Integra seat options
Last post 05-08-2008, 1:16 PM by Jojoo. 5 replies.
  •  05-02-2008, 3:02 PM 298216
    My wife and I will be occasional co-drivers of a 98 integra GSR.  the stock seat when it is all the way down is still to high by a large margin.  The car owner has approved the install of an alternate seat, but it must sort of be universal fit (accomodate skinny, fat, short, and tall
    people).
    Others must have encountered and solved this problem before.....
    What are good low cost options for a seat/sliders that will adjust fore/aft, and be a few inches lower than the stock seat?
  •  05-05-2008, 11:40 AM 298463 in reply to 298216
    Re: Integra seat options
    I'm using a Momo Cup seat on modified stock sliders in a 98 ITR. It sits me a good 2" lower in the car and worked for my 6'+ ~200lb co-driver and my 5'9" 160lb frame as well.
    Nate Whipple
    NER
    188/88 DSP ITR
  •  05-07-2008, 11:33 AM 298896 in reply to 298463
    I've been using a set of Delsol seats. They're lighter, sit lower and are more cumfy. I'm sure they're not at the minimum weight but pretty close.
  •  05-07-2008, 5:20 PM 298976 in reply to 298896
    Jojoo:
    That sounds like the perfect solution inside of our budget!!!  Do they bolt in on the Del Sol rails, or do you have to swap the pans around, or what?
  •  05-08-2008, 11:02 AM 299093 in reply to 298976
    Rocwandrer:
    Jojoo:
    They'll bolt right in. As far as seats are concerned, the floorpan for the various 5th gen Civics is the same as the 3rd gen Tegs. I forgot about those, mostly because it is so dang hard to get a good set of del sol seats.
    Nate Whipple
    NER
    188/88 DSP ITR
  •  05-08-2008, 1:16 PM 299130 in reply to 299093
    http://www.team-integra.net/sections/articles/showArticle.asp?ArticleID=1009
    That's a writeup of how to do it. I'm pretty sure three of the bolts are the same and the fourth is off a bit.
