Dunlop Direzza Sport Z1
Last post 08-20-2008, 12:03 PM by Mooobunnny. 418 replies.
04-25-2008, 11:41 AM |
Crosser1
Joined on 02-24-2002
Austin, TX
Posts 218
Points 3,510
Re: Dunlop Direzza Sport Z1
I would advise you do a little more than just drive them to the event site if you want them good out of the box. You might consider finding an empty lot and do some skid pad runs in both directions. Additionally, if you have time I would do the skid pad runs then rotate the tires front to back and do the skid pad runs again to make sure they are wore in evenly. I would then drive them to the event. I doubt this will have tem completely smooth, but they will be better than just normal driving to wear them in.
04-25-2008, 12:34 PM |
Gimp
Joined on 11-09-2004
Odenton, MD
Posts 169
Points 2,350
turbohappy: Gimp:The event where I'm going to be using these first is about 160 miles from my house. Traditionally, I would just drive on the full treads to the event to remove the mold-release. Would you say this is too far for the shaved tires and I'm best off just letting the course do the work for me? It's a two day event, with 10-12 runs over the entire weekend (on a nice and grippy airport surface).
Depends on the car. My car doesn't wear tires evenly at all on the street so it isn't too helpful for me. If your tires wear evenly on the street, that would be fine.
Mine does not wear evenly in the front with all the negative camber... so that may be out... Crosser1:I would advise you do a little more than just drive them to the event site if you want them good out of the box. You might consider finding an empty lot and do some skid pad runs in both directions. Additionally, if you have time I would do the skid pad runs then rotate the tires front to back and do the skid pad runs again to make sure they are wore in evenly. I would then drive them to the event. I doubt this will have tem completely smooth, but they will be better than just normal driving to wear them in.
I like it, but with my work schedule I doubt I'd have time to take things that far. Looks like I'll just beat them up at the event, and flip front to rear on day 2.
Paul P.
Currently running a 1996 BMW 318ti in FSP Building a C-Prepared 1981 Camaro.
http://www.mewhiney.org http://www.teamziptie.com
04-27-2008, 7:03 PM |
gtitronic
Joined on 03-14-2005
Boulder, CO
Posts 90
Points 1,235
gtitronic:I just ran the 215/40-17 Z1's (pre-StarSpec) in STS yesterday for the first time on my 94 Integra GSR. I was VERY impressed with the grip of these tires. Even on my first run the rears heated up just fine (around 60' ambient temps, sunny, very windy). I ended up with about 35psi on all corners. Tires are mounted on 17x7.5 Rota Subzeros et45 (lightest of the non-ultra expensive 17x7.5 options at 16.4lbs)
in-car video (wind-noise, sorry) http://youtube.com/watch?v=hzVKarrfUng
I have a few more photos of my car on course and the front tires after 4 runs: http://apexracinggroup.com/eventmedia/20080420dicks.html
Results-wise, I placed 2nd behind a 90 Civic Si and scored 938points first time driving the car with this suspension and tire setup- my previous best STS finish in an 89 Si on Falkens I drove half a dozen times was 954 points a couple years ago.
-Kelly Rocky Mountain Region Solo / Time Trials Apex RacingGroup.com
04-30-2008, 2:03 AM |
DougM
Joined on 04-25-2006
Seatle, WA
Posts 41
Points 560
some "hard data" concerning width
I recently mounted up the Direzza Star Spec 225/45/17 on a 7.5" wheel (STS Subaru)
-vs-
the Yokahama Neova, 225/45/17 on the same wheel (BBS)
the Dunlop was about an 1/8" wider
that's all I have for now... racing this weekend, more later
NWR#56STS
04-30-2008, 3:05 AM |
Rocky
Joined on 02-28-2008
Texas
Posts 56
Points 1,105
FWIW, this past weekend, with temps in the lower 50's (maybe even down into the 40's with the horrible wind chill factor???), vwawd and his co-driver, as well as myself in STX did quite well with our unshaved Z1's. They are totally fantastic! And even though I had to wait a very long time between runs so the tires never heated up at all, they still stuck like glue and were very impressive! Can't say much about the wear, as I can't tell where they WERE wearing from the course, because the sides of the fronts got a bit chewed up from when I tracked in at MSR some weeks back. But they felt so very good out on the course! As I learned both the car (new setup) and the tires, I was able to shave a touch over 4 seconds from my first run by my last run. As luck would have it though, we did not (THANKFULLY!!!) have the chance to test how well they would have done in the rain, because by the time it was our turn, the course dried up real nice. But the poor STU guys in the morning, were having a heck of a time. Some spots there were even standing deep puddles they had to drive through. But if the STU guys felt at least their last runs were on dry enough pavement, then you can say that STX beat them for once. But also within STU, Paul Magyar's STi with the Z1's beat Henry Lin's STi on RE01R's by about 1.1 seconds.
Now for the Tour this weekend!!!!!!!! :)
04-30-2008, 12:02 PM |
SS RX7 R2
Joined on 03-26-2003
Irvine, CA
Posts 183
Points 3,645
Gimp: turbohappy: Gimp:The event where I'm going to be using these first is about 160 miles from my house. Traditionally, I would just drive on the full treads to the event to remove the mold-release. Would you say this is too far for the shaved tires and I'm best off just letting the course do the work for me? It's a two day event, with 10-12 runs over the entire weekend (on a nice and grippy airport surface).
... If your tires wear evenly on the street, that would be fine.
So how did it go? I had a 318ti club sport. Neg camber shouldn't cause excessive street wear, it's probably due to an aggressive toe setting.
04-30-2008, 1:11 PM |
Gimp
Odenton, MD
Posts 169
Points 2,350
SS RX7 R2: Gimp: turbohappy: Gimp:The event where I'm going to be using these first is about 160 miles from my house. Traditionally, I would just drive on the full treads to the event to remove the mold-release. Would you say this is too far for the shaved tires and I'm best off just letting the course do the work for me? It's a two day event, with 10-12 runs over the entire weekend (on a nice and grippy airport surface).
Hasn't happened yet... this coming weekend... should be interesting... I kinda already know I'm going to win my class, but that's typical where I'll be racing this time of year (faster cars and better drivers will be at other events)... that, and one of my known competitors has only raced 2 times before in a very under-prepped hyundai, and my other known competitor will be in a very under-prepped auto Honda Fit, and I plan on sleeping with her the night before to throw her off her game (girlfriend). I would have loved a club sport, but those things are getting harder to find. This is a 1996 m-tech package car. It's my daily/autocross hold-over while I finish my C-Prepared car.
Paul P. Currently running a 1996 BMW 318ti in FSP Building a C-Prepared 1981 Camaro. http://www.mewhiney.org http://www.teamziptie.com
04-30-2008, 2:33 PM |
ibaker
Joined on 02-10-2004
WDCR
Posts 149
Points 3,005
Ok, so some interesting information here on the Z1..... If you take a look at the DOT stamping on the sidewall you will notice that the 2 letters after the DOT are V4. This 2 digit code stands for the manufacturer of the tire. Oddly enough, this is the same code that is present on the Falken Alenis 615. It traces back to the Japanese manufacturer ad the exact same address, which is listed below. This means both tires are produced in the same exact factory.
Ohtsu Tire and Rubber 3 Tohoku-Cho, Miyakaonojo City, Miyazaki, Prefecture, Japan, 885 According to the Goodyear rep they have no connection with Ohtsu, so who knows. Does anyone else have the same codes on their Z1's and 615's?
Interesting times these are for street tires... Ian
05-04-2008, 10:31 PM |
Toecutter
Joined on 06-18-2007
Kewaskum, WI
Posts 23
Points 410
My RT615s were apparently made in the Ohtsu plant as well. In
2003 Ohtsu was absorbed by Sumitomo Rubber. One of Sumitomo's
divisions is Dunlop Falken Tyres Ltd. So it does not surprise me that
the RT615 and Z1 would be manufactured in the same plant. Also, Goodyear may not have any connection with the Ohtsu plant, but Goodyear Japan is also a division of Sumitomo Rubber.
Paul Greif 927 STS 2006 Hyundai Elantra GT (2,800 lb. nose-heavy pig) http://www.elantraclub.comhttp://www.scca-milwaukee.org/
05-05-2008, 10:00 AM |
Mooobunnny
Joined on 05-29-2007
Posts 166
Points 2,875
Yesterday was the second event on these tires, but the first event where we got the pressures right. These tires seem to work very well. I have not had time to dig into the datalogging from this weekend to that of two weeks ago on the same sight with RE-01R's. Hopefully I will get some time to do that this week.
05-05-2008, 12:57 PM |
ada///M
Joined on 02-21-2008
SW MI
Posts 10
Points 215
these tires were DOMINANT this weekend at Minnesota's first 2 big events of the year. Many teams that visited nat's last year tried both neovas and dunlops and said the dunlops were far superior. Teams to note were the Washburn/Deutsch pair in STU and the Tovsen/Wrolson 2007 STX runner-up 3 series. It took me until the 2nd day to get my tire pressures right but I ended up at 39/38 on a BS street tire E36 M3. I have 245/40/17 Z1 * spec all around.
05-05-2008, 1:17 PM |
Patrick Washburn
Joined on 12-27-2000
Wausau, WI
Posts 2,003
Points 29,500
One note, we did not get back to back testing done. We broke the car before we could do this. :)
Also newly shaved Yoks, in my experience anyway, totally suck the first event. They get better after, but I've done this with three different sets, and they've felt like greasy crap the first day. These were not terrible, but definately not the best either. We were just trying to scrub them in before doing real testing in Milwaukee. My early take is the Z1's are competitive without a doubt. When it comes to shaking that last couple tenths............we'll see.
Patrick Washburn Lucky Lugnut Racing SoloPro Driving Schools Red Eye Brewing Co
05-05-2008, 2:24 PM |
Gimp
Odenton, MD
Posts 169
Points 2,350
I'm no where near a top-tier driver or do I have a top-tier car, but I'll add in what I know so far... This weekend was my first weekend on the tires. 225/50R16 shaved to 5/32. I did not break them in on the street. Just arrived, bolted them on, and went. I have between -2.5 and -3.0 camber up front. My pressures **seemed** okay at 36 front, 33 rear. That seems low compared to others out there. I did not have pyrometer, so I couldn't get any good measurements, but the fronts and rears seemed to be rolling over to where they are supposed to. **SIDE NOTE - does anyone have any suggestions for pressures? Am I way off?** These tires felt GREAT. I was on a RT-615s before, but these are so much better. I'm still waiting on the PAX results to get posted (my class was not strong this time around... I won both days, but PAX will be a better indicator). I was about 5-6 seconds off FTD. I'll post those up with my maxqdata logs later when I have them.
Page 21 of 28 (419 items)
... 21 ...
