I tried to put a Longacre Ignition switch on my 84 RX7 (IT7). I hooked the White/Red wire to brown power in wire. I hooked the Black/White to the yellow accessories wire and I hooked the Black/Yellow to the green starter button wire. When I flip the toggle switch I can tell the gauges are getting power. When I press the starter button, it sounds like the fuel pump is kicking on, but it is not spinning the starter. It almost seems like I need to hook both the Black/White and the Black/yellow to the yellow accessories wire, but then I'm not sure what I should hook the green starter button wire to.
Any ideas on what I have hooked up wrong?
Thanks, Gordon
