Ford EGT and Focus in FSP, but ZX2 in DSP :-/
Last post 05-19-2008, 4:34 PM by conecrusher. 29 replies.
04-11-2008, 11:09 AM |
W_kalman
Joined on 03-24-2005
Los Angeles, CA
Posts 50
Points 325
Re: Ford EGT and Focus in FSP, but ZX2 in DSP :-/
For you guys taking BG chassis to FSP, my Escort GT has been retired from competition and the suspension is for sale. <wink><wink>
Took 6th in FSP at Nationals in STS trim with R tires.
Will Kalman '07 Civic LX - HS
04-12-2008, 7:37 AM |
zxtwou2
Joined on 01-15-2008
Morton, IL
Posts 27
Points 495
ebnrt:
zxtwou2:^just curious....but if you are going FSP, what are you going to do about your open diff? i know there are a few options, but most of them just aren't tried and true. the phantom grip isn't a true LSD, the MazdaSpeed Protege has a weak bull gear shear problem (at least the older ones do), and Quaife backed out on making the 30 units they were going to do. i'm only curious because i'd like to go the route of FSP, but feel the car really won't be competative without the LSD. if i can find out what more people are going to do, maybe i can start getting the ball rolling on moving out of STS.
I have not researched this, Tim. I know there are BG Proteges out there in FSP, and BJ cars as well--in fact one trophied last year. To be honest, I dont even know what transaxle series the ZX2 has...though I would assume it to be the same as the Proteges. Can you shed any light on this?
http://www.mazdas247.com/forum/showthread.php?t=123669982 for the BG car.
http://www.mazdas247.com/forum/showthread.php?t=123669982 for the BJ car.
I suspect that the MSP is the unit being used most often. That is a 200+ ft/lb motor...we'll be far below that, and as such I suspect that the MSP LSD would suffice.
not sure what you mean by BG and BJ. we do have the protege transaxle, but not the mazdaspeed protege. it's the G5MR...with 2 spider gears instead of the 4 that comes in the Ford Escape equipped with the zetec. if i remember right, the MSP LSD swaps in, but you must get axles made with the correct number of splines.
04-12-2008, 9:00 AM |
moxnix
Joined on 06-15-2004
VA
Posts 442
Points 5,315
zxtwou2:not sure what you mean by BG and BJ. we do have the protege transaxle, but not the mazdaspeed protege. it's the G5MR...with 2 spider gears instead of the 4 that comes in the Ford Escape equipped with the zetec. if i remember right, the MSP LSD swaps in, but you must get axles made with the correct number of splines.
BG - First gen protege (89-94) (or something close to that)
BJ - Third gen protege (99-03) The mazdaspeed protege uses the G15M-R I think it has a little different gear ratios than the G5MR. Ratios on the G15M-R are 1. 3.307:1 2. 1.842:1 3. 1.310:1 4. 0.970:1 5. 0.755:1 FD. 4.105:1 R. 3.166:1
STS2 - 1990 Mazda Miata
04-13-2008, 5:36 PM |
cone-cerned
Joined on 10-09-2005
Posts 5
Points 100
The open diff, with no LSD available, is what kept me from going to DSP with my S/R. Instead, I bought a Miata and am running in ES. But now I'm thinking about FSP even without the LSD. I need to reread the SP rules and do some budget analysis.
Doug Covington ES 12 '94 Miata M Editiion
04-14-2008, 2:04 AM |
04-14-2008, 9:28 AM |
ebnrt
Joined on 04-20-2004
East Troy
Posts 337
Points 4,905
I thought I read somewhere that Kia Sopheia axles work on the ZX2 with MSP diff... I haver heard nothing good about the PG. I'd run an open diff before that. Nonetheless, its not a top priority for me at the moment...keep in mind that you can still get in the National trophies w/o one (see Will's post above). I finally get to drive my car this weekend...and then the sorting begins.
04-14-2008, 4:08 PM |
gavin
Joined on 10-17-2003
Santa Cruz, ca
Posts 153
Points 2,065
Im not too familliar with the zx2, but if it uses the mazda based transmission it would be the 10-bolt diff G-type of the 3rd gen proteges/2nd gen Probe/MX6 (2nd gen protege(1.6l?) used a J-type transmission?, Id have to check on that)
Gavin
05-19-2008, 4:34 PM |
conecrusher
Joined on 06-13-2002
carleton, mi
Posts 74
Points 1,430
Very good input on the LSD. I, too, see the LSD as a limiting factor for the ZX2.
But I think the saving grace may be the "low" power output of the ZX2. The aforementioned MSP LSD would work, with the prescribed modifications to the axles (which I'm not sure of legality in SP). I don't think you could get the Z to over-power the MSP diff.
I've begun "parting up": Momo steering wheel, 22mm adj. RSB, Kamikaze header (on the car when I bought it), Porterfield pads, etc. Due to an unforeseen circumstance, it looked like our (mine and my wife's) season was not going to be, but we may now be able to get some events in.
Has anybody been able to run on R-compoounds and compare times to FSP cars?
Brandon NWOR
Page 2 of 2 (30 items)
2
