Adjustable Rear Upper Control Arms
Last post 03-26-2008, 2:17 AM by Jojoo. 10 replies.
  •  02-07-2008, 6:22 PM 284170
    OK, I'm pretty sure that these are illegal in street prepared, but I'm just making sure. The bushings are OEM type, but I'm not sure if adjustable length arms are legal...
    http://www.spcperformance.com/PROD_DIR/SPCPerf_PROD_SEARCH_DYN.cfm?cmd=Cam&cmd2=67765&cmd3=
    Thanks...
  •  02-07-2008, 7:47 PM 284185 in reply to 284170
    Re: Adjustable Rear Upper Control Arms
    Unless the rules say you can do it, you can't.
    That said, I only see one mention of an allowance for aftermarket suspension arms of any kind: upper arms on a live axle suspension.  15.8.H.4.
    SM ~ '96 Subaru Impreza
    Old Car: A Stock ~ 2000 Honda S2000
  •  02-07-2008, 11:13 PM 284224 in reply to 284185
    • jzr is not online. Last active: 07/05/2008, 9:31 PM jzr
    • Top 75 Contributor
    • Joined on 10-20-2002
    • San Diego, CA
    • Posts 769
    • Points 11,000
    Not sure what car you plan these for, but I had them on my STS 240SX, and they had adequate rubber % to be legal.
    You can run a Street Touring car on R-compound tires in Street Prepared as long as you don't otherwise go beyond ST prep.
     So there you go... :)
    --Jason Rhoades
  •  02-08-2008, 8:22 AM 284252 in reply to 284224
    It's a 1990 240sx, but I'm swapping in a engine from a '91, so I need the update/backdate part of the SP rules, plus I don't have all the emissions equipment...
  •  02-09-2008, 6:55 PM 284452 in reply to 284252
    Sounds like maybe you're headed to SM?  The adjustable arms are legal in SM.
  •  02-10-2008, 12:39 PM 284500 in reply to 284452
    adhowe70:
     No, I'm prepping the car for SP, I was just trying to find legal options for adjusting rear camber...it doesn't look like there is anything out there.
  •  02-10-2008, 2:24 PM 284504 in reply to 284500
    • San Diego, CA
    • Posts 769
    • Points 11,000
    Whiteline makes offset polyurethane bushings you can use in the control arms and knucles that will give you a couple degrees of adjustment. Try Don or Cory at PDM-Racing:
    http://www.pdm-racing.com/
    --Jason Rhoades
  •  02-10-2008, 6:17 PM 284520 in reply to 284504
    jzr:
     Oh nice, I guess I missed those when browsing the site.
  •  02-10-2008, 8:06 PM 284529 in reply to 284520
    I guess you've figured out what happens to the rear of a 240sx when you lower it-    //===\\   right?    Offset bushings in the upper and lower arms (inboard and outboard) and then raise it back up till you can stand the camber.  Too bad STS gets adjustable upper arms and SP doesn't but it is what it is!  Enjoy!
    DJsilver
  •  03-24-2008, 1:30 AM 291620 in reply to 284529
    Hi,
    Dragging this one back up because the April FastTrack has proposed changes to SP, one of which is to copy the "camber correction" language from ST into SP.  It makes sense from a class progression standpoint and I commented in favor.  Check out the April fasttrack and if you want to comment, send it to SEB@SCCA.com
    DJsilver
  •  03-26-2008, 2:17 AM 292021 in reply to 291620
    Looks to me like STS 14.8.I covers it one way or another.
