Where to find a good C-Mod car?
Last post 03-03-2010, 9:34 AM by GEH. 32 replies.
11-19-2009, 9:47 AM |
notstock
Joined on 11-20-2007
Posts 85
Points 1,460
Re: Where to find a good C-Mod car?
you are correct , I was just pokeing at jim G just to be annoying . 8>)
jg
11-19-2009, 10:36 AM |
Jim G
Joined on 12-15-2005
Posts 675
Points 9,000
notstock:
And Jim G figured that out in about 0.3 seconds and laughed (at you, not with you).
Jim "Those are my principles, and if you don't like them ... well, I have others." -Groucho Marx
11-20-2009, 2:01 PM |
notstock
Posts 85
Points 1,460
thats cool , i figured you would get a chuckle out of it .
jg
11-21-2009, 11:57 AM |
Jim G
Posts 675
Points 9,000
The owner just lowered the price of this car: http://www.apexspeed.com/forums/showthread.php?t=36633 over $13,000 in this car but reducing the price from
$10,000 to $9,700 including all the spares and extra sets of wheels
FS: 1979 Lola T540
Car make: Lola
Car model: T540
Car year: 1979
Class: FF/CF
Condition: Good
Roller or turnkey: Turnkey
History: This
car has been raced in the Rocky Mountain Region for many years.The car
was purchased at the beginning of the 2009 season. The car ran in both
SCCA and RMVR events in 2009.
Features, specs, options
The following is a list of specs and spares and what has been done to the car, by a professional race shop, since purchase:
- 1979 Lola T540 - Chassis #83
- Bradford Precision Engine – ~ 25 hours
- Updated Frame/Cage
- Transponder #1637233
- FIA Harnesses 2010
- 2 Sets Aluminum Wheels (8 tires with plenty of tread left)
- 1 Set Original Steel Wheels - Red
- 2 Noses, 1 Original V-shape, 1 Shark-in need of repair
- 2 New Spliters
- Several Extra Gear Sets
- Suspension Spares
- Miscellaneous Spares
- Quick Lift Jack
- 7" Chassis Stands
May-July 09:
- New Battery
- Updated and Rebuilt Carb
- Rebuilt Shift Linkage
- New Gears installed: 17:35, 19:31, 22:29, 25:27
- New Transmission Dog Rings
- New Mirrors
- New Oil and Fuel Lines
- New Ignition Coil, Rotor, Cap, Plugs and Wires
- AIM Digital Dash - Mychron 3 Gold
Sept 09:
- New Brake Rotors, Caliper Seals, Pads, Master Cylinder
Asking price: $10,000
Contact phone: 303.475.8818
Contact e-mail: dlongwell27@gmail.com
Contact location: Colorado
01-01-2010, 2:40 PM |
Jim G
Posts 675
Points 9,000
Another great FF for sale over on ApexSpeed. Here's the info: After much consideration I am putting my 93 Vector FF up for sale. This
is not a fire sale so please no insulting offers. I am just thinking my
racing money might be better spent somewhere other than the SCCA.
The Vectors are great handling, light weight and fast. I have 20 lbs of
lead in the car and I weigh 205lbs. I ran 8 nationals this year, 8
poles, 5 wins, 2 seconds, and 1 DNF (battery cable came off). Finished
8th at the 09 run-offs. Do not let the mon-shock scare you, the set up
the Vector uses works extremely well.
- The car has a 3 race old strong Farley Motor rebuilt 6/09
(motor has the new .005" forged pistons, stock rods and stock crank,
matching BLC iron head[with all new valves], intake and carb, crane
ignition).
- Double adjustable Penske shocks serviced the first of this year
brand new Two Dogg Inc drive shafts being made right now Installed a new lightened 10:31 r&p on a lightened steel diff before the run-offs spare wishbones: 1 upper front universal
wishbone, 1 upper rear universal wishbone, 1 each R&L rear lower
wishbones, 1 right front lower wish bone 1 front and 1 rear new spare uprights 1 front and 1 rear push rod, 1 track rod 2 extra sway bars 8 gear sets 2 spare rotors 2 spare half shafts/drive shafts 2 sets of BBS wheels one session used rain tires bought new 4/09 one set of dry tires with 15 minutes of qualifying (run-offs) on them there is a spare set of unknown brand shocks 3 sets of springs 2 spare noses (3 total including the one on the car new slave cylinder piston and throw out bearings new master cylinders 1/09 fuel cell re-foamed 1/09 3 of the original Vector wheels 9using two of them for paddock wheels with big tires on them plenty of minor spares as well:c/v joint, clutch
disks, throw out bearings, master cylinders, a wheel bearing or 2, a
couple of sets of 2 session run-off tires and a lot of misc stuff.
The car had a 14 year break from 1995 until I bought it in
January, still on the original log book. Some of you will remember it
on E bay. I went through the whole car before I raced it and rebuilt
all the hydraulics, replaced all the plumbing, new wheel bearings. and
put together a great spares package. The only thing I still want to do
is put new bushings in the steering rack and get a new header (has the
original steel step header).
There are some previous repairs on the bell housing (nicely done) and
one of the front lower wishbone mounting points was repaired or
reinforced, not sure which. The belly pan (stainless steel) has its
share of curb rash as well.
I will get detail pictures of anything somebody might want and email them to you, just ask.
$16.5K or respectable offers?
Thanks
Darren Brown
darrenbrown97@tx.rr.com
01-03-2010, 9:12 AM |
Jim G
Posts 675
Points 9,000
$9750 Completely redone frame up by a guy in my region. Can easily fit big/tall driver. Former Solo car.
For more info, see http://www.apexspeed.com/forums/showthread.php?t=35669 4 Sale by Tod
Home 203-938-4110
cell 770-316-6445
01-03-2010, 11:00 AM |
Patrick Washburn
Joined on 12-27-2000
Wausau, WI
Posts 1,904
Points 27,390
Geoff, Having been in your position in the past, all I can do is encourage you to go ahead with this. CM was an absolute blast!! I miss my Swift all the time. I never really felt I was getting everyhting out of it, and my finishes were su-par in my opinion, so I eventually bailed after three awesome years. (I needed a car for my daughter to learn in too....that was a big part of my decision) Anyway, playing with a "real" race car was a joy. Basically put gas and oil in and drive like mad. It was a lot of fun learning all the in's and out's too....lean on the current CM guys here...they were always an invaluable resource. You will be welcomed into a great class by everyone and get a lot of support. Oh...the co-crive idea is a solid one. Most CM drivers can benefit from a co-driver, and if you can find a seat you will get some exposure to the class with minial investment. Anyway...good luck!!!!
Patrick Washburn Lucky Lugnut Racing SoloPro Driving Schools Red Eye Brewing Co
01-26-2010, 11:06 AM |
Jim G
Posts 675
Points 9,000
RF-85 for sale
http://www.apexspeed.com/forums/showthread.php?t=34513
Hey Folks, I have a new E-mail address. bozeman22@gmail.comThis car took a hit in the right side, destroyed the radiator and bent a couple of frame tubes. Very easy repair, no twist in the frame. [See update below - has been repaired.] I would like to sell the complete car but if need be I will part it out starting next week. I did a total restoration two years ago. All new fasteners, plumbing, wiring along with most of the fiberglass. Both rear stub axles (in the uprights) were replaced just last year. Stock dash was replaced with a MyChron 3 Gold data logging dash. Penske 8100 dampers. New Tilton master cylinders. Very strong Ivey engine with five race weekends and two test days since total rebuild. Rebuilt gear box, all new bearings. Nice shifting box with several sets of gears. Some spare A-arms (front & rear). Spare ARBs. two rear uprights (both need repairing). CV joints. Nice open trailer. Plus other odds & ends. If anyone is interested in a simple project this might be it. Open to offers. John Update: I have repaired the frame and replaced the radiator (at the tune of about 2K) so all that is left to do is some minor fiberglass work. New price is $9800.
01-29-2010, 7:33 AM |
GChambers
Joined on 11-12-2004
Indy, In
Posts 1,361
Points 20,930
We're out here and we're still looking. Trying to clear out some of the other racing stuff we've acquired over the years to make room for the car. It still may be a while until we're in a position to buy.
90 Miata - STS #90/190 If it aint broke, don't fix it.
01-29-2010, 10:42 AM |
Jim G
Posts 675
Points 9,000
Good luck in making room and finding the right car!
02-07-2010, 8:43 PM |
Jim G
Posts 675
Points 9,000
Long time Nationals C Mod car for sale on eBay
Bill and Linda Smiley are selling their Van Dieman Formula F. This car is ready to win right now. The buy-it-now price is only $8500 $7995. If I was trying to get started in C Mod, this is what I'd buy. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270527479280
02-15-2010, 12:16 PM |
Jim G
Posts 675
Points 9,000
Re: Long time Nationals C Mod car for sale on eBay
Price on the Smiley's car reduced to $7995 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270527479280&ssPageName=ADME:B:WNAFP:MOTORS:1123
02-16-2010, 3:08 PM |
amaff
Joined on 09-01-2006
Atlanta, GA
Posts 209
Points 2,695
I wonder if they'd consider trading for a well sorted STS car?  That's a deal right ther
Andrew Maffessanti STS 114 - 1992 Miata Blk Atlanta Region SCCA
02-20-2010, 5:14 PM |
Clemens
Joined on 08-03-2009
Noblesville/IN
Posts 94
Points 1,860
Jim G:Price on the Smiley's car reduced to $7995 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270527479280&ssPageName=ADME:B:WNAFP:MOTORS:1123
According to the listing, it sold for $7000. I wonder if it went to a Solo person. I believe this was actually the Smiley's old car, which they sold maybe three years ago. They ran Nationals in a Tiga in 2007. Clemens
Page 2 of 3 (33 items)
2
