Kumho>Bridgestone?
Last post 06-13-2008, 1:39 PM by glagola1. 370 replies.
Page 12 of 19 (371 items)   « First ... < Previous 10 11 12 13 14 Next > ... Last »
  •  03-03-2008, 2:22 PM 288100 in reply to 288086
    Re: Toyo&gt;Bridgestone?
    Thanks for the response Andy.  I've definitely decided to get them shaved.  It seems that 4/32 is the target depth, but would 6/32 be that bad, hopefully get a little more wear out of them?  Last question, I promise.  Thanks!
    Sponsored by AgileAuto.com
    D.C./Philly Region - 3 STX
    cardomain.com/id/piknockout
  •  03-03-2008, 2:56 PM 288109 in reply to 288100
    piknockout:
    I'm not sure you get any more fast tread life from 6/32 than you do form 4/32, honestly.
  •  03-03-2008, 3:41 PM 288113 in reply to 288100
    piknockout:
    4/32 is fine.
    I shaved mt first set to 3/32nds and put over 200 runs on them before they started to go off just a little due to heat cycling.  Still have plenty of tread.  I've only ever corded one set and I did it on purpose just to see how far they'd go.  It really took some doing to get the tread to go away.  Like massive abuse.
    Chambers has had the same experience.  Miatas are a little friendlier on tires than FWD cars, though.
  •  03-03-2008, 11:51 PM 288189 in reply to 288113
    Andy Hollis:
    4/32 is fine.
    Mine went off somewhat at between 180 and 200 runs on the Civic. Wears the tires a little more, 4/32 is a good #.
  •  03-10-2008, 5:46 PM 289320 in reply to 286828
    Re: Toyo>Falken?
    Andy Hollis:
    glagola1:
    Anybody want to buy some lightly used 195/50-15 R1Rs?
    They are grippy but I'm not a big fan of how they feel.  They are obviously not a silver bullet.
    My experience is this:
    The Toyos feel like Dirt Stockers (bias ply, soft compound, soft carcass).  They require large slip angles and a deliver on a "toss" driving style.  If you are fromthe "finesse" camp like me (and Mike and Matt) you won't like them.  But they so stick, especially in low-grip/cold/wet conditions.  Might be a good HPT tire.
    When I get home later I will post a picture of a Toyo with the tread literally peeling off.  That was from a couple of runs on a 30-second course featuring both transitions and big sweepers (the latter did it) with my Civic.
    Expect also to totally change your setup.  These tires will make your car push a TON.
    I did a half-assed last-minute test last week and plan to do a more comprehensive test soon.  Especially if I can lay my hands on the new big size.
    Hi Andy,
    Thanks for the info.  Not exactly what I was hoping to hear.
    How do you think the R1R's compare to the Azenis RT-615's?  I am looking for a 275/40R17 for my '01 M Roadster.  The R1R and RT-615's are the only ones that come in that size that I have found.
    Do you think R1R's or RT-615's in 235/45R17 and 275/40R17 would be better than Direzza Z1's or RE-01's (Neova's are too $$) in 225/45R17 and 255/40R17?  Would the additional width of the R1R's or RT-615's offset the increase in performance of the Z1's or RE-01's.
    I currently have 235/45R17 and 275/40R17 Kumho MX's on the car.  I like the handling balance as it is, but would like to increase the grip all around by going to a stickier tire without resorting to an R-Comp (must be 140+ treadwear for my class).
    Thanks.
     -Scott
    Track Events Schedule
    1984 Porsche 911 track car
    2001 BMW M Roadster
    1993 Toyota MR2 Turbo
  •  03-11-2008, 9:32 AM 289441 in reply to 289320
    Re: Toyo>Falken?
    sbarton:
    Hi Andy,
    Thanks.
     -Scott
    Sorry, but my current autocross experience is with small, light cars and the current tires.  What works on those cars does not always carry over to heavier cars on bigger tires. My own daily-driver '01M Roadster wears Hankook Z212's that I won as contingency, but it doesn't see competition use.
    My guess is that the waters will still be muddy on the "best new tire" issue at least through the summer.  And then we get to do it all over again next year...
  •  03-13-2008, 2:31 PM 290016 in reply to 282526
    Re: Toyo>Bridgestone?
    cmt52663:
    I've just asked my local distributor to inquire, and should have an update later today.  Will advise.  I am going through Discount Tire in this case.  225/45-15 R1R.
    I have CRS (cain't remember sh*t) and must apologize to Town Fair Tire (a NE Area Toyo Distributor) for my confusion.
    Town Fair tire will have a set of 225/45-15 R1Rs in their warehouse for me on April 1st.  Should be on the car that week.
    Section Width: 8.86"
    Diameter: 22.97"
    Revs/Mile: 905
    Tread depth (unshaved)  8/32"
    Mfg. Part Number  #236970
    Cheers.
    Charlie Thompson
    '04 JCW Cooper [STX]
    NER Cannon Fodder
  •  03-13-2008, 5:47 PM 290047 in reply to 290016
    More Toyo news:  Apparently the 225/45/17 and a new size, 195/55-15 are now available.  So new stuff coming in dribs and drabs.
  •  03-13-2008, 9:54 PM 290085 in reply to 290047
    Andy Hollis:
    and there is a rebate for $100 off a set of R1Rs.
    89/189 STS/STX '89 Civic Si
  •  03-13-2008, 11:11 PM 290096 in reply to 290085
    BrianGT:
    Through who? any tire shop?  So it looks like 225/45/15 is available?
  •  03-14-2008, 7:29 AM 290112 in reply to 290096
    Garick:
    BrianGT:
    Rebate via coupon sent via snailmail to SCCA and NASA members.
    Who said the 225/45-15 is available?  "Arriving April 1" isn't "available" in my book.  225/45-17 is available, though.
  •  03-14-2008, 8:01 AM 290115 in reply to 290112
    yep - "available" means I'm driving on them
    what I did learn yesterday though is:
    1. Town Fair found the Item# on their retail system, so Toyo has entered the new size
    2. the Item# was accompanied by the revs/mile, diameter, and section data for the tire
    3. a call from Town Fair to the Toyo "Help Desk" produced availability data, and a hard ship date from Toyo to Town Fair warehouse
    So, getting close...
    Charlie Thompson
    NER Cannon Fodder
  •  03-14-2008, 12:51 PM 290171 in reply to 290115
    good news, thanks.  Should I have gotten this coupon in the mail already?
  •  03-14-2008, 1:51 PM 290176 in reply to 290171
    I got mine a couple of days ago, but I already bought Stones.  Too bad I threw it away...didn't think about giving it away. Embarrassed
  •  03-18-2008, 5:18 PM 290715 in reply to 290115
    according to Josh @ Town Fair Tire, the manufacturer's part number for the Toyo R1R 225/45-15 is #236970
    Cheers,
    Charlie
    Charlie Thompson
    NER Cannon Fodder
  •  03-19-2008, 1:33 AM 290783 in reply to 290715
    cmt52663:
    Cheers,
    Charlie
    A quick search of the toyo #236970 shows that this is actually the part number for the 225/45-15 toyo RA1 tire not the new R1R, might want to reconfirm that with Town Fair Tire.
    this page has the 236970 part number:
    http://www.racetire.com/products/toyo_ra-1.htm
    Schooner
    95 Miata STS2
  •  03-19-2008, 1:45 AM 290785 in reply to 290783
    Sclippy96:
    cmt52663:
    Cheers,
    Charlie
     yeah......same here
  •  03-19-2008, 8:11 AM 290799 in reply to 290785
    Nuts!  Thanks for the heads up.  I'll go have a chat with them today and report back.
    Charlie Thompson
    NER Cannon Fodder
  •  03-19-2008, 9:37 AM 290813 in reply to 290783
    Sclippy96:
    cmt52663:
    Cheers,
    Charlie
    Thanks again for catching that misunderstanding.
    Having just spent an hour chatting with the TF folks, and through them with Toyo, here is the correction.  My sincere apologies for posting bad information here.
    R1R 225/45-15 Part Number is #170140
    The item is in manufacturing at this time, however the Toyo systems do NOT yet have price or firm availability.  The Toyo rep that spoke with Dan at Town Fair tire guessed that the delay could be as little as 10 days, or as much as a month.
    I will update periodically, and make darn sure there are no further misunderstandings.
    --- 3/25 -- Same status ---
    Charlie Thompson
    NER Cannon Fodder
  •  03-21-2008, 9:42 AM 291265 in reply to 290813
    Indeed, hope them, or at least the 205/50-15 will be available soon.
    My 195s are getting low in tread, with 106 runs on them:
    http://tastybeef.com/tires/tires9.jpg
    http://tastybeef.com/tires/tires10.jpg
    Will have to see how long they go before cording.  They still feel like they have a little bit of rubber on them.
