Kumho>Bridgestone?
Last post 07-30-2008, 3:55 PM by Paxman. 378 replies.
03-21-2008, 11:44 AM |
amaff
Joined on 09-01-2006
Posts 96
Points 750
Brian, I vaguely remember a rule about 'measurable tread depth at no less than two points on the tire which are 180 degrees apart around the circumference, and which are within the center one-half of the tread surface that normally contacts the ground.' Still legal on that?
Andrew STS2 114 - 1992 Miata
03-21-2008, 8:13 PM |
03-21-2008, 9:17 PM |
BrianGT
Joined on 09-16-2005
Atlanta, GA
Posts 204
Points 3,160
GChambers:Wow, I would be pissed if my Stones looked like that after 100 runs. I'm really hoping this 225/45/15 isn't that much faster. I don't want to have to deal with them.
But they felt so good. The increased grip over the bstones is crazy good. :) I am going to get some 225s as soon as they are available and try them out. I also wonder if the 16s coming out will be good, with the shorter sidewall, as the 195/15s tires kinda suck in sharp transitions compared to the bstones.
89/189 STS/STX '89 Civic Si
03-21-2008, 9:54 PM |
P90Puma
Joined on 06-04-2007
Hamilton Ontario
Posts 15
Points 165
For the record, I am not an ST* autocrosser. This thread seems to have the most info on the R1R on the net so I am posting here.
I have a 94 Miata that will shortly be pushing 180whp+ and a set of 15x9 6UL's coming for predominantly street use, some autox and some lapping. Basically my street tire choices are only 225/45/15 for the 9 inch wheels.
So either the Hankook RS2 or the R1R.
Will the R1R (full tread depth) really chunk after a few autox runs? Can I expect at least 10k miles out of them? I know some have gotten that kind of life out of NT-01's and RA-1's.
Just seeing the wear here posted is kind of scaring me.
03-21-2008, 10:08 PM |
Joined on 05-28-2003
Posts 4,027
Points 59,060
P90Puma:Will the R1R (full tread depth) really chunk after a few autox runs?
I don't know of anyone that has run them full-tread. Those of use running them shaved are seeing odd wear even at 3 or 4/32nds. A lot of it depends on the grippiness of the surface and the ambient temps. This pic shows what a 3/32nd R1R looks like after only four runs on a really grippy asphalt surface in 95 degree weather on a well-balanced car. It's more of a severe graining than a true chunking. Just seeing the wear here posted is kind of scaring me.
As well it should. --Andy
03-21-2008, 10:42 PM |
P90Puma
Hamilton Ontario
Posts 15
Points 165
Andy Hollis:The Toyo, OTOH, is very streetable, especially at full tread depth. --Andy
Still believe this is true Andy?
03-21-2008, 10:55 PM |
Posts 4,027
Points 59,060
P90Puma: Andy Hollis:The Toyo, OTOH, is very streetable, especially at full tread depth. --Andy
Yes, in the context in which it was originally written. Which I'll restate below since you were "cherry picking" a sound bite.
Counterpoint: The difference is that the best r-compounds are
not at all streetable. They have no discernable tread at all. In
fact, they are labeled "Not for Highway Use". Flies completely in the
face of ST's basic "street legal" tenets.
03-21-2008, 11:06 PM |
P90Puma
Hamilton Ontario
Posts 15
Points 165
Andy Hollis: P90Puma: Andy Hollis:The Toyo, OTOH, is very streetable, especially at full tread depth. --Andy
Well, isn't everything "Very streetable" when comparing them to an A6/v710? Either way, looks like I will be going with the RS2, I can't afford that kind of wear on the R1R, might as well go with a NT-01 as I am not limited by ST* rules.
Edit: Unless it will be shown in the next month or so, that this type of extremely fast wear can be shown to be Autox related only on the R1R's. But even then, looks like hard street/track driving would cause the same wear on unshaven tires. Thanks Andy.
03-22-2008, 7:56 AM |
Posts 4,027
Points 59,060
P90Puma: Edit: Unless it will be shown in the next month or so, that this type of extremely fast wear can be shown to be Autox related only on the R1R's.
I'm fairly certain that it is. I've seen the same kind of wear on junky street tires (think rental car) when autocrossed hard. Like say, oh, when Evo instructors come into town and need something to pre-run the course in for a safety check. Of course, that's what CDW is for!  --Andy
04-02-2008, 3:08 PM |
TurfBurn
Joined on 04-18-2006
Madison, WI
Posts 117
Points 1,435
quite the read through the last 6 pages to glean out the info. Sounds like for all the arguing there is no clear over/under on anything. I've been holding out to learn more on the Toyo's but given the price and the wear potential I think I may just run the Bridgestone's for this year and see how things shake out for next year... fun fun... I'm not running competitive STS like you guys (just street indexed HS like we have in Milwaukee) so going from Azenis to the Bridgestones will meet the needs for a year... keep the info coming and glad to see all the info and thoughts.
Steve Nackers R Street index HS. #723R '98 BMW 318i www.nsnmotorsports.com
04-06-2008, 11:14 PM |
P90Puma
Hamilton Ontario
Posts 15
Points 165
So, it's April 6th, 7th in 45min. Anybody heard anything new on the 225/45/15 R1R?
04-07-2008, 7:01 AM |
cmt52663
Joined on 04-16-2004
Wenham, MA
Posts 202
Points 2,745
P90Puma:
as of Friday the word through Town Fair Tire from the Toyo help line was - no availability date as yet....
so i'm going to find out how the Z1 Star Spec handles - i'm out of time
04-07-2008, 8:02 AM |
04-07-2008, 11:29 AM |
04-07-2008, 11:32 AM |
glagola1
Joined on 04-08-2004
Atlanta
Posts 206
Points 2,395
P90Puma:
Don't they already have enough sizes already? I mean if the 225/45/15 comes out on September 8th, wouldn't it be legal?
04-07-2008, 11:41 AM |
Posts 4,027
Points 59,060
glagola1:Don't they already have enough sizes already? I mean if the 225/45/15 comes out on September 8th, wouldn't it be legal?
Yes. I think the poster was trying to make the point that it had been awhile since any new news had come out (valid point). --Andy
04-07-2008, 1:13 PM |
04-08-2008, 3:38 PM |
04-08-2008, 5:42 PM |
BrianGT
Atlanta, GA
Posts 204
Points 3,160
I thought 13.3.F didn't apply to ST, meaning that a manufacturer could release a new tire in one size, and it would be valid, as long as it was released before April 30th and not on the exclusion list. Or this could allow you to use an OE-specific tire on a non-OE car that is only available in one size, as long as available before April 30th.
-Brian
04-08-2008, 8:06 PM |
Rocky
Joined on 02-28-2008
Texas
Posts 52
Points 1,025
Craig Garfield:You are talking about slot car tires right? Spongies were the big thing until the RTV (Silicone) based molded ones came out. The chunks didn't really hurt them all that much if it wasn't enough to make the car jump around.
DING! A WINNER!! Yep, 1/24 slot cars. Still have my old Chaparell 2E, and when I moved to TX from CA, I had Jim Hall autograph it. Spongees with that horrible menthol goop you had to put on them, yech. But yes, the "Sil Slick" came after that, and the ones I had, if you got even one tiny slice or nick on it, it would just come apart on you. In someways, this R1R almost reminds me of them.
Just an FYI - I went and bought the new Dunflop Direzza Z1 * Spec tire, With less than 100 miles on them, not even scrubbed in, I went to a track day at MSR on Friday. They performed brilliantly!!!!! No squeeling, no loss of traction, no turning greasy as they got hot, and except for the fresh rubber being scruffed off - NO excessive tire wear at all. WOW! And out on the street they are quiet, and when it rained real hard, no loss of traction or hydroplaning. They gripped very good in the rain too. Way better than the RE01R tires I just had, and right on par with my memory of the Neova I had on my STi.
Page 13 of 19 (379 items)
... 13 ...
