harts:their was no offset at all , they were all lined up straight unless someone moved them after i layed them out,, for me i don't think this thing drives much like what a regular slalom does with the 55 ft gap it seems like it would be slow but then you got 40 feet to gather the car back up before the next 55ft gap, this is a very interesting feature that i have not seen before and was a lot of fun, and something different that was not painfull to drive ,, all the measurements were from center line to center line of each cone and were with an inch of each other
This explains the course dependency theory/conspriacy thing too
Mr. Harts. Hence why you and Wes were right in the meat of your gear vs David, Jack and I.
Plenty of people will verify that my Civic was HAMMERING on the rev limiter from the end of the very first wall of cones (58mph actual) on my first and third runs. My co-driver short shifted into third at 54 and held his foot to the floor on all three of his runs and I did on my second run. When I looked at my speedo at the end of the slalom on my second run to verify speed, I was showing 66mph which is 3.4 mph fast with my tire sizing to really see if the shift was worth it. I personally never lifted through that section on any of my three runs regarless of speed. Had I have started that section slower, I wouldn't have hit the limiter and had the surface been asphalt...no way would I have been able to hold it.
As an up & coming course designer, I am learning that such elements are kick-ass fun...as long as they are safe.
D. Scott Bourne
192HS
DATS Racing LLC
Kumho Motorsports
Ken Towery's Motorsports
Tokico USADATS Racing, All DATS, All the time!
