round 2 SFR SCCA autocross sucked!
02-26-2008, 2:08 PM |
Pat Kelly
Joined on 12-27-2000
Pleasanton, CA, USA
Posts 109
Points 1,645
Re: round 2 SFR SCCA autocross sucked!
The failed cable was replaced. We lost a lot of time, for sure, but once the repair was done, the event ran smoothly, we just lost control of the Earth's rotating speed. :)
BTW, 'they' is you, and everyone else at an SFR event. Get more involved that just throwing out your personal bitches.
--Pat Kelly
02-26-2008, 2:39 PM |
David Lehman
Joined on 01-27-2004
Plantation, FL
Posts 972
Points 13,125
If they are hot bitches, then please send them down here.
Trying to get faster
02-26-2008, 2:41 PM |
Doug Hubbard
Joined on 11-26-2006
Posts 80
Points 370
 Yea, what she say's and what he says, but send them to Sacramento instead!!!!!!
Doug Hubbard # 20 AS Sacramento Chapter
02-27-2008, 8:56 AM |
Doug Hubbard
Posts 80
Points 370
Kevin,
Are you upset over the long delays or the fact that the class winner "Spanked your ass" by 6 seconds???????
02-27-2008, 12:17 PM |
Pat Kelly
Pleasanton, CA, USA
Posts 109
Points 1,645
I do think the revised results have been put up. See http://www.sfrscca.org/solo2/Results/2008/Championship/round02.html
Our progam guru Robin Yang was able to sniff out the problems and fix them.
--Pat Kelly
02-27-2008, 2:00 PM |
lswilson9
Joined on 03-26-2005
Colorado Springs, CO
Posts 32
Points 330
Pat Kelly:The failed cable was replaced. --Pat Kelly
Hi Pat,
Wondering if you know the details of the timing system? I maintain the equipment for Colorado and Continental Divide Regions and am always looking for ways to improve reliability of our systems. We use JA Circuits timers. I'm using Neutrik weather proof 3 pin XLR connectors. We've also upgraded to the laser photo heads.
Did the cable you had to replace fail due to an open wire, shorted by water or something else?
Trying to minimize 'down time'
Lindsay - Colorado Springs, CO
02-28-2008, 1:39 PM |
Impala SS AutoXer
Joined on 05-13-2003
Santa Clara CA, USA
Posts 70
Points 960
Lindsay : I'm not Pat , but I'll respond.
It is a JA Circuits timer, with wires to them. The issue was that due to course layout and a VERY wet day, there was no choice but to run the cable to the timer thru several inches of standing water.
The cables are a few years old.
We have spares, unfortunately it did take a while to realize exactly what the failure point was.
Unless you normally have no choice but to run your timer wires thru the equivalent of a shallow lake, I wouldn't worry about it.
02-28-2008, 3:17 PM |
lswilson9
Posts 32
Points 330
We have some cables with a different insulation than the thin pvc type. They seem to work better in the rain. Also using the water resistant connectors seems to help.
02-28-2008, 9:39 PM |
tougeundersteer
Joined on 02-28-2008
Posts 2
Points 25
Crrikey:dam they really need to get some new timing equipement. Friggin rediculous! I know it was wet out but dam, the last run group had to run with their dam headlights on!
FIRST you shouldnt really be complaining when you dont volunteer anytime (excluding your required worktime) to help with things... i see why you are annoyed but there are people who volunteer MORE TIME and EFFORT to make last event keep going... I am sure they had more of a headache than you did
instead of complaining why dont you, do something about it, volunteer learn the computer system offer some help...do something then come on here and complain, this doesnt happen all the time
Stop wasting your time complaining and maybe use that time to learn to drive your super aerodynamic and lots racing graphics to make my mini look faster.... 11th out of 12... getting beat by 6 seconds OA PAX
| 52.595(1 | 50.333 | 53.779(2 | 43.286 | 141 | 158 |
out of 211 entrants.... and you ran in the dry ya i would complain too!
02-28-2008, 11:34 PM |
mwood
Joined on 05-11-2005
Alamo, CA
Posts 835
Points 10,500
As one of the co-chairs of the Round 2 event, I have to say I understand the frustration of participants. Sometimes Solo events have problems and run long...ask me how I feel about Pro Solo, in that regard
Besides what ended up being an "unwaterproof" cable issue, we also had some other problems that SFR hadn't encountered previously...which is saying a lot, as we consistently have the biggest regional events in SCCA, which you would think would have exposed all weaknesses over our long history of running events. The good news is that the two major issues are now both known and dealt with, precluding having delays from these sources going forward.
Personally, I can see no upside in this thread turning into a flame war or slagging festival...the original poster had a valid complaint. But, as others have said, you can either be a part of the problem of a part of the solution...
02-28-2008, 11:40 PM |
mwood
Alamo, CA
Posts 835
Points 10,500
Impala SS AutoXer:
Ed, we did actually have enough cable to have initially avoided most of "Lake Oracle" on the routing to the starting beam. I didn't oversee that part of the set up (being responsible for the course design), but when I mentioned to a few of the techies, early on, that I wondered about the cable routing, I was told the cables were entirely waterproof and, also, that the transmittal was very low voltage (?)...I'm no EE, so I just took it on faith. Now, looking back at it, it's pretty clear that the cable casing had become compromised over the last few years and that we did have internal shorting that was going on, resulting in random starts. Also, given the continuous rain we encountered for a good part of the morning, I'm not sure the cable would have survived even if it had been routed around that one big puddle (pond?). Chris and I first decided to change out the cable in RG4, but then things smoothed out, so we figured that the cable wasn't the primary problem. By RG5, it was clear we needed to try it...and, DOH!!!, it worked.
02-29-2008, 1:07 AM |
tougeundersteer
Posts 2
Points 25
sorry about the whole flame.. but i just find it a kick in the face... when alot of us know how much chair people put in time and effort to make things happen... IMO i would not like new chairs or any chairs to be discouraged by ignorant remarks..to do future events... thats all... it was a great event still .. everyone got their runs...
