Transmission change?
Last post 04-24-2008, 10:19 PM by RtsLanE5. 11 replies.
  •  04-17-2008, 7:31 PM 295866
    I searched through the rules in SP, and I cannot find anything that says something about a restriction on transmissions.  Im going to guess that the tranny has to come out of something that is within the update/backdate years, but there is still nothing actually stating that.  Anyone have a bit more insight than myself on this subject?  Thanks
  •  04-17-2008, 7:38 PM 295867 in reply to 295866
    Re: Transmission change?
    You can update/backdate the transmission as a complete unit. That's it. No alternate transmissions, no mixing of gears, etc.
  •  04-17-2008, 7:43 PM 295869 in reply to 295866
    • Storm is not online. Last active: 07/08/2008, 7:08 PM Storm
    • Top 200 Contributor
      Male
    • Joined on 12-16-2001
    • Willoughby, Ohio, USA
    • Posts 293
    • Points 3,740
    It is my understanding that the transmission is treated the same as the motor in terms of UD/BD. It may come from an eligible car, but must be the complete unit. I actually took advantage of this on my FSP car with an updated motor first, then later, the trans from the same car.
    Jay Storm
    96 Impreza L FSP
    98 98 Impreza 2.5RS- co-driver DSP
    Wives are like SCCA rules...
    If she doesn't say you can...you can't
  •  04-17-2008, 8:06 PM 295872 in reply to 295869
    Thats what I figured.  Now, heres a big question.  This transmission is hard to find from this particular car, but from another car, theyre all over the place.  same exact transmission, just different car.  OK or not?  I know its pushing it. Thanks
  •  04-18-2008, 12:22 PM 295938 in reply to 295872
    • TedV is not online. Last active: 07-07-2008, 11:58 AM TedV
    • Not Ranked
    • Joined on 09-14-2006
    • Knoxville, Tn
    • Posts 32
    • Points 335
    same transmision code and serial numbers?  if you goto the manufacture and ask for that transmision it lists the same part number for your car and the other car it's easily found on?  all the same ratios?  The I don't see the problem if they are the same.
  •  04-19-2008, 4:50 PM 296032 in reply to 295938
    According to my info its the same transmission numbers from the factory.  I dont see how anyone could protest it if its the same transmission t hat is available in the car, but isnt from one.  Thanks for the info
  •  04-19-2008, 6:28 PM 296038 in reply to 296032
    A competitor can protest you if you fart upwind of them. )  Remember the burden of proof will be on you to prove that the transmissions are identical.
  •  04-21-2008, 10:00 PM 296294 in reply to 296038
    StrokerAce:
    Haha, I've heard of all the protesting you Texas guys do.  Im going to try and do it as close to completely un-protestable as I can.  Thanks for the info guys.
  •  04-23-2008, 11:44 PM 296819 in reply to 296032
      Male
    • Posts 293
    • Points 3,740
    RtsLanE5:
    If the tranny code matches the code of an eligable UD/BD source, it would be the same as if it physically came from that source.
    Jay Storm
    96 Impreza L FSP
  •  04-24-2008, 9:10 AM 296847 in reply to 296819
    Something similar has come up before with people swapping engines from cars not on the same line but are the exact same thing between different cars, and it was ruled OK.  Such as SR20DE engines coming in a Sentra SE-R but the same thing is in an Infiniti G20.
    Pretty sure it was Matt Kogan 4-5 years ago who got a ruling from Doug Gill for his STS SE-R which had an engine from a G20.  Yeah that's STS, but if it's OK for ST, shouldn't be any different than SP. Same exact engine in both cars from '91 through '93.  Only difference is the valve cover -- one has "Nissan" cast on the outside of the valve cover, the other has "Infiniti."
    It shouldn't be any different for a transmission.  As long as the transmission is *exactly* the same, it should be OK.  Gearing, case, etc.  If something minor like a speedo sensor hole is in a different location, then the transmission is NOT exactly the same.
    Pat
    '92 Sentra SE-R, daily driver and track car
    '82 Camaro Z28, ESP, 65% prepared, 50% ownership
    Upset about Stock class proposals? Get PISST!
  •  04-24-2008, 11:05 AM 296861 in reply to 296294
    Well, it would help a lot if you would specify which car(s) is the subject of getting a new trainy. I had a trainy in my car (Eagle Talon AWD) that was bought from the Mitsubishi dealership and was used in the Eclipse GSX, but in this case that was OK since they where still the same parts with the same part numbers for both cars. My guess that you have to have something similar because it will be hard to match things any other way.
    So, any more details that you could share?
    Fedja
    95 AWD #34 SM or ESP
    "Let boost be with you...
    ...and bring some timing too!"
    http://www.geocities.com/esp_er
  •  04-24-2008, 10:19 PM 296963 in reply to 296861
    Fedja J.:
    Fedja
    Not at this point.  I know theyre the same tranny's, so everything should be a-ok.  gearing, part numbers, ect.
