Honda Fit - what class?
Last post 04-28-2008, 12:47 PM by mrexotica. 14 replies.
  •  04-22-2008, 8:00 PM 296535
    • MikeN is not online. Last active: 05-01-2008, 9:26 AM MikeN
    • Not Ranked
      Male
    • Joined on 04-22-2008
    • Allen (Dallas), TX
    • Posts 5
    • Points 100
    What class would the Honda Fit be in?
    Thanks...
    Mike N
    08 Honda Fit Sport | 98 Grand Prix GTP | 07 CBR 600 RR | 01 DR-Z400E Supermoto
  •  04-22-2008, 8:46 PM 296544 in reply to 296535
    Re: Honda Fit - what class?
    MikeN:
    Thanks...
    H-stock!
    Jeremy Foley
    2001 2.5RS GS#80 2004-2006
    2003 Evo8 STU #80 Who Knows?
    2004 Mazda RX-8 BS #75 RWD? WTF do I do now?
    President
    Team if you can't beat them-Join them!
  •  04-22-2008, 8:52 PM 296547 in reply to 296544
    • Not Ranked
      Male
    • Posts 5
    • Points 100
    Would this still be true with basic mods such as intake, coilovers, cat-back exhaust, etc?
    Mike N
  •  04-22-2008, 9:11 PM 296550 in reply to 296547
    MikeN:
    With those mods, you're now in STS. Any other 'basic mods' you want to tell us about?
    Chike Dellimore - Blue Ridge/Washington DC Regions
    2006 Galaxy Gray 6MT Mazda RX-8 (B-stock)
    Former 2006 Steel Gray 5spd WRX (D-stock)
  •  04-23-2008, 12:38 AM 296572 in reply to 296550
    • Not Ranked
      Male
    • Posts 5
    • Points 100
    hehe... good.  I figured it was STS.
    Now if I understand correctly... if I change the front brakes (oversized) that would put me in yet a different class too?  Seems odd to me that major suspension work doesn't, but brakes would Confused
    Mike N
  •  04-23-2008, 7:57 AM 296592 in reply to 296572
    MikeN:
     Brakes would put you in STX
    89/189 STS/STX '89 Civic Si
  •  04-23-2008, 8:40 AM 296594 in reply to 296572
    MikeN:
    It's called rules.  Each class has a set of rules applied to it, whether some make sense or not is up to debate.  Most people choose one of two options: 1) build your car how you want and run in whatever class it puts you in and go have fun, or 2) build your car to the extent of a particular class you want to compete in and go have fun.  Either way it's a blast, you just have to choose which path makes the most sense for you personally. Wink
    Sponsored by AgileAuto.com
    D.C./Philly Region - 3 STX
    cardomain.com/id/piknockout
  •  04-23-2008, 9:31 AM 296610 in reply to 296594
    Yeah, and here they are...
     http://scca.org/documents/Solo%20Rules/2008_Solo_Rules_2.pdf
    Good idea to familiarize yourself with this book first.  If there's something you don't understand, by all means ask away.
    Patrick Washburn
    STU Evo
    www.winghats.com
  •  04-23-2008, 1:40 PM 296685 in reply to 296610
    Anyone think a Fit would have a chance in hell in HS? Just thinking of getting one to play with.  :)
    Also, I assume the paddle shifting automatic would not be a good idea compared to the standard transmission, right?
    2006 Noble M400 (E-Mod?)
    http://chasecam.com/ official supplier to SCCA Pro Racing. Sponsor for SCCA ProSolo. Supplier to MazdaSpeed, V8Supercars, etc.
  •  04-23-2008, 2:23 PM 296694 in reply to 296685
    My Scion XA isn't holding me back in (local) STS
    it's more the driver is holding the car back...
    corners"
    Emerson Fittipaldi
  •  04-23-2008, 3:18 PM 296710 in reply to 296685
    I've got a fit sport w/manual. Just picked up an extra set of wheels. My hoosier 205's from my type-r should fit fine so I'm considering it. Handling is great, low weight, why let low hp and torque ruin my day....
  •  04-23-2008, 7:34 PM 296760 in reply to 296535
    • Not Ranked
      Male
    • Posts 5
    • Points 100
    Yea... one of the guys on our forum is doing well with a Fit.  From his post....
    I would like to say that this 2008 Honda Fit has taken first place at the Cincinnati SCCA. With a total of 13 turns again. Here are the times given. These are only best times to cut back on typing time. This may also be viewed on youtube.com. Sorry for the bad mouth at the end, the excitement got to me. It's under Quick Fit.... http://www.youtube.com/watch?v=vhSihMP6cPc
    1. STS #11 Tony (me) 2008 Honda Fit 49.400
    2. STS-#9 Other 2000 Nissan Maxima 50.048
    3. STS-#5 Other 1997 Honda Civic 50.057
    4. STS-#77 Other 87 Volkswagen Scirocco 50.415
    5. STS-#27 Other 99 Volswagen Golf/GTI 51.560
    6. STS-#93 Other 98 Honda Civic EX 51.611
    7. STS-#3 Other 03 Honda Civic 52.203
    8. STS-#678 Other 2004 Hyundai Accent 57.953
    Mike N
  •  04-24-2008, 8:38 PM 296944 in reply to 296760
    • Not Ranked
      Male
    • Posts 5
    • Points 100
    What brake changes constitute  a class change out of STS?   Can I change the rotors (keeping the size) but change the caliper to a 4 piston instead of the stock 1 piston?
    -Mike
    Mike N
  •  04-24-2008, 9:29 PM 296950 in reply to 296944
    Why would a Honda Fit (or any modern HS car) need better brakes?Confused
    Dick
  •  04-28-2008, 12:47 PM 297391 in reply to 296950
    brakes just slow you down!
    corners"
    Emerson Fittipaldi
