Andy's STS2 Miata Project
Page 10 of 14 (280 items)   « First ... < Previous 8 9 10 11 12 Next > ... Last »
  •  01-03-2007, 10:38 PM 227584 in reply to 227038
    Re: Andy's STS2 Miata Project
    GChambers:
    That's impressive.
    Looks like I have a ton of weight to shed. We were hopeful that we could get my car down to 2015 from 2058lbs (On the HPT scales at Nationals) with going from the "B" package to a base package. I guess the new goal should be under 2000lbs. My current seats should be close to 25lbs. I will need to weigh them to confirm before the season gets going.
    If I could get the "fatman" down to the 2100 lbs range I'd be happy.  It scaled in at 2263 on the HPT scales, so this summer it might get a ltw battery.
    Andrew Cowden
    STS2 147 -- '95 Miata (the one always loosing magnets)
  •  01-13-2007, 8:33 PM 228822 in reply to 227584
    New update.  This one is a summary of everything learned so far.  It presents the basic recipe to build an STS2 Miata for any level of competition and budget.  Enjoy!
    http://grassrootsmotorsports.com/ne...a-sts2-project/
  •  01-13-2007, 10:27 PM 228830 in reply to 228822
    I could have sweor my Mazda service manual said something about 1 full turn on each side will yield about 1/4" toe out.
    Also, any chance of you prepping a 1.8L car for STS2 since stock they make 116 at the wheels? :)  I would think 125-130 should be do-able.
    David
    Andy Hollis:
    David Hedderick
    Pearland (Houston), TX
    08 Mazda 3s
  •  01-13-2007, 11:04 PM 228836 in reply to 228830
    davebs14:
    David
    Your memory is faulty.  Stick out tongue
    The manual specifically says "one turn (one side) equals 7mm (.28") toe change".  And we verified this on Bill Kim's alignment rack at Soulspeed.
    As to a 1.8, I'd be happy to help *you* set one up.  But I'm not done with my current car just yet.
  •  01-14-2007, 10:38 PM 228917 in reply to 228836
    awesome write-up.  thanks.
    Mike - #44 STS2
    '91 Miata - racer
    '07 CX-7 - dog taxi
    www.phillyscca.com
  •  02-08-2007, 11:02 AM 232149 in reply to 228917
    New installment.  Dyno work on exhaust systems, including Borla twin-tip.
  •  02-08-2007, 12:15 PM 232160 in reply to 232149
    You left out the weight of each combination.
  •  02-08-2007, 3:42 PM 232194 in reply to 232160
    Thanks Andy.  I hacked off my flowmaster last week and installed a disc only supertrapp in order to save some weight.  So now I have a 2.25 inch diameter exhaust with a glass pack and supertrapp.  Weighs about 8 lbs and works great thanks again for the dyno results, it aided in how many discs to run this weekend at the shakedown before I head down to Dixie.
    Keith
    2005 Chrysler Crossfire-- DS
    1993 Subaru Legacy-- Rallycross car
  •  02-08-2007, 3:45 PM 232196 in reply to 232160
    modernbeat:
    I was being lazy and did not have the info at hand.   Its there now.  No surprises there.
  •  02-08-2007, 6:16 PM 232208 in reply to 232196
    Yea, that's what I found when I dyno'ed the supertrapp on my '99.  Wide open made the most power, but was crazy loud.  I always wondered if it was because I only had a 2" Supertrapp though.  Possibly a 2.25" would have worked with plates.
    Andy, did you try the end plate with the open hole in it?  I looked, but couldn't find your exact Supertrapp config (probably just missed it).  What diameter and length did you test?
    Dave G.
  •  02-08-2007, 10:17 PM 232240 in reply to 232208
    talon95:
    Dave G.
    This one: Supertrapp
    17" length, 2.25" id, 4" od
  •  02-28-2007, 11:21 AM 234773 in reply to 232240
    GRM blog updated: Dixie Tour
  •  02-28-2007, 1:14 PM 234802 in reply to 234773
    Thanks for yet another update.  Which MaxQ system are you using, the entry level MQGPS?
    It might be time to get serious this year.  :P
    Brian
    Brian Peters
  •  02-28-2007, 2:54 PM 234817 in reply to 234802
    Just stumbled across this thread Andy. Great blog with excellent info! Good luck in '07 to you and Ann!
    Chike Dellimore - Blue Ridge/Washington DC Regions
    2006 Galaxy Gray 6MT Mazda RX-8 (B-stock)
    Former 2006 Steel Gray 5spd WRX (D-stock)
    "Between now and Nats, f!ck seat time - I'm working on crazy!!!"
  •  02-28-2007, 3:10 PM 234821 in reply to 234802
    Eunos:
    Brian
    Entry level MQGPS, yes.  Bluetooth version.  Does what I need.  No need to overcomplicate things. I love the battery power and lack of wires.
  •  03-06-2007, 5:22 PM 235765 in reply to 234821
    New update and new link: Delrin Downsides and Cocked Cams
    Did some maintenance on the Delrin suspension bushings, and found the classic Miata front-end clunk due to whacked adjuster cams.
  •  03-09-2007, 9:58 AM 236160 in reply to 235765
    Hey Andy.
    In looking at a few pics of your car, it looks like you and I run the same wheels.  (15x7 SSR's - mine on an ITA Miata 1.8 as you know)  Are you running spacers?  Can you?  It looks like you could grab a little more track without getting to the fender lip.  I use them and they are a REAL nice tuning tool.
    Andy Bettencourt
    Flatout Motorsports
    New England Region
    www.flatout-motorsports.com
  •  03-09-2007, 11:07 AM 236169 in reply to 236160
    Andy Bettencourt:
    Hey Andy.
    Actually, I run either 15x7.5" or 16x7.5", depending on my mood.  But yes, I *could* easily run more track.  But I don't want to.  Here's why:
    My philosophy on width in an autocross car is to keep the car as narrow as possible.  When you do the calculations, the benefits of extra track in terms of lowered weight transfer are not as important as the time benefits of driving a shorter course.  On transitional maneuvers, especially slaloms, those extra inches of track hurt you more than the handling benefit helps you.  Same with running tighter lines around 180's and such.
    In road racing, its all different because you have real straights.  In that case, carrying speed through a turn (even if it means running a slightly longer path) pays dividends all the way down that long straight.  Especially on low-powered, good-handling cars like a Miata.  The extra handling can also be beneficial as a tactical advantage when running a sub-optimal line to get position on a competitor.
    Hope that makes sense,
  •  03-09-2007, 12:24 PM 236174 in reply to 236169
    Makes sense.  I guess I was thinking that maximizing the track within the external limits of the car (ie: what is going to hit the cones) would make for the best handling car.
    Andy Bettencourt
    Flatout Motorsports
    New England Region
  •  03-09-2007, 1:33 PM 236184 in reply to 236174
    Yeah, but you ALWAYS hit the car with the wheels unless you have some funny canards or splitter. Especially on a Miata with the bodywork sloping in at the bottom.
    -Philip Maynard
    No weenies!
