Elise for SM2----?
Last post 04-03-2008, 10:58 AM by sti752. 14 replies.
  •  03-31-2008, 10:03 PM 292942
    Elise for SM2----?
    Thinking about modding my Elise for SM2
     Would a second party supercharger be legal--like BWR .
    I think that SM2 min weight for a supercharged Elise would be 2005 based on the formula of 200lbs liter +25 liter for engine behind driver
    Don't want to ruin another car, but getting the parts from Lotus and doing a ASP legal supercharger seems difficult.
    Would this car need a LSD ?  opinions.......(as my Elise doesn't have one)
    Thanks----for any replies.......feel free to goof on me.
    Lehman
    PS---just to make the car more fun
    Trying to get faster
  •  03-31-2008, 10:29 PM 292947 in reply to 292942
    Re: Elise for SM2----?
    Under current rules....
     NA Elise = 1.8 * 225 + 1600 = 2005
     FI Elise (supercharged or turbo) = (1.8 + 1.4)*225 + 1600 = 2320
     If the 200lb weight break for 275 or under width tires goes through for 2009, then those become NA=1805 and FI=2120.
    -Andy M.
  •  03-31-2008, 10:47 PM 292949 in reply to 292947
    boxboy:
    -Andy M.
    Andy, why didn't you just tell Lehman to stop messing around with theoreticals and possibilities and just buy your car, if he wants to run SM2? Less pain, still have an Elise to pick up chicks and a no excuses ride for Solo II Stick out tongue
    In slow, out fast.
    In fast, out backwards.
  •  04-01-2008, 11:10 AM 293010 in reply to 292949
    Lehman, SM2 would be ok if the 200 lbs. weight break goes through.  Otherwise, it would be too frustrating to add 400 lbs. of ballast to that car.  200 lbs. is painful enough...
    As far as getting the SC parts from Lotus, I have 2 complete sets of Lotus SC parts ready to go minus 1 or 2 back-ordered parts.  You're looking at $5k in parts, not including the ecu solution.  I know a good tuner up in Philly that can handle the ecu reflash if you're interested...  Or you can go with a stand alone EFI ecu like we did on the Randy Chase, now Jason Uyeda car.
    Robert Puertas
    www.EvoSchool.com
  •  04-01-2008, 11:20 AM 293012 in reply to 293010
    Robert---  so what would I have to do ?
    How much if I did the R. Chase soultion------ ?
    So---5k in parts------How much ECU solution ?
    PS---adding LSD----can it be Toyota------can I let a Toyota dealer do it, or better at a Lotus dealer if they will do it ?  Although my Lotus dealer handels exotics, and I don't know if like the main tech would be able to get the time to do it-----as they prob have a much of other exotic junk to do.
    Thanks-----
    PPS----ASP makes more sense
  •  04-01-2008, 1:00 PM 293032 in reply to 293012
    Screw all that David... figure out how to put a transversely mounted LS7 in it and go to..... uhhhhh ........ hmmm ....... I'm sure gulf coast autocrossers have a class for something like that.
    1999 Civic Si SSC
  •  04-01-2008, 1:24 PM 293038 in reply to 293012
    About $5k in Lotus parts, some of those sourced from other places.
    ECU... depends. I had the EFI running the engine, but it does cost $3k or so.  The good thing is most of the tuning is done and can be gotten from DRS in La Habra and then you can tweak/dyno.  Or you can get a reflash done on the stock ECU cheaper, but then there is no way to change the tune easily for E-85, 100 octane, high elevations, etc.
    LSD-  You can get a Toyota supplied tranny or differential. Probably easier to swap the entire tranny and also install a lighter flywheel and better clutch.
    ASP makes a LOT more sense. You can get the car under 1900 pounds and over 250hp and just about as much tire as you want (too much).
    2006 Noble M400 (E-Mod?)
    http://chasecam.com/ official supplier to SCCA Pro Racing. Sponsor for SCCA ProSolo. Supplier to MazdaSpeed, V8Supercars, etc.
  •  04-01-2008, 1:25 PM 293039 in reply to 293012
    David Lehman:
    You will need an LSD.  Especially if you add the SC.
     If you can get the transmission out, send it up to me and I can do the install.  TRD makes an LSD for that transmission.  I have installed a few in Loti.
    #27 DP - Toyota MR2
    2006 DP National Champion
    http://www.terriehoward.com
  •  04-01-2008, 2:41 PM 293060 in reply to 293039
    David, whatever you do hurry up.  I need those front rims off your vette!
    Ted
    2004 Z16/Z06 SS
  •  04-01-2008, 3:57 PM 293078 in reply to 293060
    I just KNEW that post from Scott was coming..  Stick out tongue
    Jer
    #196 ES
    #187 SS retired
  •  04-02-2008, 10:21 AM 293180 in reply to 293039
    I've driven a s/c Elise making about 215 whp with an open diff on Nitrons and it didn't have any problems putting the power down on corner exit.
    -2006 Lotus Elise- SS
    -1993 Mazda Miata LE- ES
    -2000 Honda S2000- BSP
    -2005 Mazda RX-8-Sold
  •  04-02-2008, 3:07 PM 293232 in reply to 293180
    Depends on factors including available grip. I have had issues putting power down when the car was naturally aspirated.
  •  04-02-2008, 11:11 PM 293295 in reply to 293232
    what kind of N/A motor swaps could you do in a Lotus in SM2? Would they have to be a toyota engine or something that was specifically put in a Lotus at one time in history?
  •  04-03-2008, 9:34 AM 293329 in reply to 293295
    sti752:
    3.6 liter (originally 3 liter) NASCAR Dash Series spec Camry V6.  ~400 whp on a Holley two barrel.  Yes
    #27 DP - Toyota MR2
  •  04-03-2008, 10:58 AM 293342 in reply to 293329
    I won't even bother calculating the minimum weight with that motor.
