Dunlop Direzza Sport Z1
Last post 08-20-2008, 12:03 PM by Mooobunnny. 418 replies.
Page 17 of 21 (419 items)   « First ... < Previous 15 16 17 18 19 Next > ... Last »
  •  06-09-2008, 11:16 AM 304518 in reply to 301432
    Re: Dunlop Direzza Sport Z1
    Had a good rain event this weekend, and the tires proved to do very well. Still very very happy with them.  It would be great to see a few more sizes next year but we'll see what happens I guess!  Any rumors of more sizes especially in the 15 and 16" rims at all?
     Also... I too like to order from Discount Tire Direct when I can. They seem to do well and even beat TR's prices a lot of the time.
    Steve Nackers
    R Street index HS. #723R
    '98 BMW 318i
    www.nsnmotorsports.com
  •  06-09-2008, 11:25 AM 304524 in reply to 304518
    DTD will also price match Tire Rack :)
    John
    John W: 2003 WRX: STX (and sometimes 1991 MR2: ES)
    Washington, DC Region
  •  06-09-2008, 12:46 PM 304547 in reply to 301426
    Why does everyone assume that the 195/55 is a bad size? As we have seen with several MFGs, the printed size is irrelevant. Has anyone measured it? There are reports of other sizes in the *spec coming in wider than listed. It is possible for this to have dimensions more like a 205/50, a size that people would be tackling each other just to be first in line to try. That said, I don't really care, I am not interested in the tire, but I just hate seeing bad information propagated by people repeating rumors and things that haven't been verified, let alone even tried/tested.
  •  06-09-2008, 1:27 PM 304560 in reply to 304547
    i hear ya
    there's a fair bit of trying and testing in this thread though
    the 195/55-15 has a contact patch width of 6 3/8" @ 37 lbs with an 870 lb load
    Azeni 205/50-15         6 5/8"
    'Kook RS2 225/45-15  6 7/8"
    Hoosier 205/50-15   7 3/16"
    the tire compound is good - capable of generating 1.05g @ 44 degrees on a wet asphalt surface, and 1.14g @ 120 degrees on a hot dry asphalt surface
    now if I could just get more of that good compound on the pavement!
    such is life with tiny little wheels...
    I was the only person running the Z1 in ST* at Devens as far as I know...
    so "bad size" might be a bit of an overstatement, but the Z1 isn't top dog with their offerings in the 15" diameter
    Charlie Thompson
    '04 JCW Cooper [STX]
    NER Cannon Fodder
  •  06-09-2008, 1:32 PM 304565 in reply to 304560
    there were 4 drivers on dunlops in STU.
    Doug #81 STS2
    1990 Mazda Miata
    STU 2000 Audi S4 (retired)
    STU 2005 Mazda RX-8 (retired)
  •  06-09-2008, 1:40 PM 304570 in reply to 304565
    Ah hah!  Guess which class I didn't look hard at...
    Running 17" by and large?
    and including Mr. Capers for 2nd place now that I look again...
    I was amused that I could not select Dunlop as a tire provider during the SCCA registration process on line...
    Charlie Thompson
    NER Cannon Fodder
  •  06-09-2008, 1:58 PM 304577 in reply to 304560
    cmt52663:
    i hear ya
    It would be interesting to see what the similar numbers are for the Bridgestones that are considered to be the "better" choice yet are still the 195/50/15 size (aspect ratio 5% smaller thant he Direzza).
    Steve Nackers
    '98 BMW 318i
  •  06-09-2008, 4:51 PM 304622 in reply to 304577
    you've got the tire stack in my garage - which does not include the RE-01R
    silly me...
    i roll the LF corner of the Mini over some paper, and measure the width of imprint - which varies widely from the spec: Tread Width
    but I don't think I'll buy one RE-01R for the pleasure of science...
    anyone else have small wheels and a curious nature?  and Bridgestones?
    Charlie Thompson
    NER Cannon Fodder
  •  06-09-2008, 5:10 PM 304626 in reply to 304622
    rolling it over the paper gives a good idea but it is also interesting to see what you get when you match the pressures in the air with no load and then lower the car onto the paper and then back off.  That will show what the real contact patch is and give you a good estimation of how the sidewalls are distributing the load and so forth as well. But the roll over paper does a good job.  There are plenty running that 15" bridgestone, it should be easy to get a matched rim width from someone that can roll it for you.
    Steve Nackers
    '98 BMW 318i
  •  06-09-2008, 5:25 PM 304633 in reply to 304626
    TurfBurn:
    i like your way better!  thanks for teaching me...
    Beer
    Charlie Thompson
    NER Cannon Fodder
  •  06-10-2008, 1:46 PM 304787 in reply to 304633
    For those of you that have run the Dunlops, how many events does it seem to take to get them ready.  I remember the old RT-215s I ran on the Civic took a couple events before they had their peak grip.  I am going to get rid of my Yokohamas on my STI soon I think, but want to make sure the Dunlops will be ready to go for the larger events I have planned soon.  I would be buying them shaved as well if that helps, that will at least get the mold release off of them.
    Colin Fiedler
    07 STI
    Milwaukee Region
    Bridgestone
  •  06-10-2008, 3:14 PM 304802 in reply to 304787
    From what I can tell, they seem to be about ready to go right away.  First weekend on mine, full tread, ran a T&T on saturday and an event on Sunday, took first in PAX on the sunday event.  If you were running full tread I'd plan for one event just to get the mold release off, starting shaved, they should be ready to go from what i can tell.
    IA Region #52 STX WRX
  •  06-10-2008, 3:27 PM 304809 in reply to 304787
    pinkertonpunk:
    I agree with Aaron, just give the Star Specs a good scrub-in to smooth out the high points from shaving, or to remove the mold release if full tread. Then they'll be good to go on the first run. The Bridgestones seemed to take a few events to achieve max grip.
  •  06-10-2008, 5:41 PM 304838 in reply to 304809
    SS RX7 R2:
    pinkertonpunk:
    I agree with Aaron TOO, second half of the first run.. very much like R comps.
    -Aaron G>
    Timmons Subaru
    ZZYZXmotorsports.com
    www.ChaseCam.com
  •  06-10-2008, 7:01 PM 304850 in reply to 304838
    With that said, is shaving the way to go with these if I am looking for every last bit of speed?  Or does it not seem to make much of a difference?
    Colin Fiedler
    07 STI
    Milwaukee Region
    Bridgestone
  •  06-10-2008, 9:17 PM 304875 in reply to 304850
    I have 2 sets, different sizes, the 1st set I had shaved to 6/32 and was very happy with them.  The second set for some reason I decided to have shaved to 8/32 and I am not happy with the wear pattern on them but it's still not terrible.  May have been the heat difference as the second set saw temps in the mid 80's whereas the first set hasen't seen over something in the low 70's yet.  Heat is one reason to shave tires.  I've heard that Dunlop recommends 3-6/32 for those that shave their tires and I can see why, it makes the tread pattern a little more solid by cutting off some of the tappered portion of the tread, in addition to the heat issue.
  •  06-11-2008, 10:59 AM 304961 in reply to 304547
    mleach:
    i think (for us smaller-diameter tire users) that it's the height, not the width, that is wrong.  195/55/15 is a tall tire for a miata or a CRX...~1/2" taller than a 205/50, which is itself taller than the stock 185/60/14 most of those cars came with.  and it's not as if we have a ton of torque to offset that gearing loss.  you're right about actually measuring, but unless the aspect ratio number is WAY off, it's likely too tall.  if it was a 195/50, yes, people would likely be swarming to it.
    i'm not buying and mounting one just to see if a size that's bad on paper is actually not that tall in the real world...once you go down that road, you can start buying one of each size to see what the "real" dimensions are.
    Mike - #44 STS2
    '91 Miata - racer
    '07 CX-7 - dog taxi
    www.phillyscca.com
  •  06-11-2008, 11:17 AM 304966 in reply to 304961
    Or you could just look on Tire Rack's web site and see the measured diameter.
    185/60R14: 22.8
    205/50R15 G-force KD: 23.2
    205/50R15 Hoosier: 22.8
    195/55R15 Dunlop: 23.5
    Dave Heinig
    07 GXP Z0K (Thanks Rob!)
  •  06-11-2008, 12:11 PM 304975 in reply to 304966
    DaveH:
    185/60R14: 22.8
    that's crazy talk. Rollseyes
    (actually, i just assumed they calculated it based on the size, rather than actually measuring.)
    Mike - #44 STS2
    '91 Miata - racer
    '07 CX-7 - dog taxi
    www.phillyscca.com
  •  06-11-2008, 12:19 PM 304977 in reply to 304966
    careful of relying on TR's tire specs as it is secondary info and doesn't always match the manufacturer's specs.  i've been bitten by this before.
    Doug #81 STS2
    1990 Mazda Miata
