Kumho>Bridgestone?
Last post 09-04-2008, 3:28 PM by Mooobunnny. 384 replies.
Page 18 of 20 (385 items)   « First ... < Previous 16 17 18 19 20 Next >
  •  05-21-2008, 10:07 AM 301451 in reply to 301393
    Re: Toyo&gt;Bridgestone?
    TimSmith:
    Let me throw this out there.  I posted this in another forum.  BTW, these started as an average of 5/32nds.  Don't ask about the "average".Tongue Tied
    these are pictures of my Toyos. I am not disappointed. So far, I have a total of 148 runs on them. 112 in the total dry, 30 in damp/drying conditions, 6 in the pouring rain. I think there are 75+ left. 24 more will be taken at the Tour this weekend so I'll have a better idea then. FWIW, I think they feel better right now than when I first got them.
    Oh, and weren't these the tires that won you the PS DX Triple Crown (Super Challenge, Honda Tuner Challenge, & Honda Showdown) this past weekend?
    So much for all the fast guys switching "back" to Bridgestone.
    Big Smile
    I think Glagola had it right.  You can win on either of these makes.
  •  05-21-2008, 10:31 AM 301455 in reply to 301451
    Then why didn't you?
    -MKStick out tongue
    Mike King
    88 CRX Si - STS2 #99
    Jacksonville, FL
    Team Bridgestone - King Motorsports - A-Spec Racing - Renspeed
  •  05-21-2008, 6:07 PM 301576 in reply to 301451
    Andy Hollis:
    TimSmith:
    Big Smile
    Yes, hence the 2" "slick" area on the outside shoulder of the fronts.  Both makes of tire are fast, you just have to drive a little differently on each.  I like the Bridgestones as well.
    125 STS '89 Civic Si
  •  05-21-2008, 8:18 PM 301612 in reply to 301451
    Andy,
    You said you have the 205s, are you having any rubbing issues? I'm just wondering if they are too wide to fit under a Civic wheel well.
    Brian
  •  05-21-2008, 10:32 PM 301634 in reply to 301455
    SoloTiresdotCom:
    -MKStick out tongue
    After running EL Toro, Arkansas and FTW, I am a used to much more open courses, and the car is setup for that these days.  I changed the setup on every Saturday run and it was still not good enough for the tightness of the turns and to avoid all the bottoming out.  Then I tried something drastic overnight which helped more, but still not enough.  In the end, I gave up on trying to make it any better.  Heyward swears that the Tour course will not be so tight and that it will be on the smoother part of the lot.  We shall see.
    That...and I suck.  Big Smile
  •  05-21-2008, 10:34 PM 301636 in reply to 301612
    Macspeed:
    Andy,
    Brian
    I only had them on for two runs and only on the front.  I think I heard some rubbing at full lock when maneuvering in stage lanes, but did not notice anything on course.  They are mounted on 15x7.5 SSR (ET43).  I'll know more on Friday.
  •  05-21-2008, 10:37 PM 301638 in reply to 301612
    Macspeed:
    Andy,
    Brian
    My set is on 15x7.5 +40 wheels, and I didn't have any rubbing issues.
    -Brian
    89/189 STS/STX '89 Civic Si
  •  05-21-2008, 11:03 PM 301646 in reply to 301638
    I'm using 15X7s so I should have even less of a chance than you guys. Is there any other 15X7.5 available new other than the Rota Slipstream?
    Andy, I take it your SSR wheels are not available anymore?
    Brian
  •  05-21-2008, 11:10 PM 301647 in reply to 301646
    Macspeed:
    Brian
    949Racing sells some 6UL ones.
  •  05-22-2008, 1:24 PM 301730 in reply to 301646
    Macspeed:
    Correct.
    And it took major conniving/begging to get this set after my originals got stolen last summer.
  •  05-22-2008, 2:41 PM 301764 in reply to 301638
    BrianGT:
    Macspeed:
    Andy,
    Brian
    -Brian
    Ditto here. Though it did require a 1mm spacer in ther rear to clear the 15x7.5 +40's.
    I might as well throw in some cold weather data from this past weekend up in CPR region. The event was in cold/rain conditions, highs in the upper 60's. I ended up running in drying conditions but was able to get 1 mostly dry run in the 195/50R15 bridgestones and 2 more runs right after than in the toyo's. I ended up about 7 tenths faster on the R1R's however that clould have been due to additional drying on the course.   During the fun runs at the end of the day it was completely dry and sunny and I was 2 seconds up on the 1 hour earlier bridgestone, which was in mostly dry/cloudy conditions. Unfortunately it rained as we were switching back to the Bridgestones, so we were unable to see if we could match the R1R times.... Sometimes the weather just sucks :(
    I think the R1R's are by far a better "cold" tire. While definitely more numb they have much more grip when cool. As a note, we did not have to spray the tires at all and were doing pretty much back to back runs with only a few min to change drivers and check pressures. This is an idication of how cool it was at the CPR event. Atlanta will be totally different weather and Matt's notes about heat will come into play.
    thx
    Ian
    --CRX Addict
    --Recovered Mini Addict
  •  05-28-2008, 2:23 PM 302713 in reply to 301302
    This being my first season in STS I'd like to say holy smokes this is a fun class!!!
    Having tried both the Toyo's and Bridgestone's going by feel alone the Bridgestone's are better in the dry. The Bridgestone's take more abuse and all and all feel sharp and precise. The Toyo's are numb and if abused wear like race tires. I know that Tim and Matt are getting decent life out of their Toyo's but I have personally seen them melt away when driven past the limit: 4/32's to 1/32 in 15 runs (on a 90 second course).
    I'd like to thank Brian Bell for letting me drive his hatch and for the time and effort he has put into testing both tires and set-up's to get the car where it is now. The car is a pleasure to drive and I look forward to more close battles like the last couple weekends!
    189 STS 1989 Civic Si
  •  05-28-2008, 4:41 PM 302755 in reply to 302713
    Marc Osgood:
    Too bad you will be driving my car in September.
    Did you get my text?  Also, you suck!
  •  05-28-2008, 9:27 PM 302799 in reply to 302755
    TimSmith:
    If you go back to the Bridgestones...and Brian's car isn't faster Surprise
    Got it, thanks! As bad as you last weekend Cool
  •  05-28-2008, 9:36 PM 302803 in reply to 302799
    Marc Osgood:
    TimSmith:
    I thought you wanted to drive mine because you couldn't drive his. You still suck!
  •  06-06-2008, 3:12 PM 304264 in reply to 302803
    Re: Kumho XS
    Anyone catch the latest Tire Rack newsletter? They have the Kumho XS due in August. I wonder what that works out to in Kumho time. Smile
    David Avard
    89 Honda Civic Si black (STS)
    07 Mazda 3s (HS?)
  •  06-06-2008, 3:25 PM 304269 in reply to 304264
    Re: Kumho XS
    Davard:
  •  06-06-2008, 3:25 PM 304270 in reply to 304264
    Re: Kumho XS
    Davard:
    Means they should be here just in time to miss next years deadline Stick out tongue
  •  06-06-2008, 3:26 PM 304271 in reply to 304264
    Re: Kumho XS
    Davard:
    Does anyone really care about the Kumho XS, since it isn't legal for competition this year?
    That can be worried about next season, and since the XS seems to be targeted as a replacement for the MX, I don't have much faith in it.
    I am still pissed at Kumho for not releasing the 245/45ZR16 v710...
    I am looking forward to the new Bridgestone RE-11 for next season more than any other upcoming tire right now.
    -Brian
  •  06-08-2008, 6:57 AM 304414 in reply to 304271
    Re: Kumho XS
    BrianGT:
    -Brian
    Me too!  I found this Japanese tire size list for the RE-11's, There's some pretty interesting sizes.  It will be interesting to see which sizes actually make it here. I am hoping the 225/45/16 is one of them.
    3. Release size (size 31)
    Tire Size
    275/30R19    92W 275/30R19 92W
    275/35R19    96W 275/35R19 96W
    245/35R19    89W 245/35R19 89W
    265/35R18    93W 265/35R18 93W
    255/35R18    90W 255/35R18 90W
    245/40R18    93W 245/40R18 93W
    235/40R18    91W 235/40R18 91W
    225/40R18    88W 225/40R18 88W
    245/45R18    96W 245/45R18 96W
    225/45R18    91W 225/45R18 91W
    255/40R17    94W 255/40R17 94W
    245/40R17    91W 245/40R17 91W
    235/40R17    90W 235/40R17 90W
    215/40R17    83W 215/40R17 83W
    245/45R17    95W 245/45R17 95W
    235/45R17    94W 235/45R17 94W
    225/45R17    91W 225/45R17 91W
    215/45R17    87W 215/45R17 87W
    205/45R17    84W 205/45R17 84W
    225/45R16    89W 225/45R16 89W
    215/45R16    86W 215/45R16 86W
    205/45R16    83W 205/45R16 83W
    225/50R16    92V 225/50R16 92V
    205/50R16    87V 205/50R16 87V
    205/55R16    91V 205/55R16 91V
    205/50R15    86V 205/50R15 86V
    195/50R15    82V 195/50R15 82V
    165/50R15    73V 165/50R15 73V
    195/55R15    85V 195/55R15 85V
    165/55R14    72V 165/55R14 72V
    185/60R14    82H 185/60R14 82H
    STS class '96 Saturn SC-2
