Splitter Clarifications
Last post 04-30-2008, 6:49 AM by Joe_914. 38 replies.
02-13-2008, 8:35 AM |
Patrick Washburn
Joined on 12-26-2000
Wausau, WI
Posts 1,402
Points 17,995
Re: Splitter Clarifications
ErikZ06:
Julia,
That picture shows a splitter not conforming to the rules, but Vic may have trimmed things down since that picture.
Erik
Agreed:
M. Front splitters are allowed and shall be installed parallel to the ground (within +/-3 degrees fore to aft) and may extend a maximum of 6 inches forward of the front bodywork/fascia as viewed from above. Splitters may not extend rearward past the centerline of the front wheels. No portion of the splitter may extend beyond the widest part of the front bumper/fascia as viewed from above.
02-13-2008, 10:13 AM |
jaebers
Joined on 08-12-2003
Floyds Knobs, IN, USA
Posts 27
Points 495
Thanx guys. This answers my questions and I am going to use approach A from my first post. Julia
Julia Aebersold 97 SM 97 Supra Turbo
02-13-2008, 12:35 PM |
boxboy
Joined on 06-27-2001
Posts 259
Points 4,315
It's actually hard to tell in the picture of Vic's car as it is a bad angle. You'd really need to look at it from above, as the bodywork right at the splitter might be farther in than above.
-Andy M.
02-13-2008, 1:54 PM |
siastuning
Joined on 03-01-2004
NorCal
Posts 49
Points 730
boxboy:It's actually hard to tell in the picture of Vic's car as it is a bad angle. You'd really need to look at it from above, as the bodywork right at the splitter might be farther in than above.
-Andy M.
Thanks Andy ;-) Some of you guys need to apply for the SMAC, we could have used the different points of views you all have. ;-) So when we wrote this (cough) LAME rule my car was the only one with a real splitter. So when I envisioned the rule as we wrote it I was thinking of B and MAYBE even C, But for sure NOT A. A is reading WAY to much into it. With B you could take a ruler and go to any point of the bumper/facia and measure 6" out on any part of the FRONT bumper. DONE! I guess we need to clarify this officially.
Vic Sias 650-704-0771
02-13-2008, 2:42 PM |
modernbeat
Joined on 06-30-2004
Houston, Texas
Posts 673
Points 6,785
siastuning:...So when I envisioned the rule as we wrote it I was thinking of B and MAYBE even C, But for sure NOT A. ... I guess we need to clarify this officially.
Go for it. D-Mod, E-Mod and X-Prepared all use the exact same language. I'd ASSUME that a clarification of the language used for SM would apply equally to the other classes that used the same phrase in their ruleset. I could use a pancake spatual splitter on the front of the Europa.
Vic, what do I have to do to make sure you are on the protest committee?
02-13-2008, 7:31 PM |
jaebers
Posts 27
Points 495
siastuning: boxboy:It's actually hard to tell in the picture of Vic's car as it is a bad angle. You'd really need to look at it from above, as the bodywork right at the splitter might be farther in than above.
-Andy M.
Well, the plot thickens. I guess I won't go cutting just yet... Thanx for the history Vic.
02-17-2008, 9:53 AM |
jaebers
Posts 27
Points 495
I spoke with Doug Gill last Friday and pointed out the discussion and various interpretations of the rule. Per my request he will be sending all of various interpretations and the discussion on this thread to the SEB where they will render a clarification. Julia
02-18-2008, 1:54 AM |
boxboy
Posts 259
Points 4,315
Julia, the SMAC did discuss this on our last conference call and had a suggested clarification for the SEB. Without rewriting the rule more specifically, all we can really do is suggest a minor rewording that could possibly result in something more like "B", which was the majority view on the SMAC.
-Andy M.
02-18-2008, 12:49 PM |
jaebers
Posts 27
Points 495
Thank you Andy. I'm glad to hear the ball is already rolling. Maybe a small rewording could entail the following.
inches measured forward and radially from the front bodywork/fascia as viewed from above.
the front bumper/fascia as viewed from above. Julia
02-18-2008, 1:15 PM |
Patrick Washburn
Wausau, WI
Posts 1,402
Points 17,995
Here's a version with a couple less words:
Front splitters are allowed and shall be installed parallel to the ground (within +/-3 degrees fore to aft) and may extend a maximum of 6 inches perpendicular from the front bodywork/fascia as viewed from above. Splitters may not extend rearward past the centerline of the front wheels. No portion of the splitter may extend beyond the widest part of the front bumper/fascia as viewed from above.
02-18-2008, 10:16 PM |
rnoll98
Joined on 12-29-2003
San Diego, CA
Posts 302
Points 4,830
siastuning:Some of you guys need to apply for the SMAC...
No kidding. :)
Randy Noll
02-21-2008, 2:30 PM |
EVOlutionary
Joined on 01-15-2006
Posts 47
Points 405
Here is one in support of "C".
M. Front splitters are allowed and shall be installed parallel to the ground (within +/-3 degrees fore to aft) and may extend a maximum of 6 inches forward of the frontmost portion of the bodywork/fascia as viewed from above. Splitters may not extend rearward past the centerline of the front wheels. No portion of the splitter may extend beyond the widest part of the front bumper/fascia as viewed from above.
And here is a new idea:
M. Front splitters are allowed and shall be installed parallel to the ground (within +/-3 degrees fore to aft) and may extend a maximum of 6 inches forward of the frontmost portion of the front bodywork/fascia as viewed from above. Splitters may not extend rearward past the centerline of the front wheels. No portion of the splitter may extend beyond the widest part of the front bumper/fascia or front wheel/tire as viewed from above (which ever is wider).
I like that one best!!
02-22-2008, 10:29 PM |
jaebers
Posts 27
Points 495
EVOlutionary:Here is one in support of "C".
I'm not sure "C" is going to fly for Doug mentioned that the SEB was concerned about foot safety for people.
02-24-2008, 1:59 AM |
modernbeat
Houston, Texas
Posts 673
Points 6,785
jaebers: EVOlutionary:Here is one in support of "C".
Really? Maybe he needs to look at wings and eye-safety.
02-24-2008, 11:28 PM |
jaebers
Posts 27
Points 495
modernbeat: jaebers: EVOlutionary:Here is one in support of "C".
Just quotin' the man....
04-17-2008, 3:38 PM |
jaebers
Posts 27
Points 495
I talked with Doug Gill and he said a clarification will be coming out in the next month's Fastrack.
04-21-2008, 1:31 AM |
boxboy
Posts 259
Points 4,315
It isn't a very lengthy clarification. Just added the word "from" the body. Implication is that you can be 6" from the body in any direction until you hit the "no wider than..." part. That should put you at "B" at the beginning of the thread. As long as you can draw a line from the edge of the splitter and hit the "as viewed from above" body line within 6", you are OK.
-Andy M.
04-29-2008, 10:39 PM |
jaebers
Posts 27
Points 495
Yep. I agree with you that it implies "B".
04-30-2008, 6:49 AM |
Joe_914
Joined on 12-05-2005
Gulf Coast
Posts 531
Points 2,820
Well I am sure glad I decided to look at this thread again. tore up my old splitter and was going to make a new one. Son of a gun if my old one would not have met "B" anyway.
Hold my beer I got some work to do.
Page 2 of 2 (39 items)
2
