Blytheville Pro Solo Index Results
Last post 06-22-2009, 10:53 AM by Dave Schotz. 26 replies.
Page 2 of 2 (27 items)   < Previous 1 2
  •  06-09-2009, 6:42 AM 364491 in reply to 364454
    Re: Blytheville Pro Solo Index Results
    ron:
    I got to say that the HS change is wrong in so many levels, This particular pro had no long straight for the faster cars to take advantage of and HS ended up doing ok in the pro index. But... your rtp index places the top two drivers in the pro index way below many other classes that had multiple drivers in higher spots. SS had three above the top HS driver. I would agree HS should have been changed slightly, but, about half of what it actually did change. Again multiple drivers at nationals per class were ahead of the top drivers in H and yet the index changed. Now H cars don't have a chance in haiti's  to win the index. Just an opinion of course.
    Thanks for all you do Rick
    I apprecitae the thanks, Ron, and thanks for noting the errors in my original posting.
    At this Pro, on the Left Side, Shawn Hill (in H Stock) finished a little over 1/2 second behind the top spot, on the PAX/RTP Index, in 15th position.  He was ahead of the winners in BS, DSP, ASP, FSP and only a little (less than 2 tenths) behind the winners of SSM, SS, and ES.  Can't find too much wrong with that -- and, on a different course, on a different day....
    There were 43 drivers within one (index time) second of the top spot.  These represented -- SS, AS, BS, CS, DS, ES, HS, ASP, BSP, DSP, FSP, SM, SSM, EP, GP and DM.  All except 6 of the Open Classes in attendance, all within one second (there were a couple of Ladies Classes in there too).   Hopefully, enough said.   Big Smile
    H's & K's,
    Rick Ruth
  •  06-10-2009, 8:39 PM 364741 in reply to 364491
    • ron is not online. Last active: 03/20/2010, 5:31 AM ron
    • Top 200 Contributor
    • Joined on 03-03-2003
    • Topeka Ks. U.S.
    • Posts 464
    • Points 7,610
    Well, you can't say that you aren't a professional of your pax craft, excellent  response. I just hate to loose, so I complained.
    Ron Williams
    Multi-time national champion
  •  06-11-2009, 5:48 AM 364772 in reply to 364741
    ron:
    I frequently suffer from the same issue.  Sad
    H's & K's,
    Rick Ruth
  •  06-11-2009, 1:03 PM 364829 in reply to 364772
    • edj is not online. Last active: 03/19/2010, 1:20 PM edj
    • Not Ranked
    • Joined on 10-25-2004
    • Austin, TX
    • Posts 75
    • Points 890
    does Darrin have the RT/60ft times available?
  •  06-11-2009, 4:31 PM 364858 in reply to 364741
    ron:
     Ron,
    I'm sure you understand that the RTP/PAX index doesn't take into account the standing starts of a Pro, and those SS Elises were probably putting 2 tenths per side on you by 60 feet. Subtract that from your index results and that puts you roughly in a tie with Matthew Braun. I don't know about you, but to me, PAXing right with Braun is just not a real strong argument for the PAX index being too hard on HS.....
    Wink
    Edit: Oops, my mistake. Looking at the actual 60 foots, it was really 4 tenths per side, which means the two highest finishing stock class cars at the event were both in HS (when taking this into account). Yep, HS has it pretty tough!
    sorry, couldn't resist. Congrats on a nice finish. Yes
    Gary T
  •  06-11-2009, 4:46 PM 364862 in reply to 364829
    edj:
    The RT/60Ft Times are on the web site with the results from Blytheville.  The are under the results, under the 2nd FINAL RESULTS link.
    Just in case here is the direct link:
    http://scca.com/documents/resultfiles/13627_blytheville,%20ar%20Rt_60%20ft.pdf
    Darrin
  •  06-21-2009, 9:44 AM 365681 in reply to 364862
    Anyone else getting an error trying to open page 1 of this thread?
    Jesse Caudill
    74 ST
    Colorado Region/Continental Divide Region
  •  06-21-2009, 1:39 PM 365688 in reply to 365681
    proxenus:
    YUP.
    Bob Buxbaum
    Lee's Summit, Mo.
    Can't wait for Lincoln 2010 !!!!!
  •  06-21-2009, 4:00 PM 365700 in reply to 365688
    Unfortunately I don't think I can fix the problem anymore. trying to see if I still have the ability to
    buy my book
    project350z.com
  •  06-21-2009, 6:31 PM 365713 in reply to 365700
    Thanks guys... we'll figure out what's up with this one tomorrow morning, if Chris hasn't found a way to fix it tonight.
    Please keep letting us know of anything else you may find!
    Dave
    Cars: '01 LS1 Formula / '89 1LE IROC
    Class: CMC-2 / CMC
    Car No#: 34 / 75
    KUMHO TIRES / CARBOTECH BRAKE PADS / HP234.com Lubricants /
  •  06-22-2009, 5:28 AM 365754 in reply to 365713
    Dave Schotz:
    Dave
    Thanks for working on it. I know how frustrating these things are. The Finger Lakes results thread gives the same error.
    Jesse Caudill
    74 ST
  •  06-22-2009, 10:53 AM 365841 in reply to 365754
    Thanks Jesse... both are working now again! Smile
    Dave
    Class: CMC-2 / CMC
    Car No#: 34 / 75
