Andy's STS2 Miata Project
05-30-2007, 2:07 PM |
Joined on 05-28-2003
Posts 4,080
Points 60,045
Re: Andy's STS2 Miata Project
jwbrockman:
Actually, a lot of e36 aftermarket rear shock mounts work very similarly to Andy's method, but with an important difference - they use a metal sleeve over the threads of the shock rod, so that the plate can't damage the threads of the shock. I think that type of mounting could work fine on a yellow, with a short 12mm i.d. sleeve for protection of the threads. In my case, it was easier to find the lugnut parts than a 12mm sleeve.
Interesting thought. 1st-gen CRX (and similar Civic) worked that way, too. Hmmm... --Andy
05-30-2007, 10:05 PM |
jwbrockman
Joined on 04-11-2005
Saco, ME
Posts 32
Points 310
Just one more question... why aren't the rear shocks on these cars removable?
So the lower shock bolt on the rear threads into a square nut that is captured by a small bent metal basket sort of thing. This square nut is inaccessible. It is presumably intended to be held in place by the metal basket deal, but my car is old and from new england, so instead of the bolt coming out of the nut easily, the square bolt just bent the metal basket as it turned. So now on both rear sides I have a square nut and bolt assembly that spins freely in place, which cannot be held in place by any tool I can imagine (and certainly not with the kind of force that would be required to actually remove this bolt). Fun.
'93 Miata - Prepping for STS2 '98 BMW 328i - Daily fun
05-31-2007, 10:10 AM |
GChambers
Joined on 11-12-2004
Indy, In
Posts 582
Points 6,155
Cut through the control arm so that you can get something on that nut to hold it while you remove it. Then, go on e-bay and buy yourself another control arm for $25.00
Edit: BTW, remember to put anti-seize on the bolts when you reinstall.
06-07-2007, 6:04 PM |
06-07-2007, 8:59 PM |
Sidewinder
Joined on 12-30-2000
Corona, CA USA
Posts 143
Points 940
GChambers:Cut through the control arm so that you can get something on that nut to hold it while you remove it. Then, go on e-bay and buy yourself another control arm for $25.00
Or get new ones from Mazda Comp.
Bob Beamesderfer '94 CSP Miata Cal Club and SDR
06-08-2007, 9:10 AM |
Chiketkd
Joined on 08-23-2006
Charlottesville, VA
Posts 405
Points 3,580
Andy Hollis:
Awesome result in Huntsville Andy. Enjoy the R&R!!!
Chike Dellimore - Blue Ridge/Washington DC Regions 2006 Galaxy Gray 6MT Mazda RX-8 (B-stock) Former 2006 Steel Gray 5spd WRX (D-stock) "Between now and Nats, f!ck seat time - I'm working on crazy!!!"
06-28-2007, 7:03 AM |
06-28-2007, 8:40 AM |
Brian
Joined on 09-06-2004
Mid Ohio
Posts 104
Points 1,635
Hey Andy, are you running on 7" or 7.5" SSRs? Thanks.
»Coining the phrase... Clarifi-Change...
06-28-2007, 6:32 PM |
Auto-X Fil
Joined on 07-19-2005
Posts 790
Points 3,710
"Barely touched the rev limiter"? Heading up the hill on the left course it sounded just like my car, popping all the way. My datalogs show I was on it for two full seconds, although going uphill like that I swore I was just hitting it before I braked at the top. What's your redline?
-Philip Maynard No weenies!
06-29-2007, 11:03 PM |
modernbeat
Joined on 06-30-2004
Houston, Texas
Posts 689
Points 7,015
Auto-X Fil:"Barely touched the rev limiter"? Heading up the hill on the left course it sounded just like my car, popping all the way. My datalogs show I was on it for two full seconds, although going uphill like that I swore I was just hitting it before I braked at the top. What's your redline?
Sounds like your need to do some ECU work. With the stock ECU we've been on the rev-limit on a few Roger Johnson Nationals-style courses even with tall tires.
07-03-2007, 8:25 AM |
07-03-2007, 11:23 AM |
Brian
Mid Ohio
Posts 104
Points 1,635
Thanks Andy, Bridgestone told me that they wouldn't support/suggest it over 7.0" wide rim, and I had mentioned that it is an autoX car that would not be on the street ever, etc. I am glad to know it is being put on a 7.5" rim and working (quickly), contrary to what UHP from Bridgestone told me.
Congrats at Peru...... Hopefully the CRX's will continue development and push their way to the top STS2 spot consistantly But maybe I'm a bit Honduh-biased, My car just needs a good driver, most the go-fast goodies are there, minus some one-of-a-kind parts we are still developing.
07-10-2007, 6:08 PM |
11-07-2007, 6:53 PM |
Posts 4,080
Points 60,045
Update: The latest issue of GRM (December 2007) has Part 3 of the print articles, with all of the dyno testing we did at the beginning of the project. It also contains some dyno stuff we did last winter. The former includes testing of a number of popular intakes/headers and other common mods.
Since GRM acquired many of these parts, this info is NOT contained in the online blog so that it may serve as a lead for the print mag itself. So go buy a copy! Feel free to discuss here, though. --Andy
11-08-2007, 10:52 AM |
Crosser1
Joined on 02-24-2002
Austin, TX
Posts 198
Points 3,065
Andy,
I got mine yesterday. Is there any way to post some of the dyno charts. The size they are in print makes them pretty much usless to see any of the points you were making.
Eric
11-08-2007, 1:07 PM |
Posts 4,080
Points 60,045
Crosser1:Andy,
Eric
Yeah, I was a bit disappointed with that. I was under the impression that they were going to appear in the larger size that you see in the chart #9 on the second sidebar. I'll see what I can do...
11-08-2007, 4:00 PM |
Crosser1
Austin, TX
Posts 198
Points 3,065
Thanks.
Just to clear up one point as well, What intake did you decide to use? The SPI or RB? I read the article late last night and was did not quite catch your choice, other than cooling it down between runs due to heat soak.
BTW, the bike strapped to the dyno was classic. I have got to take a ride down to ART's soon.
Thanks again,
Eric
05-14-2008, 8:38 AM |
Posts 4,080
Points 60,045
Back from the dead... Car has been out of hibernation with a win at the Fort Worth Tour. More importantly, we've got some Toyo vs Bridgestone tire testing up on the blog. This is from March. Enjoy! --Andy
05-14-2008, 9:38 AM |
glagola1
Joined on 04-08-2004
Atlanta
Posts 207
Points 2,430
The Toyos look even stronger when you consider that you've been driving on the B-stones for a while and are probably quite used to them... and the car was set up for them. I know I had to adjust my CRX setup when I switched to the Toyos. I am surprised by the Toyo tire pressures though. Did you take any pyrometer measurements on the tread or did you just go with what got you around the skid pad fastest?
Thanks, Matt
05-14-2008, 9:54 AM |
Posts 4,080
Points 60,045
glagola1:The Toyos look even stronger when you consider that you've been driving on the B-stones for a while and are probably quite used to them... and the car was set up for them. I know I had to adjust my CRX setup when I switched to the Toyos. I am surprised by the Toyo tire pressures though. Did you take any pyrometer measurements on the tread or did you just go with what got you around the skid pad fastest?
Thanks, Matt
No pyro, just the clock. I've been burned by the pyrometer too much in the past. And I did make a few adjustments to the car before the test. More rear bar. Did not hurt the Bridgestone performance, but did help the Toyo. Learned this from an informal test session at the Driveway just before Dixie. Car would not even turn on the Toyo.
No doubt that my "feel" preference is the Bridgestone. Some because of experience on the tire, as you say, but also because I personally prefer a more responsive tire. What's ironic is that just a year ago we were all saying that the Bridgestone was sloppy compared to the old Falken RT215. I can't even imagine back-to-back between the RT215 and the R1R. The Toyo just likes to run at big slip angles and you have to get used to that. Very much like an old-school bias ply. Maybe if I had power steering things would be different...
Page 13 of 14 (280 items)
... 13
