B Mod, where's it going??
Last post 03-20-2008, 10:25 AM by P38overhead. 66 replies.
11-24-2007, 11:20 PM |
notstock
Joined on 11-19-2007
Posts 25
Points 425
Re: B Mod, where's it going??
LET us be very clear, Tommy Saunders car was not designed by anyone still living. And next Mr, Dragon (yes i know his name) cannot Drive any better than I can, furthermore he just copied the mk25 legrand construction and lengthened the lower and upper track rods without even moving the diff.on the rear suspension , The car ate u joints continously over the past years until the axle angles and plunge depths were corrected.
It was a very badly constructed and lengthened mk25 legrand . I have done significant repairs on that car at 2 nationals that if I had not done , the car would not have made the podium due to being out for repair.
I have provided cv joints at many events and technical suggestions for each year after tommy bought the car to get the car reliable ,
The entire rear suspension, supports , rear frame , as well as differential axles and driveline has been re engineered and replaced in the past 4 years , the cooling system has been replaced and reworked, ackerman has been redone, the suspension including sway bars, control arms in rear all have been removed and replaced., a quaife added from taylor and mounts from from Janco, Janco has done all the work on fabrication above in addition to , new roll bars , attachments, UTA designed and fabricated shifter and clutch control , New fuel pump system , Brakes and wheels corrected , Tommy tried to put the rain tires and wheels on the car a couple of years ago and they interfered so bad that they locked up the front wheels and he had to borrow some from another car, An illegal belly pan was replaced last year , The breather system has been reworked I might add all the above was accomplished with lighter and less robust materials without effecting the tub , so that more ballast had to be added to remain legal.
Tommy has reworked the glass due to how badly it was falling apart and due to a fire in his trailer caused by a short in the cars electrical system . The rear body fits extremely poorly over the lengthened suspension so tommy is going to redo the rear wheel wells next year .
So saying anything about Mr dragon and his work does not buy a whole lot, nor support his prowess of design cus he has done none, and he drives as badly as I do. ( ask Vern Lyle about his Mr dragon legrand experiences)
Your car was lengthened here in Texas; but still had the spool in the rear end and unless you changed the motor had a weak engine in it , It is a MK18 car ,
I welded the original lower arms after the heim insert weld broke at a local event .
. Perry reworked the entire rear suspension on your car right before he sold it He does immaculate work.
Jg
11-26-2007, 11:14 AM |
Gonzo_BMod
Joined on 06-19-2007
Posts 64
Points 1,200
John,
I guess soon we'll be seeing F1 cars with less wing and more lead if the static weight and aero weight are so similar ;) Sure is cheaper to throw lead in than spend precious $$$ on wind tunnel time. Maybe they can get Lewis to drive in a dive suit???
All kidding aside, the 4 lengthened trailing links on my car were bent when I got them, part of the spool carrier had begun to crack at several of the welds also. So as is, they didn't seem like the current DSR weight and forces. I've run this car at just 50 lbs overweight so that both my skinny son and my fat self would make weight at the end of the day, it is an absolute pig in that form. Basically if the SCCA says that I have to add 200 or so pounds to it I will race with someone else.
If there is such a disparity between these vehicles, then maybe they just need to be in different classes. No need to turn one into a school bus to compete. You mentioned A-Mod for the DSR's. That would just throw them into the same pit you claim you are trying to get out of. Hardly seems to make sense. If you noticed the PAX/RTP guy dropped the B-Mod pax this year some. Seems to indicate B Mods are getting a bit slower compared to A? Evan's car placed a whopping 430th in PAX at the nationals this year.
DSR is not a formula class. It rewards engineering, and full use of the available rules. Engine mods are free, aero is pretty free up to a degree, lots of room for innovation, that is why I chose one over some of the other B Mod cars I looked at. Literbike engines are advancing by leaps and bounds. Now that they are a serious AMA class they have been put on the fast track for development by the manufacturers. A couple of HP per year is not going to be uncommon. So where do you stop? Nobody has yet put a full Moto-GP engine in a DSR, but some day (probably soon) that will come. What then? Another couple hundred pounds?
IMHO weight is not the answer here.
Joe Gonzalez 1979 Legrand DSR- B Mod Gilbertsville, NY
11-26-2007, 1:02 PM |
notstock
Posts 25
Points 425
First Bmod is and has been a basically GCR or slightly modified GCR class. It's intent ( Jesus jump in here) has been an outlet for GCR regulated cars with easily reversible changes to be placed into competition without reducing the ability of the vehicle to revert to a competative GCR car as well as maintain the Economic value of the car after life in Club race or solo , remember formula cars compete and are constructed on a very well controlled set of rules called a formula . The Formula's have always been based in part or completely on internationally homologated Racing classes and as such are very restrictive in construction ,minimum weight , engines , transmission designs etc . The class was originally intended to allow cars to compete in solo on one weekend and compete in ( yes) vintage or a club or international event the next weekend with maybe only minor changes ( never really materialized that way ) . As I understand it the way the rules were written way before my time was so that SR Legrands were actually outlawed from Bmod , as if one constructed one according to Legrands original plans they all would be at 76 inch wheel base and thus not meet the 80 inch wheel base rule and thus would by omission be AMOD not BMod. Since SR cars especially DSR mc cars and FS mc cars almost have no rules and for the most part have no internationally sanctioned equivalent ,In general and in solo one is not automatically rewarded by building a car into a GCR class that has little if no rules those were generally called amod in the past . As a result especially for FS cars and DSR cars built to GCR rules and not wanting to run at minimum weight, wheel base , track or Balast can now and always have been allowed to Run as AMOD cars.
As I have heard it ( Jesus help here) The SR cars were deemed to be a possible dominant element in class even with old technology engines so The atlantics, were given the ability to run enhanced engines and run tires up to the maximum for the largest allowed in the GCR class, but had weights applied that was displacement based and achievable to ensure equilization of the atlantics if one used a cosworth engine. ( quick Note here is that even current 1600 toyota based swift 014 cars, all carbon fiber ,have trouble meeting 1250 weight )
Your last line discussions are exactly why weight Must be added to DSR/1 liter bike cars to run against The hodpodge of other cars in BMOD or they need to be placed in another class. You have agreed with me and Jesus even though want to take your ball and go home if you and other DSR cars cannot be OVER DOGS .
However in your comparison to formula one:
You completely subvert or are not skilled enough to understand what I have said. ( I doubt the latter as you have proven with at least some of your writings you understand the technical issues and problems with the 1liter bike motors against autoderived engines. Kudos on at least admitting it publically I admire sportsmanship and fairness)
Again at speed on a road course the aero force produces force vectors into the structure that are identical to the same static weight applied at the same points, From a force on the chassis standpoint and in direct responce to your claim that you would have to reengineer the car to carry extra weight , again you do not !! ; down force and static weight apply the same exact loads if they are the same in magnitude . 100 pounds is 100 pounds regardless if it comes from lead or from a wing.
Lower static weight as I have already explained , but again you have neither understood or choose for your own ends to ignore and go emotional , effects The ability to accelerate a body ,( on a non tire limited vehicle , ) the system is controlled by the equation F=Ma.
Down force improves tire normal force but imparts exactly the same forces as if one were to replace it with weight at the same attachements.
Static weight is a great leveler for classes because it effects F=Ma and for road race GCR classes that have aero , the chassis all already can take the static weight addition with no additional re enforcements needed, when; for solo ;the speed is reduced to under 80mph .
Static weight addition on some DSR's may also be a very big improvement on a short wheel base car because it does not change as a function of speed and /Or if designed to help weight transfer by careful placement . So by distributing the weight properly; the car may handle at low speeds much better after the weight than before. Formula one redistributes weight in the form of ballast for every track or for different temperature/ tire conditions .
Now your arguement of formula one is just plain emotional ,....... From an engineering stand point Your example actually supports Jesus's suggestion of added weight to a DSR to equalize a car and that it does not hurt the integrity of the vehicle nor does it hurt slow speed handleing ability .
Added weight does effect acceleration ; so is very good at equalizing vehicles or Horses on courses requireing bursts of acceleration with small aero and just like in both cases; if the structure (horse or car )already can handle the forces ( as we have already fully proven ) does not require a bigger horse or changes to the vehicle beyond ballast attachements. Jockeys wear weight vests to equalize carried weight on horses .
Formula one is a very long wheel base car , the cars acceleration capability is limited by tire traction, engine HP and static weight , Aero DRAG limits Top speed , so it has exactly the same issues any formula car or DSR has . Static Weight is the low speed to high speed limiter with a given set of tires and engine, ( F=Ma,) a good example of how STATIC weight is so significant is Renault Got disqualified a few years Back for having extra weight , above the minimum , but had the weights contained in a spring pendulum arrangement to amplify the weight transfer effects on the front of the car.
They were able to back out a significant amount of wing down force that resulted in ,"reduced high speed drag ", that resulted in raised top speed , at the expense of a little slower acceleration but much faster corner entry and exit with the moving weights and faster terminal speeds in the straights due to lower down force, This resulted in an overall average speed gain in most tracks over many laps, Another team was disqualified for trying to pump fuel around the car into different cells, dynamically to effect STATIC weight distribution while running. SO formula one does Know exactly what i have been open and honest about and uses it to their advantage .
In the Case of Renault , During breaking; the static weight resisted nose bounce and caused the cg to be shifted forward against a spring so slow speed corner entry was dramaticaly improved as well as corner exit when the weight shifted rearward . The on board computer could freeze the location of the weight so that in high speed or low speed portions of a course the best STATIC weight distribution could be achieved. Different values of static weight or none were added depending on the circuit . The Mass dampers were 15cm By 15 cm at each corner and had a weight and springs that were located in a inclined or almost vertical tube. The weight material being used by Renault was rumored to be depleated uranium fo compactness.
This STATIC WEIGHT spring pendulum as well as the fuel pumping , was determined to be illegal because it Gave Renault and other team a very large advantage due to the movable STATIC weight . The moving weight was determined illegal as not meeting the "ballast must be secured rule " as well as movable aerodynamic influence device provision on interpretation by the FIA.
From speed tv experts
The F1 regulations demand that the combined weight of the car and driver should be a minimum of 600 kilos. With the exception of fuel, the weight of the car includes all its fluids and lubricants: engine and transmission oils; engine coolant; and fluids for both brake and hydraulic systems. The driver’s weight includes everything he would normally wear whilst driving: gloves, boots, underwear, overalls, helmet.
Fuel is excluded from the car’s minimum weight because it must not be used as a ballast. A full tank of fuel will add 100 kilos to the car’s mass. If the FIA allowed fuel to be taken into consideration when calculating the car’s weight, then any team (that had managed to build a sufficiently lightweight car) could, in theory, remove 100 kilos of ballast from their chassis prior to the start of the race and run underweight. This would give a massive performance advantage. Then, by filling the fuel tank during a very late pit stop, the car could be re-ballasted, returning its mass back to 600 kilos in readiness for post-race scrutineering. A dastardly trick.
With the FIA ignoring the mass of the onboard fuel, however, everyone can sleep soundly, secure in the knowledge that all teams are observing the same set of rules. Indeed, should they deem it necessary, the FIA’s scrutineers are at liberty to request the fuel tank be thoroughly drained before weighing the car.
The above is an extreme example, I’m unaware of any current car/driver combination that needs 100 kilos of ballast to comply with the FIA’s minimum weight requirements. It’s usual for the cars to carry somewhere between 40 to 75 kilograms of ballast. The top three or four teams may well run a little more, the lower teams a tad less.
It’s a perfectly reasonable question to ask why the teams continually strive to make their cars as lightweight as possible, knowing they are required to reach the same minimum weight before competing. why aren’t the teams content to manufacturer a car that weighs, say, 590 kilograms, and then play with a mere 10 kilogram of ballast?
The answer is that more ballast is preferable for the engineers as it allows them to lower the car’s centre of gravity: get more of the car’s weight as close to the ground as possible. A low centre of gravity improves chassis handling; the car is more stable and reacts quicker to steering input and direction change.
In fact, as the engineers and drivers work to improve the balance of their cars, controlling both understeer and oversteer, playing with the precise positioning of the ballast has become an important part of the process. The mechanics are always being asked to shift a percentage of the onboard ballast: “take two kilos out of the rear, add two kilos more at the front, please.”
John Garcia
Again My degrees, experience and understanding prove that BS does not beat science except in discussions of man , monkeys, and emotion.
11-28-2007, 6:33 PM |
Gonzo_BMod
Posts 64
Points 1,200
Are these the correct current BMod weights allowed? FA- 2V to 1600cc- 1100 lb 4V to 1600cc- 1180 lb up to 3000cc- 1285 lb (is this where rotary engined cars run?)
CSR- 1075 lb with no engine restrictions.
DSR- 1020 lb with MC based 1000cc The club racing rules show:
FA- Between 1160lb and 1230lb depending on engine (with the 1230 being the rotary engine cars) CSR- Between 1100lb and 1225lb depending on cc's for motorcycle engine cars DSR- 900lb for MC engine cars So the Solo weights compared to GCR weights penalize the DSR cars by 120lbs, credit the CSR cars by (25lbs to 150 lbs), and penalize the Mazda engined cars by 55lbs. Is that correct? Outside of the CSR based BMod weights, which according to Chuck have been corrected for 2008, I continue to fail to see the case for adding more weight to a DSR. At the GCR weights this year the top FA car at the Runoffs qualified 2.5 seconds faster than the top DSR. The top CSR, literally the same car (with Viking bodywork) and driver as the FA pole car, qualified on CSR pole within a tenth of the DSR pole. Does anyone know where one of the new FB cars would run if they were going to Solo? I am assuming B-Mod.
11-29-2007, 3:58 PM |
notstock
Posts 25
Points 425
All rotaries run at 1285 regardless of the porting or if it is a 12a or 13B . You again provide more data that supports claims of all the physics going on and has already been stated, and continues to support the need for more weight in Ax events for the DSR cars.
As we have all indicated classing and weights in club racing have no bearing on equilized solo performance period ,they are not designed intended nor were ever concieved of for that purpose in club racing . They have no merit in determining Solo performance as the course and battlefield is not the same
Sort Of Like you saying we should make atomic ( non neutron) hand grenades cus the atomic bomb has such high yield you need less of them to kill the enemy or they work great for tanks, need only one and it only has to be close to the tank to work,
Pretty stupid and ignorant over all concept in a hand grenade,, If one really understands atomic blast weapons , but maybe not so far fetched if shot from a cannon , again wrong assumption ,conclusion and application due to ignorance ,evil or desire to be overdogs but not based on fact or engineering . Yes a big ass KAMAKAZEE arm grenade might work but I would not want to be within 2 miles on any side when it went off, just plain dumb,even worse than less than stupid .
Club Racing rules are based on an oval or road course with long straights ,In road racing one goes round and round over the same course for from between 15min and 2.5 hours depending on the circuit and the event. Cars with higher terminal velocity because of better high speed stability or lower drag aero can be faster over the average than lower weight cars with higher down force.
Road race not solos . All the above as well as your masterfully stated obvious rules for Club race have actually no direct link to solo performance except in a course that looks like a road race course wide fast, no slaloms ,no tight corners . Other than that Your attempt at comparison is just stupidy based on emotion or ignorance or both.
My previous examples of more weight and less down force in formula one also support a road course scenerio , The weight bias applied to road race vehicle has no bearing on what the weight to equalize a vehicle used in a hill climb or in a autocross should be , The weights in road race are determined by what is supposed to be considered a minimum weight that can produce a safe vehicle with any construction allowed,and thus force a desire for adequite construction. As previously stated and shown due to the round and round venues of Club racing weight is not as deterministic as it is in short ,tight ,single shot events like solo. So comparsion to solo for any reason other than ignorance or stupid pet tricks really has no link to solo. Again engineering fact not emotion or BS.
There has been a significant issue in SCCA Club racing with the Dsr cars; that have been constructed by individuals or have been modified , have had severe reliability problems in road racing ( alot have broken crashed etc:) and a move to increase weight in the name of safety has been discussed every year because of the whole issue of cars pushed to the lower weight limit. Without good engineering and construction they are just plain dangerous to every one on course and do not provide sufficient protection for the driver in a crash. . Read your fast tracks for the past 7 years this comes up alot because even in Club racing the weights are not sufficient to create a safe car in general .
Hope this changes this year ; after the Ferrari club club race verdict and award of over 40 million ; and SCCA forces a better construction and increase in lower weight limit to ensure it is achievable for DSR cars 1100 pounds for road race seems to be about correct based on metal tubing. .
The whole TV speed experts, exerpt that I linked you to stated that as well .
See below Swift engineering on adding weight to their 016 cars for safety.
DING DONG listen up son , Knock knock is there gray matter between those ears on that jug. 8>)
You are again going emotional and trying to justify lower weight based on something that has no direct comparison to SOLO events and has no bearing on equalization in solo. DUHHHHH
Although both follow the same physics , there are 2 different issues that determine the outcome. As I showed in my previous post of formula one, in a road course one can gain an over all advantage by reducing the down force on a fast track even with higher weight , Your examples above shown all of that to be absolutly true , long formula car better high speed aero (lower down force less high speed drag) as well as high speed stability than the Sports racers ( their aero provides higher down force at lower speeds thus higher drag at speed way rates) the formula car should by design be faster at the end of long straight courses where lap after lap the smaller higher down force car drives ahead then gets caught up with and passed at the end of the straight, then catches up in the corner but just not quite all the way ( i have been to many run offs as well as did the suspension decks on the DEKON monza while a co-op at Gm in the early 70's)and have seen that repeatedly Over the course of 15 to 30 minutes the the big ass low down force, poor cornering atlantics gain on every straight away over the nimble high down force srs. , Neither were intended in club racing to be compared to each other nor classed together nor meet the same equilization set as they are not equal any where . Weights in club race are based on safety for an achievable structure and terminal velocities that are possible , neither apply nor were intended to apply in solo as no one ever gets near terminal speeds.
Solo tries to equilize them in a class with different limiting conditions for each type of vehicle with completely different characteristics that favor smaller lighter higher down force cars on small solo courses. Club race favors high speed aero high horsepower long wheel base cars that is why FA and Fmazda cars converted to CSR work so well as CSR in club racing . So any comparison to club race weights or performance is just thrattle with no value against solo equalization numbers .
Just a quick fact at Mid ohio a formula ford turns faster corner section times than a formula one car ( goes through the corners at a faster speed ) does The formula ford would probably beat the *** out a formula one car in Auto cross as well. Again supports smaller lighter works in corners .
Again enough of the emotion and Bull s**T , added weight is the only equilizer for DSR cars that is viable and works for any car in solo for BMOD with the current and previous crop of real FA cars . It is achievable, reversible with velcro and well within the platforms force vector envelope. Weight as has already been proven cannot be readily removed from any manufactured altantic except maybe with bastardized cars but that then hurts the real atlantic to give bastard cars a weight advantage . Not desireable for class participation or acheivable by one without complete fabrication facilities or big wallets. Weight is cheap available every where and can be placed to a DSR's advantage as well as be removed for next weeks club race in a DSR with no major changes in the DSR.
Fa cars even the swift 0014 and 016 cars with a 1600 toyota come in at over 1100 (data from swift engineering ) you quoted , So they cannot even get anywhere near the 1100 weight , the 1195 weight in solo is their for the purpose of allowing a 1600 GCR legal formula ford or varient to be able to compete in BMOD at an equitible weight.
http://www.lynxracing.com/about_specs.html 1260 pounds minimum from lynx data
http://www.swiftengineering.com/full.asp?content=6 specifically talks about increasing weight to make the car survivable .
talking to swift engineering directly they indicate the 016 car comes in at 1270 +/- 10 to +15 pounds with no fuel with a normal 17 to 19 year old boy in the drivers seat (From Chris Walrod swift engineering) (145pounds average is the quoted design number for that driver )
Since both; current F atlantics cannot make 1100 pounds even with carbon fiber as even stated by the primary manufacturer , and older fa club race competative cars cannot make much below 1285 with the 2 liter or any thing resembling it ; as well as with any human male over 35 years of age driving it ( us average weight is 165 for U.S. males 35 to 45) it is just PLAIN STUPIDITY AND IGNORANCE AS WELL AS Idiocy for anybody to think one can even lower Fa weights on a real Manufactured FA from homologated manufacturers ,
It is sort of like a 4 year old kid wishing that the real DARTH vader would come and get rid of bullies for him. IT is based on the childs ignorance and complete non reality world they live in to think it is even possible . ONLY raising DSR weights make sense and are achievable as well as doable from an engineering basis .
Formula b cars would run amod if they exceeded any of the bmod rules such as displacement ( which certain years actually did) other wise are basically like a RALT rt 2 to rh 6 derived folded sheet metal monocoque car ( March was the single biggest supplier and all were ron Tarnac inspired if not designed for March)
So you will not take up a free offer to show that i can actually improve your DSR for solo by adding weight and do it completly with no structure change? Sort of knew engineering works and BS walks .
John Garcia
This has been like trying to teach pigs to sing,
It waists my time and only annoys the pig 8>)
11-29-2007, 4:34 PM |
Jim G
Joined on 12-15-2005
Posts 330
Points 3,300
notstock: Again enough of the emotion and Bull s**T
I completely agree with that statement. If you'd throttle back a little it would make it alot easier to listen to you and have a discussion.
Jim Garry
11-29-2007, 6:26 PM |
jesvilla
Joined on 05-10-2006
Posts 38
Points 265
OK, let's all throttle back some, voice your opinion, and if someone disagrees with you, then they disagree.
My original post suggested or asked for an equal wings ruleset for all cars, not weight added to DSR's. My intent was to illicit some opinions to see what peoples thoughts are on the subject, not a full on war of words. I hoped that Bruce D., Greg S., or a few more of the FA guys would speak up, maybe they're not privy to this forum, I don't know. How about some of the SR guys, Evan, Tommy or Stu?? I'm leaving plenty of people out, I can't think of everyone right now.
IMHO(H for humble), If the FA's were allowed to run full width wings at the same heights in cleaner air, as the Sports Racers, or the Sports Racers had to use the same wings ruleset as the FA's, then maybe, just maybe, the (percieved) advantage for the SR's could be somewhat nullified, and run times might be closer between the two types of cars.
Nothing is for certain, I can't guarrantee that this will be the answer, and unless more of the Formula Car and Sports Racer owners speak up and voice their opinion, then we are basically wasting our time, and a few of you are getting upset over something we have no control over.
Jesus Villarreal D mod Europa
11-30-2007, 9:12 AM |
Gonzo_BMod
Posts 64
Points 1,200
Very well put Jesus. I agree with your point of view. I was also hoping to get more opinions from others vested in this class. Being new to BM, and really enjoying racing the new car, I am all for keeping this a viable class. I haven't yet been to the Nat's and like I have mentioned earlier, in the NT events and Divisionals that I have attended, the BM car to beat is Ron and Brad Fish's Ralt Supervee. The (perceived) DSR performance advantage is a relatively new topic to me. DSR is seeing some new chassis in road racing that will at some point hopefully will filter down into our sport, The big development in my opinion is the formation of an FB class. This may have positive implications for BM in the future. There are companies like Jay Novak's making "back half" kits for Van Diemen FC's that allow the motorcycle powerplant to be easily put into the chassis. Many of the early cars are just converted FC's with stock 1000cc motorcycle power plants, though there are some very nice purpose built FB's like the Stohr and the Phoenix. Though it sounds like an open wheel version of DSR, the aero, engine, and tire rules are more restrictive.
Is there currently any specific ruling that would put FB cars in the BMod class?
11-30-2007, 10:39 AM |
modernbeat
Joined on 06-30-2004
Houston, Texas
Posts 673
Points 6,785
Gonzo_BMod: ...The (perceived) DSR performance advantage is a relatively new topic to me.
DSR is seeing some new chassis in road racing that will at some point hopefully will filter down into our sport...
I think most of that Perceived Advantage comes from open wheel drivers who aren't willing to prep their cars to the limit based on the value of their historic cars. I know that's what John G's been saying, but he refuses to cut up his Ralt. Instead he's built something akin to a FSAE car but hasn't unveiled it yet. I think he's going to try to get the weights lowered on F cars so he can make use of a lower minimum weight on his new built-to-the-limit car. Or, I'm just paranoid.
So John, what does that new car weigh without ballast? When are you going to unveil it, March?
On the topic of new SR cars...it seems to me that most of the new cars are getting much wider and slightly longer. Despite any aero or suspension trickery, I can't imagine that's an advantage for Solo, but I'm willing to be show how the larger cars can have an advantage not available to the smaller cars.
11-30-2007, 11:03 AM |
Lynn
Joined on 11-30-2004
Saint Louis
Posts 1,453
Points 12,155
Gonzo_BMod: Is there currently any specific ruling that would put FB cars in the BMod class?
Per the Modified section of Appendix A in the Solo Rulebook, all Formula cars and Sports Racing cars legal under the current year GCR are legal in BM unless specifically classed elsewhere.
2002 Mercedes C230k, retired, 2005 Nationals STU DFL 1969 Beach Solo Vee and 1985 Lynx B Solo Vee
11-30-2007, 11:37 AM |
notstock
Posts 25
Points 425
You are parnoid , Lets give you my philosphy , First local real life examples
Damon has been running both my car and another Bmod in the past 2 years. The other BMOD owner stopped Damon from running cus Damon was waxing his ass almost every event in the owners own car. Made some kind of Bs legal excuses (Maybe not BS , because of how much material he has removed from his DSR the car may actually be unsafe now (over 120 pounds of tube removed ))
I offered a ride to Damon and he has run with me and has beat me as well, but even so I am modifying the new car so Damon can drive it , I like equal competition and will even go out of my way to help people even if I get beat in doing so . Damon is a great driver and with him in my car it helps me get better as well as gives me feed back that allows us to adjust the car in fewer individual runs than I would have to give away. He gives fantastic car feedback. I would rather have some one who is better beat me in my own car that is extremely within the rules then have a dog t*rd beat me in a rules weaseled amod in Bmod clothing. As a result ..
I will not produce a vehicle and call it "a something type" car then try to get weights reduced to meet my build capabilities . That is just plain dishonest and evil, I will not rebody my car so I can take weight out ,change its class by doing so and then get a buddy on the mac to reccommend inclusion of a car that would have been amod into bmod either. I find people who do those sort of things are just plain dishonest slime bags . I will not stand on my head to change the meaning of a passage in the rules so that I can justify an illegal car , I will not even run a car in class localy under weight without bumping the car class . IT is just plain dishonest and crappy to do so , While others may have no honor or problem with cheating , or mentaly redacting rules for their advantage I sure do. It is the height of unsportsmanship.
My new car depending on what engine and what belly pan arrangement I put in it ; can meet any weight from 1120 pounds to the 1285 with me driving ( not a 18 year old boy) . But it is a bastard car , that I had to build in order to be engineering based competative with the amod bastard cars that are in class right now. Since I built it on FA rules (and it will meet homologation standards for class) I will meet current FA or FS rules for the engine that is in the car when I decide to run it . I am and will not ask for any advantage over the Homologated FA cars , That would be cow manure tactics and be quite doggie pooh if I did ( stronger 4 letter words apply here) . Yes I could put a 1000 mc derived engine in it and get to 1020 pounds by ripping out the real tranny and going to an itty bitty fuel cell and battery , If I did you know it would be a MOTO GP class engine as I can afford to do that .
The point is I hoped that even after throwing over twice the inital price of the car into developments on the ralt over the past 4 years that I would not have had to build a Bastard car to compete with the amod bastard cars now in bmod if I believed that any real Fa car could be converted as easily as stated I would have bought one and converted it. Secondly I would not have had to build it if the SEB would have added weight to dsrs ( especially legrand based or below 84 inch wheelbase) and not continue to bleed AA red and allow the amod legrand hord to continue in bmod unchecked .
I would not have spent 2 years and more time and rescources than most people have in 2 years designing and building a new chassis, drive train and aero package, if The SEB had done their job . IMPO There should be both a Mc derived engine penality as well as a below 84 inch wheel base, indexed penality applied to be comprehensive and fair . For a coment and discussion on Jesus's suggestions I would not allow the FA wings rules into SR's as they are pretty generous in area for FA s (and if allowed in unfouled air of a SR are a further upset ) , but IMHO need to have their envelope on FA cars adjusted to be of any value . (wider, higher , more rear over hang as well as maybe allow full skirts for FA cars) The above could improve cornering some what , However what simulation shows is that the dominate issues for solo in order are; weight, then track, then wheel base . It has been established That The largest available marque cars ( the ralt) cannot make weight then IMPO It is beyond what a real Fa can be done and have them still handle correctly and be converted back for club racing on the next weekend. That is why I have built a solo only bastard FA with no resale or intrinsic value ,It can be cut up or what ever with only my time as a loss thus the same as most solo DSR cars are , it also can be converted to a SR car and I can sell it to Road racers as a CSR or FS car , or remove the real tranny and sell it as a DSR for $$ and
( They buy anything keep it in a garage for years then whine all the time cus they don't want to spend money on a new engine or a quaife diff to be competative, their answer is cut out structure and throw it away. )
I will not cut up a Ralt do to its intrinsic value as well as by doing so the car is really no longer a true FA car but now a bastard as well.. I would have NO problem doing that to a legrand as even the legrand produced cars were really nothing historic or even expensive .( a mk18 car down the road from me sold for 4 grand last year complete, another small dsr was bought 2 years ago for local events for 6k complete ) So to compete with the bastard AMODs in Bmod clothing cars I have built one , but will meet the 1285 pounds minimum with the initial planned engine . ( I actually will be 1304 on purpose out of the box with one gallon of fuel ) It will take a year to sort out the last pieces of suspension fine tunning, weight shifting and FEA model udating to be accurate and predictive ,
I have a new engine planned for 2009-2010 that I am currently doing simulation and generating machine NC files for that will be 60-80 pounds lighter than the current one and will also have smaller over all dimensions and will output about the same power with torque distributed over a much wider crank angle to minimize peak to rms torque ratios and keep everything light weight. It will still be 1304 pounds if the rules stay the same and I will continue to push for them to add weight to DSR and mc derived vehicles as TRUE FA cars really have no room for weight reduction and maintain their value .
JG
11-30-2007, 11:58 AM |
notstock
Posts 25
Points 425
If there would not be so much crying and be emotional tantrums like a 4 year old the professional discussion is being given . Adults and the educated discuss things in ideas and concepts that usually exceed a 4 year olds attention span , So just like my 4 year old niece once I get past how birds fly she starts crying about how airplanes dont have feathers so how can they fly and falls asleep. You have the same ability to write cogent physics based responces as I do. The fact that only Jesus has come back with anything that may even resemble a starting point for a real solution is telling.
OBTW I am only at idle, so keep the insults comming it will only rev me up sooner 8>)
jg
11-30-2007, 1:14 PM |
Jim G
Posts 330
Points 3,300
Just so everyone is clear, my previous post was not written as an insult. It was a statement hoping that posters would calm down. I'm just trying to absorb the important points that are being made.
Jim Garry
11-30-2007, 1:15 PM |
notstock
Posts 25
Points 425
Re: B Mod, houston in dec jan of feb
I hope to be down your way sometime between now and march to play with the car more than on my test track at home ( 2000 feet of driveway and lots of country roads) I am cutting up the seat area and moving the dash and wheel so Damon will fit in the car. I have a couple of new cams comming to back out some engine power as currently the car is splitting transmission cases on a clutch dump .
I hate cold weather so have been slow to work over the past 2 months.
Jg
11-30-2007, 2:34 PM |
notstock
Posts 25
Points 425
Just for clarification , I did not interpret that way just having fun , i have a pretty blunt sense of humor.
jg
11-30-2007, 2:47 PM |
