Brake Controllers
Last post 07-25-2008, 3:50 PM by car39. 35 replies.
08-02-2007, 8:54 PM |
rjohnson
Joined on 07-16-2007
Posts 19
Points 305
As so many have said, the Prodigy is far better than anything else
available in the aftermarket.
However, after *many* miles in an 08 F450 w/15,000# +/- trailer, the Ford OE system
outshines even the Prodigy. It's awesome!
-Roger (O)
08-02-2007, 10:10 PM |
Phillip S. Osborne
Joined on 02-12-2005
Nicholasville, KY
Posts 501
Points 3,610
Hmmmm, new truck Roger?
Phil O.
Roger wrote: However, after *many* miles in an 08 F450 w/15,000# +/- trailer, the Ford OE system
OzCop "It's never too late to have a happy childhood."
08-03-2007, 8:16 AM |
Keith Casey - IMHO...
Joined on 12-27-2000
Somerset MA
Posts 1,556
Points 21,045
rjohnson:As so many have said, the Prodigy is far better than anything else
-Roger (O)
"I bought a brake controller, and I got a truck with it?" ;)
"Engine and transmission must remain unmodified, including emissions equipment, except as noted below"
08-07-2007, 1:54 AM |
TeamRX8
Joined on 04-18-2003
Posts 1,585
Points 21,615
I grew fond of this Reese controller because it has a detachable hand operator that allows me to hide the unit under the dash, the hand controller will proportionally operate the trailer brakes only when needed - it is a real blessing in stop & go traffic if the interstate backs up ...
but then I'm only in a toy truck ...
http://www.hidden-hitch.com/prod.asp?pc=5510
the Brake Smart line pressure setup sounds interesting
08-17-2007, 11:39 AM |
autoxgod
Joined on 08-14-2002
desplaines, il
Posts 290
Points 3,050
Re:Prodigy Brake Controllers
For those who are using the Prodigy controller, what is your setting for full load? I have tested mine yesterday following the procedure and I wasn't able to achieve lockup but sure stopped fast and smooth. I'm at about 9.9 on the controller and b3.
I think it might be time to adjust my brakes on the trailer.
Jim
08-17-2007, 12:17 PM |
SpyderVenom
Joined on 01-11-2001
Southeast, PA
Posts 1,393
Points 18,560
Re: Re:Prodigy Brake Controllers
That would depend on your truck, trailer, trailer tires, and load. B3 is a lot of brake boost. I tend to run B1 on back roads and without boost on the highway.
If you can not achieve lock-up on your brakes, you need to have them looked at.
09-04-2007, 12:32 PM |
autoxgod
desplaines, il
Posts 290
Points 3,050
I adjusted the brakes and they now stop better than before. Once in a while I get a full 13 on the scale but then it settles down. I wonder why this happens? Only seems to happen when I'm coming to a slow stop at an incline. I'll try repositioning the unit to a more level position.
12-05-2007, 10:14 AM |
jdchristianson
Joined on 08-19-2001
Mechanicsville, Iowa
Posts 48
Points 500
Just Curious, is everyone still happy with the Prodigy? I just switched tow vehicles and need a new brake controller. The old one went with the old Suburban. That was the 3rd vehicle it had been in, and time to be replaced as I'm tired of trying to adjust and going from almost no trailer brakes to nearly bonking my nose on the streering wheel.
Is there anything new that is better?
Jeff Christianson
12-05-2007, 11:48 AM |
SpyderVenom
Southeast, PA
Posts 1,393
Points 18,560
jdchristianson:Just Curious, is everyone still happy with the Prodigy? I just switched tow vehicles and need a new brake controller. The old one went with the old Suburban. That was the 3rd vehicle it had been in, and time to be replaced as I'm tired of trying to adjust and going from almost no trailer brakes to nearly bonking my nose on the streering wheel.
??? You weren't getting good brake control with the Prodigy? [edit: Still have and enjoy mine. I haven't changed it.]
12-05-2007, 12:40 PM |
BigEnos
Joined on 07-16-2004
Sykesville, MD
Posts 252
Points 3,215
SpyderVenom: jdchristianson:
Mine works great. I like that I don't really notice it, and yes I periodically give it the manual brake test to see if it does and I can always feel the brakes kick on.
I also like it's ability to do some limited troubleshooting. Strano hooked his trailer to my truck once to figure out his no brakes issue. Turned out it was the dreaded "Econo-Trailer Axle Wire Short".
Brian "Big Enos" Burdette
12-09-2007, 11:06 AM |
jdchristianson
Posts 48
Points 500
Nope, I must not have been clear. My old controller was not a Prodigy. It was over 10 years old and not always working the best. I was just curious if the Pordigy was still one of the best, before I buy a new one.
Jeff Christianson
12-09-2007, 11:14 AM |
SpyderVenom
Southeast, PA
Posts 1,393
Points 18,560
It sounded like you sold it with your old truck. I still love my Prodigy. Tekonsha came out with a P3 product that is complete overkill - so if this one every goes belly-up, I might try that one.
12-09-2007, 8:15 PM |
atcovan
Joined on 09-27-2007
North Highlands, CA
Posts 72
Points 1,110
Another vote for the Prodigy. I had one in an F150 towing a 12' open 2-axle and a Miata, then moved up to an Excursion and 18' enclosed 2-axle with a Z06. In each case, it always gave reliable, predictable braking action. I also helped a neighbor move all their household stuff in my enclosed trailer all the way to Arizona. Mind you, I had up-rated the tires to 225 Goodyear Marathons as a matter of good course and was astonished when I ventured into a Flying-J to learn our loaded weight, Excursion and trailer, was 19,990 lbs! The turbo-diesel didn't even breathe hard and the tires/wheel bearings didn't get hot. The point I'm making is the Prodigy had adequate adjustment to apply those brakes hard enough and totally smoothly enough to control over 10,000 lbs of trailer.
James Plotkin '05 FSP Echo
04-21-2008, 4:57 PM |
jungle
Joined on 02-14-2006
minneapolis
Posts 8
Points 55
Is the Tekonsha P3 worth the extra money over the Prodigy?
tia...
aaron... http://testsvr.sabis.com http://www.volksport.org 1996 GTI VR6 SM 1995 Neon ACR ITA/PTE 1998 Audi A4 1.8tq kO4 1995 Dodge Ram 1500
07-25-2008, 3:50 PM |
car39
Joined on 04-18-2005
stuck behind a desk
Posts 2
Points 10
I bought a Prodigy after reading the board. Tuesday, coming home from PA, the state of CT decided to block off two of three lanes on I-84 by parking a truck in the middle of the lanes around a blind corner. Tractor trailer to my left, state truck dead ahead, not enough room to go to the far right. I stood my 99 Navigator with a 20 foot enclosed Carmate trailer loaded with tires, tools and a CSP Miata on it's nose. Stopped straight, true, no drama. Eighteen wheeler flys by me at 80 to make room in the left lane, I flick 40 feet of vehicle into the left lane, and avoid causing the state workers in the truck from waking up. If I had my old Hoppy controller, they would still be picking aluminum out of my butt, and grille pieces out of my teeth. Good recommendation.
there is no fool proof, idiot resistant is the best you can hope for
Page 2 of 2 (36 items)
2
