction
of what you'd pay for auto-xing a car. Asking $4200 for everything. If
you have a civic I'll even throw in the trailer hitch. I am located in Atlanta, GA. You can contact
me at ryan12321@gmail.com
Kart Details
99 MBA kart
Ribtect medium seat installed in 2007. Never have to worry about rib pain
Extended front porch for taller drivers. Custom built by MRC fabrication in Lawrenceville, GA
Pedal position is adjustable so it will not effect normal height drivers.
Extended rear bumper built by MRC. Great for safety if you want to do any sprint or road racing.
4 wheel disc brakes with dual master cylinders
All electronic wiring done
Kill switch wiring and switch on front fairing
New fuel line installed in 2008
Brand new 40mm axle bearings installed in 2008.
All new bolts/nuts hardware on entire kart replaced in 2008.
All tie rod ends replaced in 2008
1 set douglas magnesium wheels with beadlocks for dry tires. Vega yellows on wheels
1 set aluminum wheels with brand new rain tires
2 spare rear aluminum wheels
2 sets of tire bags
1 set of Shockwave 65mm front hubs
1 set of Shockwave 95mm front hubs
1 set of MBA 120mm rear hubs
Brand new retrofitted 2007 kart front hub mounts
New as of 2007 rear brake rotor
New brake pads as of 2008, also have a set of spares
Engine Details
Honda CR125 built by Banke Motorsports
6 speed sequential transmission
vforce3 carbon fiber reed cage
K&N filter
K&N airbox with airbox filter. Air flow tubes have been upgrade to 29mm tubes.
RS Piston
ported and polished
O-ringed cylinder head
Epic racing thermostat system
Kehin PWM carb with pumparound system
RLV pumparound fuel pump, completely rebuilt in 2008
full jet set
full range of pilot jets
multiple needles
Shockwave
karting free-heel engine mount. Uses spherical bearings so it does not
stress the engine. Only mount of its kind on the market.
Shockwave fuel pump mount
Shockwave exhaust port with O-ring seals. Extra O-rings included
RLV exhaust pipe with EGT gauge port welded on
M4 titanium exhaust silencer
Freeline radiator
Engine spares
Full set of 40mm lightweight aluminum axle gears
A few extra steel axle gears
Full set of engine gears
Extra spark plugs
Extra O-rings for cylinder head
Tools
T-handle hex wrenches
Tire wizz tire mounting tool
RLV tire dismount tool
Fuel ratio mixing tool
5 gallon VP racing fuel jug
Brake bleeding tool for quick and easy brake system flushes
Tire guage
valve stem removal tool
Kart lift pro kart stand (single person kart lifting) - Sells for $550
Electronics
AIM Mychron 3+ data aquisition system with the following sensors
EGT - exhaust gas temperature gauge
Water temperature gauge
RPM
Speed sensor
2hours of onboard memory storage
USB cable to download system information to PC
Other
Full documentation on CR125 motor
OMP Ribvest
Shift kart size 56
Karting neckbrace
Northern Tool 5x8 trailer with toolbox permanently installed (can be removed if desired)
