Kumho>Bridgestone?
Last post 10-06-2008, 4:47 PM by Mooobunnny. 391 replies.
Page 19 of 20 (392 items)   « First ... < Previous 16 17 18 19 20 Next >
  •  06-08-2008, 9:49 AM 304415 in reply to 304414
    Re: Kumho XS
    A 225/45/16, RE-11, might be the one thing that would pry me away from my Dunlop Star Specs.
  •  06-08-2008, 7:19 PM 304443 in reply to 304415
    Re: Kumho XS
    I too am interested to see how the Re-11's turn out, although i have heard that they have softer sidewalls than the Re-01R's do.
    Schooner
    95 Miata STS2
  •  06-11-2008, 6:00 PM 305064 in reply to 296764
    Re: Toyo&gt;Bridgestone?
    Any updates on the 225-45-15 Toyo?
    I tried cold calling a bunch of numbers from the Toyo website.  I eventually talked to someone named Rob that worked in Marketing (this is from calling the number listed on Toyo's website for sponsorship).  He told me he'd check and call me back.  He advised me they would be available August or September.
  •  06-12-2008, 7:38 PM 305240 in reply to 305064
    Does anyone have the 195/50/15 RE-01Rs in stock?  I am running 15x7s and don't want to run 205/50/15 Falken 615s any longer... .
  •  06-12-2008, 11:38 PM 305273 in reply to 305240
    daveyboy:
    National back-order.  Been that way for weeks.  1200 tires coming in late June/early July, is the latest word.
  •  06-13-2008, 9:45 AM 305303 in reply to 305273
    Well, for the first time this season, I'll be back on some Bridgestones.  The Toyos are just melting in this 90* heat.  They won't cut it for the summer.  I hope I'm not dissapointed.
  •  06-13-2008, 10:07 AM 305310 in reply to 305303
    Oh, you will be....it just won't be because of the Bridgestones...Stick out tongue
    -MK
    Mike King
    88 CRX Si - STS2 #99
    Jacksonville, FL
    2007, 2008 STS2 Solo National Champion
    Team Bridgestone - King Motorsports - A-Spec Racing - Renspeed
  •  06-13-2008, 10:09 AM 305313 in reply to 305303
    Matt, we ran the CRX on Bridgestones last week at Grissom in 85deg heat and barely sprayed the front tires. They were fantastic.(Of course, I have yet to try the Toyos in comparison)
  •  06-13-2008, 10:11 AM 305314 in reply to 305313
    GChambers:
    You guys were running it like it was a single-driver car, right?
  •  06-13-2008, 10:13 AM 305315 in reply to 305314
    turbohappy:
    GChambers:
    Yes.  Also, we didn't spray the tires on the Miata at all.
  •  06-13-2008, 1:39 PM 305348 in reply to 305315
    Yeah, I drove on those stones nearly all of last year.  They're pretty good.
    Mike, you're a dork.  :)
  •  07-30-2008, 11:02 AM 312961 in reply to 305348
    Re: Kumho XS ... Where is it?
    For a tire due out in a few days (August, according to Tire Rack), there is a glaring lack of information.
    What sizes will be available, what are some specific details about it's construction and what is it
    supposed to be capable of? Will it be good in the heat as the Dunlops are, or melt like the Toyos?
    I've done searches everywhere, and have found no typical introductory materal or information; just
    that it is "due out". Even the Kumho site mentions nothing.
    Jason I. has not shared "insider information" as he has been able to do in the past.
    Makes me wonder if there are problems or delays with this tire.
    Anyone see or hear anything new?
    Thx.
    EDIT: Just now rechecked Kumho Site and found this info:
    http://www.kumhousa.com/tires/passenger/ultra-high-performance/KU36.do
    Scott Meyers
    Glendale AZ
  •  07-30-2008, 11:33 AM 312968 in reply to 312961
    Their graph that compares the tires is terrible. It indicates that the XS performs worse than the MX and cost's more. While that may or may not be true, if it is, no thanks.
  •  07-30-2008, 11:58 AM 312972 in reply to 312968
    With a Y speed rating, the tire delivers an optimum run temperature of 205 degrees Fahrenheit.
    Wow, optimum run temperatures of 205 degrees. I wonder how much truth that holds...
    00' 328Ci
    01' Tahoe LT
    98' Camaro Z28 - dead
    95' 325is - STX 182
  •  07-30-2008, 12:05 PM 312974 in reply to 312972
    Mooobunnny:
    What are considered optimal run temps on on the Bridgestone and Dunlop offerings?
    VW MKIV R32 - STX
  •  07-30-2008, 12:40 PM 312983 in reply to 312974
    mmm ->  295/35-17, nice to see wider 25" o.d. sizes!!
     Also, since this seems to be the defacto ST* tire thread, any updates on the 225/45-15 R1R?
  •  07-30-2008, 12:56 PM 312986 in reply to 312968
    mleach:
     Looking at the graph it appears that the XS performance level is bewtween the V710's and the MX's.
    STS class '96 Saturn SC-2
  •  07-30-2008, 2:20 PM 313000 in reply to 312986
    I agree with Matt, the graphic sucks.  I think what they are tyring to say is on a scale the higher you go up the list the better the performance, but how these graphics are suppose to work is the exact location of the item in question (i.e. where the word XS is located on the graph) is where the data is suppose to be represented.  So, applying the that theory that Matt is, the XS costs more, but us further to the right on the preformance scale than the MX's.  The same applies to the V710's vs the V700's.  It appears as represented that the V710s cost more and have less performance potential than the V700s.  Which everyone knows is false.  As someone that uses these style graphics regularly, this is just very poorly executed.
     Eric
  •  07-30-2008, 3:55 PM 313023 in reply to 313000
    I was hoping for another 255/50/17 or 255/45/17 as the MX had; my V-6 Mustang really, really needs a larger size in the 17" diameter so I can get more rubber on the road (yes, street tire classing). The 245/45/17's that I have to run now are in fact simply too short for optimum performance, but mostly too narrow.......Crying
    The factory stock 235/55/17 tire had a 27.1" diameter, and the 245/45/17 that I run now (Dunlops) are about 25.7". I do not want to go lower in diameter, which I'd have to do for more width (like a 255/40/17) or such.Rollseyes
    Damn........ Super Angry
    Scott Meyers
    Glendale AZ
  •  08-30-2008, 3:52 PM 318786 in reply to 271367
    Re: Kumho>Bridgestone?
    don't know if this has been posted, couldn't find anything.  Assuming nobody cares right now, but apparently XS can be ordered...
    http://forums.nasioc.com/forums/showthread.php?t=1582213
      here is a list of sizes and prices:
    205/50R15 KU ECSTA XS 97.00
    215/45R16 KU ECSTA XS 104.00
    225/50R16 KU ECSTA XS 124.00
    265/45R16 KU ECSTA XS 188.00
    215/45R17 KU ECSTA XS 125.00
    235/45R17 KU ECSTA XS 148.00
    245/40R17 KU ECSTA XS 160.00
    245/45R17 KU ECSTA XS 150.00
    255/40R17 KU ECSTA XS 158.00
    275/40R17 KU ECSTA XS 173.00
    285/40R17 KU ECSTA XS 192.00
    315/35R17 KU ECSTA XS 228.00
    335/35R17 KU ECSTA XS 233.00
    225/40R18 KU ECSTA XS 159.00
    225/45R18 KU ECSTA XS 188.00
    235/40R18 KU ECSTA XS 172.00
    245/35R18 KU ECSTA XS 178.00
    245/40R18 KU ECSTA XS 182.00
    265/35R18 KU ECSTA XS 245.00
    275/35R18 KU ECSTA XS 250.00
    315/30R18 KU ECSTA XS 338.00
    285/35R19 KU ECSTA XS 339.00
    345/30R19 KU ECSTA XS 416.00
    Filed under: , , , ,
