Statement from the Ft. Myers National Tour Chief of Protest (unofficial)
Last post 03-09-2006, 1:11 PM by NightTrain. 99 replies.
02-21-2006, 9:33 AM |
abreakey
Joined on 06-21-2004
North Carolina
Posts 97
Points 340
Re: Statement from the Ft. Myers National Tour Chief of Protest (unofficial)
welll - Ian was driving the GT3, and he stated he was trying to hit the
rev limiter in 2nd, but never could. That would mean he never hit
83 mph.
Peter Leir's GT3, with Peter, Ian or myself driving it has never found the rev limiter in 2nd on any solo course, even this one.
adamb
Adam Breakey
Mazda Mp3 SSC Founder - http://www.autocrossforum.com
02-21-2006, 10:48 AM |
Paul_Ward
Joined on 10-09-2001
Shelbyville, KY USA
Posts 38
Points 450
http://www.peanutbutterward.com/sundaysized.jpg
Above is a map from Sunday, I worked first heat standing south of Cone number 60. From my view point cones 45 threw 52 slowed the cars way down but by cone 60 several cars were bumping 2nd gear limiters and some going into 3rd gear. It was higher speeds than I'm used to but never felt unsafe.
Paul Ward 2000 Miata Cstock, garage queen 2000 Camry Point A to Point B
02-21-2006, 11:25 AM |
Sidewinder
Joined on 12-30-2000
Corona, CA USA
Posts 143
Points 940
The rule on corner speeds is specific about speed, but doesn't define what all constitutes a corner. Is a slalom a corner? How about gated sections, which are really just slaloms? To me, a slalom is not a corner. Overall direction of travel doesn't change.
So, was the protest filed over speeds in sweepers or through slalom or gated sections?
Bob Beamesderfer '94 CSP Miata Cal Club and SDR
02-21-2006, 11:33 AM |
tuskenraider
Joined on 11-05-2005
Posts 53
Points 330
Wow........what a bland looking course on paper.
Wayne Onyschuk #375 was STX now ESP(THANKS SCCA!)
02-21-2006, 1:23 PM |
RenoSolo
Joined on 01-08-2006
Reno, Nevada
Posts 12
Points 135
I applaud Mr Carpenter and the PC for making the tough call. Anyone can make easy decisions, it takes real intergrity to make the hard ones. We should remember that Solo is NOT a speed sport. If we kill or maim some course workers Solo could go the way of Rally. Time trials are there for those who need to "dance at the edge of control" at speed with safety, Solo is meant to be different.
97 Miata ES 93 RX 7 SS
02-21-2006, 1:33 PM |
David Lehman
Joined on 01-27-2004
Plantation, FL
Posts 889
Points 11,855
Yeah that's great--------
You will make solo so thrilling ---THAT IT REALLY WILL BE SOLO
It will become so boring that you will be lucky to get 5 drivers show up.
PS---If only one person shows up, then who runs the timing equipment ?
Trying to get faster
02-21-2006, 1:48 PM |
one timer
Joined on 02-20-2006
Posts 1
Points 0
David Lehman:
Are you mentally disabled, or just acting like it to make us feel sorry for you?
No one has suggested slowing down Solo ... only preventing a rogue region (who decides that someone is over the sound limit without using a meter, and has more major incidents than most) from setting up single throttle position course that also happen to be stupidly and boringly designed. You don't need to design only transients down, same old 180 at the bottom, and transients back. Unless you really have no talent at course design whatsoever .... oh, that must have been it.
As for the protest, it wasn't so much an issue of safety, it was more that the Solo class structure is not based on what cars could do on that course.
As for national staff allowing that course, they already made some changes prior to allowing walk throughs, or weren't you watching? It's hard to force a region or designer to make more than a couple of major changes. That course sucked so bad it really needed to be completely redesigned, preferably by someone from the planet earth.
02-21-2006, 2:15 PM |
Mrsideways
Joined on 02-24-2003
Orlando,FL,USA
Posts 683
Points 8,495
Highest speeds were reached at gate 40/41 and 66/67. The course was actually very exciting to drive. Constantly doing something, no time to think. offline by 1 inch lead to being late for the rest of the run. Very important to be percise.
1999 Civic Si SSC
02-21-2006, 6:29 PM |
vetteman
Joined on 10-13-2005
Posts 24
Points 105
I give the man credit for filing the protest, BUT don't say there's a problem with the speed of the course, then go make your runs and protest. That makes it souond like I got my Butt kicked ,so I'm gonna fix that---I'll protest the course like i wanted too and see what happens. I don't think thats the case here, but one might wonder????
02-21-2006, 6:34 PM |
DILYSI Dave
Joined on 12-12-2002
Posts 454
Points 5,145
vetteman:I give the man credit for filing the protest, BUT don't say there's a problem with the speed of the course, then go make your runs and protest. That makes it souond like I got my Butt kicked ,so I'm gonna fix that---I'll protest the course like i wanted too and see what happens. I don't think thats the case here, but one might wonder????
Is it conceivable that the course didn't reveal itself to be too fast until he drove it? I know that I'm not all that good at guessing where I will and will not have to shift into third.
02-21-2006, 7:59 PM |
ScoobSnax
Joined on 02-10-2004
Posts 19
Points 220
I know that at a Pro at this location several years ago, we were all bummed out walking the course because it was way too tight. By Sunday we were bouncing off the limiter all over and what was tight on the walk was nothing more than a quick gasp and flick of the wrist. Do it right and you gained a lot of time, do it wrong and you got the cone. Sounds like typical solo to me, but it just was not that obvious.
I can understand being upset about having times taken away, but compared to my last experience after a 15 hour overnight drive to an event in Ft. Myers you would be happy to have had the runs. It rained, and then it really rained. All the timing equipment was soaked. We started up the first heat, and instantly had issues. So they tried this, and that, and for nearly (ok its been a while so I may be off here) 2 hours we sat out on course. Only to be told in the end that we were going to start up again, with afternoon runs, BUT, keep the AM workers on. So I got to sit out on the concrete for another hour and police cones. Fun stuff. I think I would have rather taken the runs, and had them taken from me (and everyone else) than to sit on the concrete wondering why it had to rain on Friday intead of Thursday.
But, alas, I was not there this year for the tour, and it sucks that some people ended up worse for the protest, but it sounds like speaking up and filing the protest was the right thing to do. I know in the past, we have had incidents around the area, and afterwards people say how they KNEW this would happen, but DID NOT say anything about it at the time. So rather than debate top speeds, or who has the credentials to make the decisions, or who should have preemptively made a decison, lets just say thanks for putting on the event in the first place. Be happy no one was hurt (physically), and everyone got a chance to compete on a legitimate course, and have fun on a course that was faster than it should have been.
Thanks SCCA, for doing these events for us, and structuring them so that when we feel something is not right we have a way to resolve the issue. Now, lets talk about moving National to August....
02-21-2006, 9:26 PM |
vvt4me
Joined on 04-03-2005
Milwaukie, OR
Posts 57
Points 515
Do you guys think course designers are going to have trouble keeping the speeds up to an interesting level on the nice big lots while making sure the rules arent being broken? I have confidence that we can keep the courses legal and keep the watered down needlessly slow courses out.
Dominic Stone #77 2005 Dodge SRT-4 ACR >:) -- D-Stock 2004 Oregon Region STS Champ 2006 EESCC STS Champ Oregon Region Chief of Safety
02-21-2006, 10:37 PM |
vetteman
Posts 24
Points 105
I would say sometimes yes, but more times than naught if you think about going to 3rd gear it's more than likely a high 2nd gear course or a low 3rd gear course. I didn't go to the nationals this year but just looking at the course maps i knew it was going to be a fast course if it stayed dry, and after talking to some who went they stated it was the fastest nationals they had been too. I was just looking at thge course map from Florida and the only true turn it looked like there was was the turn around. My question would be what is the definition of a turn? I wasn't trying to bust his chops, just making a statement.
02-21-2006, 10:38 PM |
Glenn L. Austin
Joined on 06-20-2001
Snoqualmie, WA, USA
Posts 573
Points 7,340
Yes, I really do think that course designers will be able to create very interesting courses, even while they are following the rules.
It's not the speed, it's the "impression of speed" that makes a course "fun," in my opinion. You can move a cone here, add a cone there, and have a course that is quick and fun, and yet never go beyond 50 MPH.
Glenn L. Austin, Computer Wizard and Race Car Driver 2005 Ultra Yellow Nissan 350Z Track Model 2007 Packwood ProSolo "first loser" (0.081) 2007 SCCA Solo National Championships - 10th place
02-22-2006, 12:08 AM |
F125AXer
Joined on 03-04-2002
Rochester, Michigan, USA
Posts 75
Points 280
Here it is only Tuesday, and I feel that I am way behind on the week's happenings. This has to be the hottest topic to have ever hit the Solo discussion boards.
Allow me to preface my comments by saying that I believe all of the parties involved in the protest and its' disposition to be persons who value the SCCA, and who were acting in what they felt were appropriate directions for the circumstances. Hind sight always has the advantage of perspective, with additional information and further consideration.
I was not at the Tour this year. I might well have been, if the format of having both a Tour and a Pro Solo on successive weekends had been resurrected. My history with the site spans four consecutive personal competition season openers. I have had the good fortune to run FTD at many of those National level events. All of the competition and practice runs were taken in my F125 Honda/Renspeed shifter kart, except for four exhibition runs in a 250 4-cycle clutch kart. I was nearby, and even peripherally involved in a couple of the safety related incidents mentioned in another thread. You could say that I know Buckingham Field pretty well. The bulk of my SCCA autocross experience remains in stock category cars, from HS to DS, with forays into P and SP. So I am not just a kart guy.
I was happy to see Steve's post, which outlined the entire Sunday occurrence from his viewpoint. In reading it, I was particularly struck by one section:
On the issue of the ruling: The protest committee must first determine legality. The course was protested under 2.1.A. The protest committee found the course was in excess of 2.1.A in respect to this sentence: “Turns should not normally allow speeds in excess of 45 mph in unprepared cars.” Members of the PC spent much of the afternoon observing the competition and monitoring car speeds through all sections of the course. I also interviewed various competitors in a variety of stock and street prepared cars as to speed in gears and speed at rev limits. What the PC determined was that the majority of turns were taken in excess of 45 mph. In fact, that turns at or below 45 mph were the exception not the norm. This fact contradicts the quoted statement in 2.1.A. Whether or not a Super Stock GT3 Porsche went 83 mph or 73 mph was never an issue. The PC must follow the rules and based on our investigation it was determined that the course was not in compliance with 2.1.A. Steve Hoelscher
Within a couple hours, Gary P. inquired:
The Lawyer in me would ask "what is an 'unprepared' car? Is it any car in a category below Prepared? Or is it a car in 'as delivered from the factory' condition, with stock tires, stock shocks, stock sway bar, stock brake pads, stock exhaust, and an alignment within FSM specs; a car that has not been modified with any of the stock category preparation allowances?"
There have been numerous other posts now on the same subject, and I think it is not at all trivial. In fact, it may just be the crux of the issue. An enlightening post was submitted only a few minutes before Gary's:
Precisely. Safety aside, the course design rules help define what our sport is all about. We buy and prepare cars assuming they're going to be put to use on a course that meets the rules. Bryan 2004 Mazda RX-8, #187 BS (emphasis is mine, AS)
Now over 20 years ago, I was fortunate enough to win the HS class at Nationals in a car which had, in order of relative importance: Tires, seat belts/harness, altered toe (alignment), a fresh tune-up, and a clean air filter. Did I feel tat the car was "prepared"? Absolutely. Those modifications and additions allowed me to run at the top of the class. Yet those changes are now the norm for all but perhaps the slowest 10% in any of the stock category classes.
There can be little argument that tires are the number 1 component in transforming the showroom vehicle into an autocrosser, and they are better almost every year. If you want to run at the front now, you'll likely also need expensive shock absorbers, a custom adjustable sway bar with urethane or Delrin bushings, legal limit offset (or spaced) lightweight wheels, and crash bolts to maximize alignment departure from factory settings. You can add in the allowances which contribute to power, and therefore speed capability. I think after viewing a list of additions, modifications, and adjustments, that someone who knows nothing of autocross or the SCCA would come to the conslusion that Darrin Disimo's Miata (for example) is certainly NOT an "unprepared" car.
From personal experience, I have run a production vehicle around the outside of a 100' skidpad at an indicated 38 mph. I wish there had been the possibility of prepping it to a higher level for autocrossing, and recording the change in capability. I know it would be obvious.
Steve's later posting of more text from the rules section has not altered my take on the subject. We all realize that anyone can drive a vehicle from a dealer's showroom, and within a matter of days, if not hours, stretch its' cornering capabilities by anywhere from 15 to an incredible 30%. In some cases the transformation is literally akin to the old axiom involving a porcine appendage. Those rides which start on a higher level still get a significant, albeit lower, benefit. "Unprepared" equates to street tires, oem suspension. I'd expect rules limit prepared stock class cars to be quite significantly faster.
So where does that leave the SCCA's Solo program? In a time of change, of course. I can't say that I agree with the the PC's answer to the protest. If it was done with the intent of shaking things up to bring about change, that is fine, but a ".22 single action" would have done the job; blasting the Howitzer was drastic overkill. One thing which troubles me is that if the event were truly determined to be operating outside the rules, then it should have been stopped immediately, before any more cars took runs.
After dealing with all the inevitable appeals, I think the SEB will have to get together with the SS Committee and come up with some clearer guidelines for what constitutes a legal (within those rules) and safe autocross.
Alan Sheidler
Alan Sheidler F125#21 Honda/Renpeed
02-22-2006, 7:33 PM |
gary p
Joined on 11-23-2001
Monticello, IL, USA
Posts 2,189
Points 35,070
In another Forum, Bill Headlee had these profound thoughts about this situation. I'd like to share them.
The important thing (I think) is that there is not a common interpretation on what the rules allow as far as max speeds (independant of whether or not at a specific event at a specific site on a specific day, those speeds present a physical danger). This conclusion (lack of common interpretation) has been very well supported by comments on both sides of this protest and the ruling on it so far. I hope the end result of this is...
- The definition of "turns" as it relates to maximum speeds in section 2 of the rule book is clarified so that we, the members, understand it with a common interpretation
- The definition of an "unprepared car" as it relates to maximum speeds in section 2 of the rule book is clarified so that we, the members, understand it with a common interpretation.
- The definition of "normally allow" as it relates to maximum speeds in section 2 of the rule book is clarified so that we, the members, understand it with a common interpretation.
- Future events have a better and more consistent understanding of what is allowed by the rulebook.
02-22-2006, 10:46 PM |
vetteman
Posts 24
Points 105
Alan brings up a very profound point, if after the first group or 2nd group the course was found to be that fast why wasn't the event stopped and the course changed. Seems the protest committee was was having a hard time saying the course was to faast in the turns.
02-25-2006, 6:29 PM |
TeamRX8
Joined on 04-18-2003
Posts 1,581
Points 21,490
I simply cannot keep quiet on this any longer.
You can argue the merits of this situation all you want, but at this point it's irrelevant. This protest will not be reviewed or judged upon by it's merits. Simply, there is no protest. This is only an illegitimate abortion that will be tossed out for improper procedure. A protest committee doesn't have a blank check to do as they please. The PC is as bound by the framework of the ruleset as much as anyone else. If this whole situation wasn't so tragic your use of the words "illegal" and "logical" would be quite humorous, as would the utter arrogance you've displayed in defending your incorrect actions.
First, you cannot have a protest without two parties; a protester and a protestee. A course cannot be a protestee. The officials who allowed competition to occur on the approved course would have to be the protestees. In this particular case the protest would have to be filed against the Chief Steward(s), Safety Steward(s), etc. This means they have to be served the protest paperwork and allowed the opportunity to be heard and present their own case. Apparently this did not occur. If there is no protestee this begs the question on how an Intent to Appeal was filed and what exactly they were going to appeal since they had never been served or seen the supposed protest at the event. This precludes the fact that nowhere in the rulebook is a PC chartered to impose a penalty against an entire field of non-protested competitors by tossing out a whole days worth of competition.
Further, if the course was indeed inappropriate, as an SEB member you and/or the other SEB members in attendance with which you consulted for this abortion have the responsibility and authority to shut the event down until it is brought into compliance. This in itself would be considered the final extreme measure to be taken only after exhausting numerous other ways to address the situation with the senior event officials, which apparently you never bothered with bringing into the loop on what was happening. To allow a whole days competition to occur and then disallow it without recourse is inexcusable for someone in your position. As inexcusable as the event officials not learning about it until after firing up their computers later that evening to witness one of the most negatively damaging debacles to hit the SCCA Solo2 program that I have witnessed in my 12 years of participation.
As the person who handpicked you to be my replacement on the Board I am shocked, ashamed, and completely embarrassed by your actions. This is undeniably one of the biggest mistakes I have ever made. I cannot apologize to the SCCA and it's membership enough for what has happened as a result. Your lack of understanding of the Solo2 rules is only trumped by your complete lack of judgement and forethought. The entire episode reeks of a self-imposed hidden agenda. If that's not the case then the only other alternative is total ignorance of the Solo2 ruleset.
I would strongly urge you to save yourself any further embarrassment and resign your post before all the facts become known to the general membership. It's clear that you are not fit to serve on the Solo Events Board.
Mark Sipe
Steve Hoelscher:
I was expecting the forums to virtually explode with the typical Monday morning second guessing, safety stewarding, chief stewarding, finger pointing, blaming, character assassination, rampant speculation and name calling but this has gotten completely out of hand. I was the Chief of Protest at the Ft. Myers National Tour and to set the record straight I believe it now necessary to make some kind of statement regarding the facts of the protest filed by Robert Carpenter. This is not an official response from the SCCA or the SEB. I have no intention of debating, in any of these forums, the Protest Committee’s decision or its merit. The PC’s decision stands on its own and is wholly supported by the facts. Nor will I respond to those who find it necessary to attack and defame the Protest Committee. Such statements say more about the author’s character than the character of those they are intended to assail. The purpose here is to provide the solo community with information as to why the PC took the action it did.
Robert Carpenter was one of several people who approached me Sunday morning expressing concern regarding the course. I know Robert well and know that he would much prefer for the competition to be settled on the course not in the protest shed. Robert raised the issue of a protest and I advised him that filing a protest would guarantee the course issue be dealt with. Robert thought it through and filed the protest after he drove in heat one. He was VERY surprised when I later informed him that the PC had upheld his protest and that Sunday’s times were thrown out. He even stated that he never considered that the protest would be upheld, let alone that the results would be affected. In fact, he told me that he “had not intended for this to affect the results and mess up anyone’s event”. I commend Robert for having the guts to file the protest. I have heard a lot of whining over the years but seldom does anyone ever step up and take the heat for actually taking action.
Once a protest is filed, the Protest Committee must deal with it. The committee cannot simply sit around and whine and argue on various forums, they must make a decision and that decision carries with it the responsibility of its effect. It would have been easy for the PC to dismiss the protest or pass the buck. However, the protest committee has the responsibility of ensuring the integrity of the event and protecting the interest of the competitors at the event and the membership as a whole. This is a big responsibility and one that the PC takes very seriously. Nor is it an easy job and one that few people will take on because of the potential for controversy. That the members of the Ft. Myers National Tour Protest Committee took on this issue knowing their decision would result in extensive armchair quarterbacking is to be commended.
Results: The second step in the process is the action taken by the protest committee once it votes to uph
