Kumho>Bridgestone?
Last post 09-04-2008, 3:28 PM by Mooobunnny. 384 replies.
05-21-2008, 10:07 AM |
Joined on 05-28-2003
Posts 4,079
Points 60,040
TimSmith:Let me throw this out there. I posted this in another forum. BTW, these started as an average of 5/32nds. Don't ask about the "average".
these are pictures of my Toyos. I am not disappointed. So far, I have a
total of 148 runs on them. 112 in the total dry, 30 in damp/drying
conditions, 6 in the pouring rain. I think there are 75+ left. 24 more
will be taken at the Tour this weekend so I'll have a better idea then.
FWIW, I think they feel better right now than when I first got them.
Oh, and weren't these the tires that won you the PS DX Triple Crown (Super Challenge, Honda Tuner Challenge, & Honda Showdown) this past weekend? So much for all the fast guys switching "back" to Bridgestone.
I think Glagola had it right. You can win on either of these makes. --Andy
05-21-2008, 10:31 AM |
Renspeed
Joined on 04-30-2005
Jacksonville, FL
Posts 377
Points 4,970
Then why didn't you? -MK
Mike King 88 CRX Si - STS2 #99 Jacksonville, FL Team Bridgestone - King Motorsports - A-Spec Racing - Renspeed
05-21-2008, 6:07 PM |
TimSmith
Joined on 06-08-2006
Atlanta,GA
Posts 48
Points 680
Andy Hollis: TimSmith:Let me throw this out there. I posted this in another forum. BTW, these started as an average of 5/32nds. Don't ask about the "average".
Yes, hence the 2" "slick" area on the outside shoulder of the fronts. Both makes of tire are fast, you just have to drive a little differently on each. I like the Bridgestones as well.
125 STS '89 Civic Si
05-21-2008, 8:18 PM |
Macspeed
Joined on 07-23-2007
Posts 22
Points 380
Andy, You said you have the 205s, are you having any rubbing issues? I'm just wondering if they are too wide to fit under a Civic wheel well. Thanks, Brian
05-21-2008, 10:32 PM |
Posts 4,079
Points 60,040
SoloTiresdotCom:Then why didn't you? -MK
After running EL Toro, Arkansas and FTW, I am a used to much more open courses, and the car is setup for that these days. I changed the setup on every Saturday run and it was still not good enough for the tightness of the turns and to avoid all the bottoming out. Then I tried something drastic overnight which helped more, but still not enough. In the end, I gave up on trying to make it any better. Heyward swears that the Tour course will not be so tight and that it will be on the smoother part of the lot. We shall see. That...and I suck.  --Andy
05-21-2008, 10:34 PM |
Posts 4,079
Points 60,040
Macspeed:Andy, You said you have the 205s, are you having any rubbing issues? I'm just wondering if they are too wide to fit under a Civic wheel well. Thanks, Brian
I only had them on for two runs and only on the front. I think I heard some rubbing at full lock when maneuvering in stage lanes, but did not notice anything on course. They are mounted on 15x7.5 SSR (ET43). I'll know more on Friday.
05-21-2008, 10:37 PM |
BrianGT
Joined on 09-16-2005
Atlanta, GA
Posts 209
Points 3,185
Macspeed:Andy, You said you have the 205s, are you having any rubbing issues? I'm just wondering if they are too wide to fit under a Civic wheel well. Thanks, Brian My set is on 15x7.5 +40 wheels, and I didn't have any rubbing issues.
-Brian
89/189 STS/STX '89 Civic Si
05-21-2008, 11:03 PM |
Macspeed
Posts 22
Points 380
I'm using 15X7s so I should have even less of a chance than you guys. Is there any other 15X7.5 available new other than the Rota Slipstream? Andy, I take it your SSR wheels are not available anymore? Thanks, Brian
05-21-2008, 11:10 PM |
BrianGT
Atlanta, GA
Posts 209
Points 3,185
Macspeed:I'm using 15X7s so I should have even less of a chance than you guys. Is there any other 15X7.5 available new other than the Rota Slipstream? Andy, I take it your SSR wheels are not available anymore? Thanks, Brian
949Racing sells some 6UL ones.
05-22-2008, 1:24 PM |
Posts 4,079
Points 60,040
Macspeed:Andy, I take it your SSR wheels are not available anymore?
Correct. And it took major conniving/begging to get this set after my originals got stolen last summer. --Andy
05-22-2008, 2:41 PM |
ibaker
Joined on 02-09-2004
WDCR
Posts 114
Points 2,335
BrianGT: Macspeed:
Andy,
Brian
-Brian
Ditto here. Though it did require a 1mm spacer in ther rear to clear the 15x7.5 +40's.
I might as well throw in some cold weather data from this past weekend up in CPR region. The event was in cold/rain conditions, highs in the upper 60's. I ended up running in drying conditions but was able to get 1 mostly dry run in the 195/50R15 bridgestones and 2 more runs right after than in the toyo's. I ended up about 7 tenths faster on the R1R's however that clould have been due to additional drying on the course. During the fun runs at the end of the day it was completely dry and sunny and I was 2 seconds up on the 1 hour earlier bridgestone, which was in mostly dry/cloudy conditions. Unfortunately it rained as we were switching back to the Bridgestones, so we were unable to see if we could match the R1R times.... Sometimes the weather just sucks :(
I think the R1R's are by far a better "cold" tire. While definitely more numb they have much more grip when cool. As a note, we did not have to spray the tires at all and were doing pretty much back to back runs with only a few min to change drivers and check pressures. This is an idication of how cool it was at the CPR event. Atlanta will be totally different weather and Matt's notes about heat will come into play.
thx
Ian
05-28-2008, 2:23 PM |
Marc Osgood
Joined on 10-22-2004
clemson, SC
Posts 9
Points 105
This being my first season in STS I'd like to say holy smokes this is a fun class!!! Having tried both the Toyo's and Bridgestone's going by feel alone the Bridgestone's are better in the dry. The Bridgestone's take more abuse and all and all feel sharp and precise. The Toyo's are numb and if abused wear like race tires. I know that Tim and Matt are getting decent life out of their Toyo's but I have personally seen them melt away when driven past the limit: 4/32's to 1/32 in 15 runs (on a 90 second course). I'd like to thank Brian Bell for letting me drive his hatch and for the time and effort he has put into testing both tires and set-up's to get the car where it is now. The car is a pleasure to drive and I look forward to more close battles like the last couple weekends!
189 STS 1989 Civic Si
05-28-2008, 4:41 PM |
TimSmith
Atlanta,GA
Posts 48
Points 680
Marc Osgood:This being my first season in STS I'd like to say holy smokes this is a fun class!!! Having tried both the Toyo's and Bridgestone's going by feel alone the Bridgestone's are better in the dry. The Bridgestone's take more abuse and all and all feel sharp and precise. The Toyo's are numb and if abused wear like race tires. I know that Tim and Matt are getting decent life out of their Toyo's but I have personally seen them melt away when driven past the limit: 4/32's to 1/32 in 15 runs (on a 90 second course). I'd like to thank Brian Bell for letting me drive his hatch and for the time and effort he has put into testing both tires and set-up's to get the car where it is now. The car is a pleasure to drive and I look forward to more close battles like the last couple weekends!
Too bad you will be driving my car in September. Did you get my text? Also, you suck!
05-28-2008, 9:27 PM |
Marc Osgood
clemson, SC
Posts 9
Points 105
TimSmith:Too bad you will be driving my car in September. Did you get my text? Also, you suck!
If you go back to the Bridgestones...and Brian's car isn't faster  Got it, thanks! As bad as you last weekend
05-28-2008, 9:36 PM |
TimSmith
Atlanta,GA
Posts 48
Points 680
Marc Osgood: TimSmith:Too bad you will be driving my car in September. Did you get my text? Also, you suck!
I thought you wanted to drive mine because you couldn't drive his. You still suck!
06-06-2008, 3:12 PM |
Davard
Joined on 12-29-2000
Topeka, KS
Posts 1,199
Points 18,050
Anyone catch the latest Tire Rack newsletter? They have the Kumho XS due in August. I wonder what that works out to in Kumho time.
David Avard 89 Honda Civic Si black (STS) 07 Mazda 3s (HS?)
06-06-2008, 3:25 PM |
gary p
Joined on 11-23-2001
Monticello, IL, USA
Posts 2,216
Points 35,610
Davard:Anyone catch the latest Tire Rack newsletter? They have the Kumho XS due in August. I wonder what that works out to in Kumho time.
Means they should be here just in time to miss next years deadline
06-06-2008, 3:26 PM |
BrianGT
Atlanta, GA
Posts 209
Points 3,185
Does anyone really care about the Kumho XS, since it isn't legal for competition this year? That can be worried about next season, and since the XS seems to be targeted as a replacement for the MX, I don't have much faith in it. I am still pissed at Kumho for not releasing the
245/45ZR16 v710...
I am looking forward to the new Bridgestone RE-11 for next season more than any other upcoming tire right now.
-Brian
06-08-2008, 6:57 AM |
Gunny JC
Joined on 02-05-2005
Eastern Tennessee
Posts 115
Points 1,055
BrianGT:
-Brian
Me too! I found this Japanese tire size list for the RE-11's, There's some pretty interesting sizes. It will be interesting to see which sizes actually make it here. I am hoping the 225/45/16 is one of them.
3. Release size (size 31)
| Tire Size |
| 275/30R19 92W 275/30R19 92W |
| 275/35R19 96W 275/35R19 96W |
| 245/35R19 89W 245/35R19 89W |
| 265/35R18 93W 265/35R18 93W |
| 255/35R18 90W 255/35R18 90W |
| 245/40R18 93W 245/40R18 93W |
| 235/40R18 91W 235/40R18 91W |
| 225/40R18 88W 225/40R18 88W |
| 245/45R18 96W 245/45R18 96W |
| 225/45R18 91W 225/45R18 91W |
| 255/40R17 94W 255/40R17 94W |
| 245/40R17 91W 245/40R17 91W |
| 235/40R17 90W 235/40R17 90W |
| 215/40R17 83W 215/40R17 83W |
| 245/45R17 95W 245/45R17 95W |
235/45R17 94W 235/45R17 94W |
| 225/45R17 91W 225/45R17 91W |
| 215/45R17 87W 215/45R17 87W |
| 205/45R17 84W 205/45R17 84W |
| 225/45R16 89W 225/45R16 89W |
| 215/45R16 86W 215/45R16 86W |
| 205/45R16 83W 205/45R16 83W |
| 225/50R16 92V 225/50R16 92V |
| 205/50R16 87V 205/50R16 87V |
| 205/55R16 91V 205/55R16 91V |
| 205/50R15 86V 205/50R15 86V |
| 195/50R15 82V 195/50R15 82V |
| 165/50R15 73V 165/50R15 73V |
| 195/55R15 85V 195/55R15 85V |
| 165/55R14 72V 165/55R14 72V |
| 185/60R14 82H 185/60R14 82H | |
STS class '96 Saturn SC-2
Page 18 of 20 (385 items)
... 18
