Kumho>Bridgestone?
Last post 09-04-2008, 3:28 PM by Mooobunnny. 384 replies.
06-08-2008, 9:49 AM |
06-08-2008, 7:19 PM |
06-12-2008, 7:38 PM |
06-12-2008, 11:38 PM |
Joined on 05-28-2003
Posts 4,079
Points 60,040
daveyboy:Does anyone have the 195/50/15 RE-01Rs in stock? I am running 15x7s and don't want to run 205/50/15 Falken 615s any longer... .
National back-order. Been that way for weeks. 1200 tires coming in late June/early July, is the latest word. --Andy
06-13-2008, 9:45 AM |
06-13-2008, 10:07 AM |
Renspeed
Joined on 04-30-2005
Jacksonville, FL
Posts 377
Points 4,970
Oh, you will be....it just won't be because of the Bridgestones... -MK
Mike King 88 CRX Si - STS2 #99 Jacksonville, FL Team Bridgestone - King Motorsports - A-Spec Racing - Renspeed
06-13-2008, 10:09 AM |
06-13-2008, 10:11 AM |
turbohappy
Joined on 11-10-2003
Posts 575
Points 7,015
GChambers:Matt, we ran the CRX on Bridgestones last week at Grissom in 85deg heat and barely sprayed the front tires. They were fantastic.(Of course, I have yet to try the Toyos in comparison)
You guys were running it like it was a single-driver car, right?
06-13-2008, 10:13 AM |
GChambers
Joined on 11-12-2004
Indy, In
Posts 581
Points 6,150
turbohappy:
Yes. Also, we didn't spray the tires on the Miata at all.
07-30-2008, 11:02 AM |
Paxman
Joined on 12-27-2000
Glendale, AZ, USA
Posts 98
Points 1,585
Re: Kumho XS ... Where is it?
For a tire due out in a few days (August, according to Tire Rack), there is a glaring lack of information. What sizes will be available, what are some specific details about it's construction and what is it supposed to be capable of? Will it be good in the heat as the Dunlops are, or melt like the Toyos? I've done searches everywhere, and have found no typical introductory materal or information; just that it is "due out". Even the Kumho site mentions nothing. Jason I. has not shared "insider information" as he has been able to do in the past. Makes me wonder if there are problems or delays with this tire. Anyone see or hear anything new? Thx. EDIT: Just now rechecked Kumho Site and found this info: http://www.kumhousa.com/tires/passenger/ultra-high-performance/KU36.do
Scott Meyers Glendale AZ
07-30-2008, 11:33 AM |
mleach
Joined on 03-29-2006
Austin Tx
Posts 185
Points 2,550
Their graph that compares the tires is terrible. It indicates that the XS performs worse than the MX and cost's more. While that may or may not be true, if it is, no thanks.
07-30-2008, 11:58 AM |
Mooobunnny
Joined on 05-29-2007
Posts 90
Points 1,540
With a Y speed rating, the tire delivers an optimum run temperature of 205 degrees Fahrenheit. Wow, optimum run temperatures of 205 degrees. I wonder how much truth that holds...
07-30-2008, 12:05 PM |
vwawd
Joined on 11-14-2006
SHV
Posts 106
Points 1,225
Mooobunnny:With a Y speed rating, the tire delivers an optimum run temperature of 205 degrees Fahrenheit. Wow, optimum run temperatures of 205 degrees. I wonder how much truth that holds...
What are considered optimal run temps on on the Bridgestone and Dunlop offerings?
VW MKIV R32 - STX
07-30-2008, 12:40 PM |
tosi
Joined on 07-10-2008
Posts 4
Points 65
mmm -> 295/35-17, nice to see wider 25" o.d. sizes!! Also, since this seems to be the defacto ST* tire thread, any updates on the 225/45-15 R1R?
07-30-2008, 12:56 PM |
Gunny JC
Joined on 02-05-2005
Eastern Tennessee
Posts 115
Points 1,055
mleach:Their graph that compares the tires is terrible. It indicates that the XS performs worse than the MX and cost's more. While that may or may not be true, if it is, no thanks.
Looking at the graph it appears that the XS performance level is bewtween the V710's and the MX's.
STS class '96 Saturn SC-2
07-30-2008, 2:20 PM |
Crosser1
Joined on 02-24-2002
Austin, TX
Posts 198
Points 3,065
I agree with Matt, the graphic sucks. I think what they are tyring to say is on a scale the higher you go up the list the better the performance, but how these graphics are suppose to work is the exact location of the item in question (i.e. where the word XS is located on the graph) is where the data is suppose to be represented. So, applying the that theory that Matt is, the XS costs more, but us further to the right on the preformance scale than the MX's. The same applies to the V710's vs the V700's. It appears as represented that the V710s cost more and have less performance potential than the V700s. Which everyone knows is false. As someone that uses these style graphics regularly, this is just very poorly executed.
Eric
07-30-2008, 3:55 PM |
Paxman
Glendale, AZ, USA
Posts 98
Points 1,585
I was hoping for another 255/50/17 or 255/45/17 as the MX had; my V-6 Mustang really, really needs a larger size in the 17" diameter so I can get more rubber on the road (yes, street tire classing). The 245/45/17's that I have to run now are in fact simply too short for optimum performance, but mostly too narrow....... The factory stock 235/55/17 tire had a 27.1" diameter, and the 245/45/17 that I run now (Dunlops) are about 25.7". I do not want to go lower in diameter, which I'd have to do for more width (like a 255/40/17) or such. Damn........
08-30-2008, 3:52 PM |
root
Joined on 06-10-2006
Posts 61
Points 305
don't know if this has been posted, couldn't find anything. Assuming nobody cares right now, but apparently XS can be ordered... http://forums.nasioc.com/forums/showthread.php?t=1582213
here is a list of sizes and prices:
205/50R15 KU ECSTA XS 97.00
215/45R16 KU ECSTA XS 104.00
225/50R16 KU ECSTA XS 124.00
265/45R16 KU ECSTA XS 188.00
215/45R17 KU ECSTA XS 125.00
235/45R17 KU ECSTA XS 148.00
245/40R17 KU ECSTA XS 160.00
245/45R17 KU ECSTA XS 150.00
255/40R17 KU ECSTA XS 158.00
275/40R17 KU ECSTA XS 173.00
285/40R17 KU ECSTA XS 192.00
315/35R17 KU ECSTA XS 228.00
335/35R17 KU ECSTA XS 233.00
225/40R18 KU ECSTA XS 159.00
225/45R18 KU ECSTA XS 188.00
235/40R18 KU ECSTA XS 172.00
245/35R18 KU ECSTA XS 178.00
245/40R18 KU ECSTA XS 182.00
265/35R18 KU ECSTA XS 245.00
275/35R18 KU ECSTA XS 250.00
315/30R18 KU ECSTA XS 338.00
285/35R19 KU ECSTA XS 339.00
345/30R19 KU ECSTA XS 416.00
Page 19 of 20 (385 items)
... 19
