Holy Splitter Batman! - is it legal?
Last post 01-29-2008, 10:20 AM by 129STS. 15 replies.
  •  01-26-2008, 11:11 AM 282212
    The 2008 SCCA rule book says that in SM/2
    [QUOTE=SCCA]
    M. Front splitters are allowed and shall be installed parallel to the
    ground (within +/-3 degrees fore to aft) and may extend a maximum
    of 6 inches forward of the front bodywork/fascia as viewed
    from above. Splitters may not extend rearward past the centerline
    of the front wheels. No portion of the splitter may extend beyond
    the widest part of the front bumper/fascia as viewed from
    above.
    [/QUOTE=SCCA]
    So without getting into the merits of the design etc, I just want to gather opinions as to whether or not it's legal before I make it out of anything other than cardboard and start testing.
    Chris
    51 SM2
  •  01-26-2008, 1:15 PM 282220 in reply to 282212
    Re: Holy Splitter Batman! - is it legal?
    Yes, that is legal. I would shorten it up a little bit though, as that big of a splitter will create a TON of downforce, and consequently drag, on the front end of the car. I would make a few of them in different sizes, like 3", 4", and 6". I am going to be trying something similar on my car for this season.
    '77 Scirocco FWD SM Monster
  •  01-26-2008, 3:33 PM 282230 in reply to 282220
    No such thing as too much down force at 60-70 MPH top end speed.
    Just remember to do a wing equally big out back.
    I've been designing one like these in my head for awhile now.   Is yours going back to the front axe?
  •  01-26-2008, 5:08 PM 282243 in reply to 282230
    The rules say it can go to the centerline.  I may stop at the front of the crossmember.
    And for the rear
    Chris
    51 SM2
  •  01-26-2008, 7:52 PM 282256 in reply to 282243
    holy cone splitter.... you will chop them in half if you hit one. do too many, and you will get a bill from the scca at the end of the event...
    Hi! I'm Rodney. "Hi Rodney!" I'm addicted to Solo2....
  •  01-26-2008, 10:20 PM 282264 in reply to 282256
    Rodney:
    Then I could have a half off cone sale.......   Thanks, I'm here all week, try the veal!!!
    SO... If I slice the cone in half, and the bottom stays in the box, no penalty right?
    Chris
    51 SM2
  •  01-26-2008, 10:34 PM 282265 in reply to 282212
    Make sure you figure out an easy way to take it off and put it on for putting it on/in your trailer.  Our XP car's splitter takes about 5 mins to put on.  Cotter pins, and then a 'wrap' secured with 5 screws.
    Jesse
    -2007-2008 XP Spyder
  •  01-27-2008, 12:31 AM 282270 in reply to 282265
    My splitter looks exactly like what you are templating, Chris. And in fact, APR should now have a suitable pattern on file ;-).
    And I have a strangely similar wing as well (shorter pedestal, though, to comply with XP rules)....
    Jesse, I don't understand the pin & wrap mounting you are describing. By 'wrap' are you referring to a lip with five screws attaching the splitter to the air dam?
    -- Glenn
  •  01-27-2008, 4:53 AM 282278 in reply to 282270
    geewiz:
    -- Glenn
    The cotter pins hold the actual splitter up.
    The "wrap" we have is a separate piece of cotton belting material.  It sits perpendicular to the splitter surface, and covers the area between the bodywork and the splitter.  Hopefully that describes it, as I don't have any pictures handy.
    Of course, I'm awake before 5am because I'm going to an event this morning.... maybe I should bring my camera. :)
    Jesse
  •  01-27-2008, 9:50 AM 282287 in reply to 282278
    129STS:
    fuggin sucks... it is 20 degrees here... :(  i haven't run since topeka
  •  01-27-2008, 2:09 PM 282328 in reply to 282270
    geewiz:
    -- Glenn
    If anyone is interested, I can help with custom or off the shelf APR wings/splitters. We've been supporting the solo community with carbon fiber and aluminum aero APR parts, including the large custom SM/2/XP dual element set-ups. PM or email for racer's discount.
  •  01-28-2008, 12:13 PM 282406 in reply to 282264
    "SO... If I slice the cone in half, and the bottom stays in the box, no penalty right?"
    we thought about this with an a-mod car and some tight piano string across the front wing. and just drive straight through a slolam :)
    But i just looked in the rule book
    7.9.1  "...If the pylon is upset or totally displaced outside the penalty limit, two seconds will be assessed..."
    that makes it kinda gray. the rule says totally displaced. using this you could say the cone was not totally displaced.
    Alex Jones
    2007 A-Street Prepared GXP
    www.CrazyMonkeyRacing.com
    because 285's were not enough...
  •  01-28-2008, 12:27 PM 282411 in reply to 282406
    DrJones_CMR:
    no, but I am willing to bet that if cut in half, the pylon would be Upset.
    I agree the design is legal, just was a bit shocked at how big it actually was.  I trimmed it back a bit as I want to put an air dam around the front and that will make it a bit wider.  Prototype is cut out, but not attached yet.  The good news is you can get two of them out of one 4x8 sheet of material, but not one out of a 4x4 sheet.
    Chris
    51 SM2
  •  01-28-2008, 1:40 PM 282424 in reply to 282411
    Part of the downforce generated is the negative pressure on the underside of the splitter.  You want to maximize that area, go all the way to the wheel ceneterline, and as wide in between the wheels as you can.  Just 0.10 psi of negative pressure adds up to quite a bit as the number of square inches go up.
  •  01-28-2008, 3:22 PM 282432 in reply to 282411
    ChrisSwearingen:
     off topic -
    I have only seen a cone get cut in half once and the lower portion stayed in the box. Sure the cone was badly damaged before the impact and should have been replaced before the event. Still a funny story thought :D
    Alex Jones
  •  01-29-2008, 10:20 AM 282528 in reply to 282278
    So I did get around to snapping a picture of the "wrap".
    EDIT: the attachment won't work...
    http://img254.imageshack.us/my.php?image=picture001bh2.jpg  (copy and paste)
    Jesse
